The sun is shining, the pollen count is getting higher, and we are in the mood for some Spring Deals!
Starting today, you can score some spicy savings in our Spring Deals. With offers on a wide range of products and components, this is the perfect time to make an upgrade or two.
Spring is Here
There are many great offers in the Overclockers UK Spring Deals, from your favourite brands like Lian Li, AMD, and more. We’ve picked out five of the spiciest to pique your interest here, but there is plenty more where that came from!
Glorious Model D- Gaming Mouse
- USB gaming mouse
- Up to 12,000 DPI and 50G acceleration
- Lightweight at approximately 58g
- RGB lighting and stylish honeycomb shell
- Save up to 13%
ASUS ROG Strix B760-F Gaming WIFI DDR5 ATX Motherboard
- ATX LGA 1700 motherboard
- Support for DDR5, PCIe 5, and WiFi 6E
- Compatible with 12th, 13th, and 14th Gen Intel
- Iconic ASUS ROG design
- Save up to 24%
LG 27” UltraGear 27GR95QE-B OLED Monitor
- 27” widescreen OLED monitor
- 2560 x 1440 resolution
- 240Hz refresh rate and 0.03ms response time
- FreeSync and G-Sync certified
- Save up to 25%
Gigabyte GeForce RTX 4090 Gaming OC GPU
- Ada Lovelace architecture
- 24GB GDDR6X VRAM
- WINDFORCE cooling system
- Fusion RGB lighting
- Save up to 10%
OcUK Gaming Oxygen Configurable Gaming PC
- Configurable gaming PC – adjust the spec to suit your needs!
- AMD Ryzen 5 7500F CPU as standard
- NVIDIA GeForce RTX 4060 Ti GPU as standard
- Stylish APNX C1 iridescent case
- Save up to 11% (on standard spec, pricing may change with adjustments)
Savings to Put a Spring in Your Step
Will you be bagging a bargain in our spring deals? Let us know in the comments below!
All pricing is correct at the time of writing. Deals are a limited time offer.
