Usually, when checking out the list of game releases for the upcoming month, I find five really juicy titles to get all excited about. But, with so many games dropping this September, I couldn’t limit this list to five – you get the full ten. Plus, even though the summer might be officially done, we still have to think about keeping our gaming PCs cool. Especially if you’re going to be cranking up the heating soon! So to go with this phenomenal collection of games, I am going to highlight a selection of high-performance AiO coolers available at Overclockers UK.
They might even be themed.
Rogue Lords – 30/9/21
Rogue Lords, from Cyanide Studio and Leikir Studio, is a twist on the classic RPG. Instead of playing as virtuous heroes, the underdog, or the rogue with a golden heart, you play as the Devil, himself. You are actively trying to sow discord and terror around the world, with the help of evil geniuses you recruit along the way. Take your revenge on the demon hunters of the world!
Component | Min. Spec | Rec. Spec |
Operating System | Windows 7 64-bit | Windows 10 64-bit |
Processor | Intel Core 2 Duo E6750 AMD Phenom II X2 550 | Intel Core i5-3470 AMD FX-3850 |
Memory | 4GB RAM | 8GB RAM |
Graphics | Nvidia GeForce GTX 650 AMD Radeon HD 7770 | Nvidia GeForce GTX 660 AMD Radeon R9 270X |
DirectX | Version 11 | Version 11 |
Storage | 3GB available space | 3GB available space |
While you try to regain your dark hold on the world, your gaming PC can be kept at optimum temperature by the Asus ROG Strix LC AiO Cooler. Available in 360, 240, and even 120 models, so whether you opted for a full-tower or mini-ITX, there is a loop to fit your build. Additionally, they come in black or white – ensuring there is one to suit your chosen aesthetic!
There are many great features of this system, including stunning RGB lighting, extended compatibility with a range of motherboards, and 4-pin PWM control. Cooling is efficient and effective thanks to the optimised fan and improved pump designs. Plus, this AiO cooler is highly durable thanks to the reinforced, sleeve tubing.
Features |
Available in 360mm, 240mm, and 120mm |
Optimised airflow and static pressure |
Individually addressable RGB lighting |
Reinforced sleeved tubing for durability |
Precise 4-pin PWM pump control |
Fan rotation Speed: 800 ~ 2500RPM |
SkateBIRD – 16/9/21
If ever there was a game I never knew I needed, it’s SkateBIRD from Glass Bottom Games. You genuinely play as a small bird, skateboarding over home furniture because you’re sad your owner has hung his board up for good. Yep. That is the story. You could say this bird is a regular… Tony Hawk.
Operating System | Windows 7 64-bit | Windows 7 64-bit |
Processor | Intel 3rd generation Core Or equivalent | Intel 3rd generation Core Or equivalent |
Memory | 2GB RAM | 2GB RAM |
Graphics | Intel HD 4000 | Intel HD 4000 |
DirectX | Version 10 | Version 10 |
Storage | 500MB available space | 500MB available space |
Sound Card | Integrated | Integrated |
Whilst you grind the rails and grab some extreme air, your gaming PC can be doing the same. Grabbing some extreme air, that is, with the OcUK Tech Labs 645LT Asetek CPU Cooler. Available with either a Cryorig or Noctua fan, this AiO beast is equipped with a Gen 6 pump from Asetek and all mounting hardware is included. Plus, as it is an Overclockers UK exclusive, there are configurable components, meaning you can craft the perfect CPU cooler for your setup.
Despite their compact size, these coolers are highly efficient and this can be attributed to the 92mm aluminium heat exchanger along with the optimised Cryorig or Noctua fans.
