It’s no secret that here at Overclockers UK we just love to spoil you. That’s why we’re back with another round-up of some tasty deals currently available that are sure to boost your gaming performance.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/10/Deals-Day-1024x1024.png)
Lian Li Galahad II LCD 280mm AiO CPU Cooler
Keep your hardware cool and performing at its best with the Lian Li Galahad II LCD AiO CPU Cooler. Equipped with a 280mm radiator and two pre-installed 140mm PWM fans, excess heat is effectively dissipated away from your processor to facilitate superior processing and blisteringly fast speeds. With a maximum noise production of only 32.1 dB(A), you can enjoy all this powerful cooling with whisper-quiet operation. Plus, the integrated RGB lighting ensures it will look fantastic in any PC, regardless of your chosen aesthetic.
- AiO CPU cooler
- 280mm radiator
- 2 x 140mm PWM fans
- Compatible with Intel and AMD CPUs
- Integrated RGB lighting
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/280_lcd_b-300x300.png)
LG 32GR93U-B 32’’ Gaming Monitor
Elevate your battle station with the LG 32’’ Gaming Monitor. Take advantage of the 3840 x 2160 resolution to unlock plenty of screen real estate for all your must-have apps, games, and tabs. Armed with both 144Hz refresh rate and 1ms response time, enjoy crisp and incredibly detailed visuals, with ultra-fast responsiveness and minimal screen tearing or ghosting. Plus, support for AMD FreeSync and NVIDIA G-Sync delivers high-res images and visuals with no unwanted display stutter breaking up your immersion.
![LG 27" 27GR93U-B 3840x2160 IPS 144Hz 1ms FreeSync/G-Sync HDMI 2.1 Gaming Monitor](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/lg-ultragear-27gr93u-b-gaming-monitor-300x300.jpg)
- 32’’ gaming monitor
- 3840 x 2160 display
- IPS panel
- 144Hz refresh rate
- 1ms response time
Ducky Project D Tinker 65% RGB USB Mechanical Gaming Keyboard
Level up your typing game with the Ducky Project D Tinker 65% Mechanical Keyboard. Built utilising only premium-grade materials, this keyboard delivers smooth and pixel-precise gaming that you can customise to perfectly suit your needs thanks to hot-swappable tech. As standard, this keyboard features Cherry MX Brown, a great all-rounder key switch that boasts tactile feedback and medium actuation force, and PBT double-shot keycaps which have been fine-tuned to stand the test of time.
- Mechanical gaming keyboard
- 65% form factor
- Hot-swappable
- This model comes with Cherry MX Brown key switches
- PBT double-shot keycaps
- Integrated per-key RGB backlighting
![Ducky Project D Tinker 75% RGB USB Mechanical Gaming Keyboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/ducky-projectd-tinker75-pre-built-keyboard-removebg-preview-300x300.png)
ASUS ROG Keris Optical RGB Gaming Mouse
Achieve pixel precise gaming with the ASUS ROG Keris Optical Gaming Mouse. Boasting a lightweight design, high-quality optical sensor, and specially tuned DPI of up to 16,000, unlock superior control over your mouse movements. The 1000Hz polling rate facilitates next level responsiveness, which is sure to prove advantageous during the heat of battle. What’s more, the ROG Omni Mouse Feet ensures this gaming mouse glides effortlessly across any surface.
![ASUS ROG Keris Gaming Mouse](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/07/asus-rog-keris-gaming-mouse-300x300.jpg)
- Optical gaming mouse
- Designed for esports
- Lightweight design
- DPI of up to 16,000
- 1000Hz polling rate
AMD Ryzen 7 7800X3D Processor
Harness the AMD Ryzen 7 7800X3D to unlock AAA performance in all your favourite games and demanding workloads. Built with Zen 4 architecture and featuring a blend of 8 cores and 16 threads, this processor has been designed with gaming in mind to facilitate ultra-fast speeds across single- and multi-threaded applications. Incredible 3D V-Cache tech boosted this one step further, delivering higher capacities and next-level efficiency.
- Zen 4 architecture
- 8 cores
- 16 threads
- Up to 5.0GHz boosted clock speed
- 3D V-Cache technology
- Supports DDR5 RAM and AMD EXPO
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/AMD-Ryzen-7-7800X3D-Eight-Core-5.00GHz.avif)
Still Searching for The Perfect Deal?
Still on the hunt for the perfect deal to upgrade your gaming set-up? At Overclockers UK, we stock a premium range of hardware and must-have peripherals that you can purchase at wallet-friendly prices.
Click the button below to explore all our current deals.
Did You Find a Bargain?
Did you find the ultimate bargain? Let us know in the comments below.
*Prices correct at time of writing and are subject to change.