Overclockers UK Tech Labs 645LT Asetek Cooler
Features |
Available with Cryorig or Noctua fans |
92mm optimised fans |
Perfect for SFF builds |
Gen 6 integrated pump and copper cold plate |
Thick 92mm aluminium heat exchanger |
Modern, appealing aesthetics |
Overclockers UK Tech Labs 645LT Asetek Cooler: Cryorig
Kraken Academy!! – 10/9/21
The kids may have gone back to school, but you’ll want to join them with Kraken Academy!! from Happy Broccoli Games. Whilst it is “technically a school”, you will spend more time befriending spirits and trying to prevent the end of the world than you will be studying Shakespeare. Damn straight, too, there’s a traitor to uncover in this time loop game! A colourful and wacky game, it uses a blend of 8-bit and comic book style artwork to bring this game to life.
Processor | Intel Core i5 1.2GHz and up | Intel Core i5 1.2GHz and up |
Memory | 1GB RAM | 1GB RAM |
Graphics | DX10, DX11, DX12 capable | DX10, DX11, DX12 capable |
Storage | 400MB available space | 400MB available space |
I would be a fool to not suggest the NZXT Kraken AiO coolers with this game. Talk about a stars aligning moment! With the NZXT Kraken RGB AiO range, there are three models to choose from. The X73, which is 360mm; the X63, which is 280mm; and finally, the X53, which is 240mm. Paired with a bigger infinity mirror, the stunning RGB shines bright and illuminates your case. It will feel like there are spirits living in your gaming PC.
Utilising NZXT’s CAM software, you can achieve precise control over your fans and cooling performance. Airflow is optimised by the specially designed, winglet-tip blades, with the extra bonus that this shape reduces noise. Plus, thanks to their hydraulic bearings, the fans have amazing longevity and durability. They will keep cooling with every reset of the time loop.
NZXT Kraken X73 RGB AiO Cooler
Features |
10% bigger LED ring for brighter RGB |
Fluid dynamic bearings in every fan |
Full CAM integration |
Fine nylon mesh sleeves heighten durability |
Pump motor Speed: 800 – 2,800 ± 300 RPM |
Winglet-tip fan blade design for optimal airflow |
GameDec – 21/9/21
From Anshar Studios, GameDec is an isometric, non-combative RPG set in a cyberpunk world. You play as a game detective, solving crimes within virtual worlds, and every choice you make has real in-game consequences. The entire story is shaped by what you do, adapting to fit the narrative you build. Every play-through will be different.
Operating System | Windows 10 64-bit | Windows 10 64-bit |
Processor | Intel i5-3570 AMD FX-8140 | Intel i7 4770k AMD Ryzen 5 1500X |
Memory | 8GB RAM | 16GB RAM |
Graphics | Nvidia GTX 760 AMD Radeon R9 270 | Nvidia GTX 1060 AMD RX580 |
Storage | 30GB available space | 30GB available space |
With so much to think about with your game, solving cases and wondering what effect your choices will have, you really don’t need to be worrying about thermal performance. Armed with a Gigabyte Aorus Waterforce X AiO cooler, cooling will not even cross your mind as you delve deeper into the mysteries. Available in 360mm, 280mm, and 240mm models, there is one to fit your system.
Efficient heat dissipation is a breeze thanks to the high-performance pump, keeping the AiO cooler working effectively. The pump even includes a rotatable, LCD screen that can display temperatures, custom text, or even a Chibi Time Mode. (I know which setting I would have!) With all this information easily accessible and clearly displayed, you can keep on top of any thermal mishaps and rectify them quickly. That is one consequence you won’t have to deal with!
Gigabyte Aorus Waterforce X AiO Cooler
Features |
High-performance pump for heat dissipation |
Unique circular LCD full-colour screen |
Low-noise level Graphene Nano Lubricant ARGB fans |
RGB FUSION 2.0 enabled |
330 degrees manual rotatable design |
AORUS exclusive design Micro SD port support |
Bus Simulator 21 – 7/9/21
If it wasn’t abundantly clear, we love a good simulator at Overclockers UK. Bus Simulator 2021 from stillalive studios dropped this week and is satisfying some of that missed summer travel needs. Explore routes around Europe and the USA, in a choice of 30 different buses – from double-decker to e-bus. There are single-player and multiplayer modes, varying gameplay as you enjoy the hyperrealistic graphics. Drive models from famous manufacturers, experience dynamic weather, and endless customisation. Plus, explore the management of your bus fleet, as well as perfecting your driving skills. This game has so much to offer.
Processor | Intel Core i3-2120 AMD Phenom II X4 830 | Intel Core i5-4440 AMD FC-8140 |
Memory | 8GB RAM | 8GB RAM |
Graphics | NVIDIA GeForce GTX 760 AMD Radeon R9 280 | NVIDIA GeForce GTX 1070 AMD Radeon RX Vega 56 |
DirectX | Version 12 | Version 12 |
Network | Broadband Internet connection | Broadband Internet connection |
Storage | 18GB available space | 18GB available space |
Getting to grips with such a big vessel is not the easiest feat, thankfully the tutorial is narrated to help you pick up the necessary skills. This means having the quietest cooling loop is paramount. Who better to pick than be quiet! and their Silent Loop 2? Models are available in 360mm all the way down to 120mm, so there is premium, silent performance for all.
How is such quiet performance achieved? The adjustable and dampened pump is equipped with a six-pole motor, plus the three-chamber design reduces turbulence. Subtle RGB lighting illuminates the pump, for style levels to match the thermal performance. Paired with the be quiet! Silent Wings 3 PWM fans and cold plate, the Silent Loop 2 truly lives up to its name. You can concentrate on building schedules and forming bus routes.
be quiet! Silent Loop 2 AiO Cooler
Features |
Dampened and adjustable pump with six-pole motor |
ARGB LEDs on pump for customisable lighting |
3-chamber pump design reducing turbulence |
Silent Wings 3 PWM high-speed fans |
Control via motherboard or wired remote control |
Easy-to-access refill port |
Big Rumble Boxing: Creed Champions – 3/9/21
Since 1976, Rocky has been a big, fictional name in boxing, with nine films and several video games existing as part of the “Rocky Universe”. Joining that line-up is Big Rumble Boxing: Creed Champions from Survios, Inc. As you would expect, this is a blood-pumping, boxing game that features all the iconic names associated with the Rocky franchise. Play as Rocky Balboa, Adonis Creed, Clubber Lang, and more, as you see if you have what it takes to be a champion.
Processor | Intel Core i5-4590 AMD FX 8350 | Intel Core i5-4590 AMD FX 8350 |
Graphics | NVIDIA GeForce GTX 970 AMD R9 290X | NVIDIA GeForce GTX 980 Ti AMD Radeon R9 Fury X |
Storage | 8GB available space | 8GB available space |
As you take on your opponent in the ring, you want an AiO cooler that can really pack a punch. The MSI MAG Coreliquid range is up to the job, as it was designed to provide efficient cooling without compromise. The RGB lighting can be changed to match the colours of your boxer – perhaps red and white for Rocky, himself? – whilst the MSI dragon motif looks fierce on the pump. Watch your foe tremble!
A combination of durable materials and a three-phase motor grant this AiO loop great longevity, keeping your gaming PC cool throughout your training. (Just queuing Eye of the Tiger, excuse me.) The radiator can be mounted in any orientation to suit your build and the blockhead can be rotated to match, keeping your aesthetic sleek. Plus, with models in 360mm, 280mm, and 240mm, there is a loop to match your spec.
MSI MAG Coreliquid AiO Cooler
Features |
Mount the cold plate in any orientation |
Integrated pump into radiator for quieter operation |
Durable three-phase motor |
Split pathway for efficient heat dissipation |
Netted plastic tubing and a reinforced mesh exterior |
Secure installation bundle with vast compatibility |
Deathloop – 14/9/21
Trapped in another time loop, Deathloop from Bethesda Softworks, sees two rival assassins doomed to live the same day over and over and over… Set on the island of Blackreef, this is a next-gen FPS game where you have to do whatever it takes to break the loop. Or be stuck in the cycle. Learn from every loop and try to change your fate. If at first, you don’t succeed, then die, die again.
Processor | Intel Core i5-2500K AMD FX-8350 | Intel Core i7-9700K AMD Ryzen 7 3700X |
Memory | 8GB RAM (Dual-channel) | 16GB RAM (Dual-channel) |
Graphics | NVIDIA GeForce GTX 1060 AMD Radeon RX 580 | NVIDIA GeForce RTX 2070 AMD Radeon RX 5700 XT |
Storage | 45-50GB HDD SSD strongly recommended | 45-50GB HDD SSD strongly recommended |
Blackreef may sound like a tropical paradise, but this retro-future landscape is anything but. In fact, it can feel more like a prison to your character, Colt. To help sting his enemies, equip your gaming PC with the Jonsbo Jellyfish TW5 AiO. A high-performance cooler, this comes as a 360mm model with stylish RGB lighting on the pump.
Connecting to your motherboard or fan controller via a 4-pin PWM connector, thermal performance and volume are dictated by fan speeds, which operate between 700 and 1800RPM, as per your needs and preference. The pump motor operates at 2600RPM, for smooth and efficient performance. You’ll be sneaking up on your rival, Julianna, with ease.
Jonsbo Jellyfish TW5 360mm AiO Cooler
Features |
Water cooling system with easy installation |
360mm radiator with 3 x 120mm PWM fans |
Stylish RGB LED lighting on the pump |
Connects via 4-pin PWM header |
Interface with motherboard or controller |
Pump Speed: 2600RPM ±10% |
Fire Commander – TBA
If you always fancied being a firefighter growing up, now is your chance to see what it would be like. With Fire Commander from Atomic Wolf and Pixel Crow, you can face fire in this RTS game – commanding your unit and saving lives. There are over 30 missions for you to complete and develop your team on, you will face more than your average house fire. Toxic spills, difficult logistics, and dangerous environments stand in your way. Do you have what it takes to be a hero?
Operating System | Windows 8 64-bit | Windows 10 64-bit |
Processor | Intel Core i5-3570K | Intel Core i7-4790 |
Memory | 12GB RAM | 12GB RAM |
Graphics | NVIDIA GeForce GTX 780 | NVIDIA GeForce GTX 1060 |
Sound Card | Yes | Yes |
Storage | 15GB available space | 15GB available space |
When it comes to AiO coolers, Phanteks has more Glacier Ones than you can shake a stick at. Leaving you spoiled for choice. The latest model, the T30s, hit the Overclockers UK website last month, meaning you can equip yourself with the very latest in AiO cooling tech if you opt for this system. Available in a 240mm model, the Glacier One T30 has RGB lighting with an infinity mirror, premium fans, and a heatsink with a fin density of 21 FPI.
So named the “T30” for its two 120mm T30 fans, this AiO cooler is equipped with fans that are 30mm which allows for blades that are 25% longer than those with a typical design. They have a high static pressure that, when paired with the PWM pump, facilitate whisper-quiet operation with highly efficient cooling performance. Plus, your hardware will be safeguarded, thanks to the integrated intelligent protection which adjusts fans speeds when necessary. Whilst you’re the hero fighting fires on screen, the Glacier One T30 will be the hero of your gaming PC.
Phanteks Glacier One 240 T30 AiO Cooler
Features |
High-performance pump with PWM control |
2 x 120mm Phanteks T30 fans |
Infinity mirrored RGB lighting |
Integrated intelligent protection |
Fan blades 25% longer than the typical |
Three performance profiles |
Sonic Colours: Ultimate – 7/9/21
Everyone’s favourite blue hedgehog is back, in Sonic Colours: Ultimate from SEGA. This game is high-speed, colourful, and full of amazing levels to complete. Dr. Eggman has built an incredible, interstellar amusement park but is using the alien race, Wisps, to power it. Of course, it is up to Sonic to save these creatures and thwart his long-time foe. Upon freeing the colourful Wisps, Sonic gains new abilities to further explore the six worlds, such as passing through solid objects or discovering new paths. It’s time to hit the ground running!
Processor | Intel Core i5-6600 AMD Ryzen 5 1600X | Intel Core i5-6600 AMD Ryzen 5 1600X |
Graphics | NVIDIA GeForce GTX 650 Ti AMD Radeon HD 7790 | NVIDIA GeForce GTX 650 Ti AMD Radeon HD 7790 |
Storage | 26.5GB | 26.5GB |
Naturally, you cannot save colourful Wisps without some colourful cooling. The Corsair Hydro iCUE H150i Elite AiOs are just the ticket. These 360mm AiO coolers are available in black or white, so they will suit a range of aesthetics, and utilise Corsair ML RGB Series PWM fans for highly efficient cooling. With up to 2,400RPM, it’s going to feel like Sonic, himself, is powering your fans!
Featuring 33 ultra-bright Capellix LEDs across the fans and pump, the lighting can be configured within Corsair’s iCUE software or by using the included fan speed and RGB controller. Use your RGB lighting to show which Wisps you have saved or which is your next target whilst the split-flow cold plate and whisper-quiet centrifugal pump provide thermally optimised and exceptional performance. Dr. Eggman will be looking for a new power supply in no time! Perhaps I should point him in the direction of highly efficient, 80 Plus Rated PSUs?
Corsair Hydro iCUE H150i Elite AiO Cooler
Features |
Water cooling systemPowerful, low-noise cooling |
Smart RGB lighting and fan speed controller |
3 x 120mm CORSAIR ML RGB Series PWM fans |
Optimal cold plate design and a high-density stack |
Flow rate of up to 0.82L/min |
Modular, tool-free mounting bracket |
Corsair Hydro iCUE H150i Elite AiO Cooler: Black
Corsair Hydro iCUE H150i Elite AiO Cooler: White
Test Drive Solar Crown – 22/9/21
Finally, we have what is shaping to be a phenomenally real and adrenaline-pumping game, Test Drive Solar Crown from KT Racing. An open world and lifestyle experience, you can drive some seriously high-end cars whilst living a life of luxury. Social status is everything in this world, so you need to race, cruise, socialise, and curate a sophisticated lifestyle. The latest addition to the Test Drive franchise, this game features a lot of the original game’s DNA in a beautiful 1:1 recreation of the real world. Customise your avatar, your car, and live that high life.
Processor | Intel Core i3-4170 AMD FX-6120 | Intel Core i7-3820 4-Core 3.60GHz AMD Ryzen R5 1400 |
Graphics | AMD Radeon R7 250X NVIDIA GeForce GTX 650 Ti | AMD Radeon RX 470 4GB NVIDIA GeForce GTX 1060 |
Storage | 80GB HDD | 80GB HDD |
This is going to be one demanding game, so you definitely need an AiO cooler that is more than up for the task of keeping your gaming PC at optimum temperature. The Lian Li Galahad AiO cooler comes as either a 360mm or 240mm, in black or white. Both models feature brilliant RGB lighting, PWM fans, and a triple chamber pump.
With a namesake like Sir Galahad from the Round Table, you can expect some high-performance cooling from this AiO. The high-pressure fans create incredible airflow whilst the braided, malleable tubing facilitates flexible installation. Customising the look of your Lian Li Galahad goes beyond the RGB lighting, as the water block comes with two magnetic caps for mixing things up. Match your cooling aesthetic to your unique Lamborghini for one mission, then to your Porsche when hitting the hottest party. Bling-a-licious.
Lian Li Galahad AiO Cooler
Features |
Triple-chamber water pump for efficient heat transfer |
High static pressure fan |
Multiple lighting ARGB LEDs modes |
400mm long tubing for flexibility |
Easy to sync with motherboard |
Removable cap on water block for two looks |
Lian Li Galahad AiO Cooler: Black
Lian Li Galahad AiO Cooler: White
Who Needs Sleep Anyway?
With so many incredible games dropping this month, it feels like there is going to be barely any time to work, eat, or sleep! Let us know which games you’ll be trying in the comments below, and if you have an AiO cooler installed in your gaming PC.
