There’s something you don’t have to accept when building a small-form-factor PC; excessively high temperatures. As long as your internal components have access to plenty of airflow, they won’t suffer from overheating and throttled performance. The SSUPD Meshroom S Mini-ITX case provides unparalleled access to cool air, thanks to the all-around mesh panels. Furthermore, this case has plenty of space for all your dream hardware. Enjoy unrestricted space for full-size GPUs, plenty of storage drives, and even custom water cooling.
Room for Everything
The Meshroom proves the adage that great things come in small packages. This Mini-ITX case provides plenty of space for even the most powerful and chunky components. The Meshroom S offers sufficient clearance for a full-sized GPU with a length of up to 336mm, and there are four expansion slots available.
This emphasis on providing options for components applies to power supplies, as well as graphics cards, with clearance for an ATX PSU up to 170mm in length. The Meshroom S is also able to house an ATX motherboard within its confines with a couple of adjustments: some padding and a riser cable (sold separately).
Room to Breath
SSUPD has put the Mesh into Meshroom. They’ve achieved this by making practically every panel out of a fine mesh that allows easy airflow in and out of the cases. Alternatively, there is the option to show off internal components with optional tempered glass side panels.
To aid with maintaining peak performance, this case is able to accommodate a range of cooling options. First of all, there is 74mm of clearance within the case for highly efficient CPU coolers. If water-cooling is more appealing, then SSUPD has built-in plenty of scope for an AIO or a custom loop. This is thanks to multiple locations to mount a water pump and the ability to simultaneously install two 280mm radiators.
These cooling options are supported by the phenomenal number of fans that can fit in this Mini-ITX case. The Meshroom has three locations that can support up to five fans. Two 140mm or 120mm fans can be mounted to the side panel, alongside a further two 140mm or 120mm fans mounted to the front panel. These are then complemented by a 120mm slim fan that can be mounted at the top.
A Mini-ITX Case that’s Easy to Build in
SSUPD has kept building in the Meshroom series a simple process, without the need for too many additional tools. To accomplish this, every panel is easily removed, as they all attach with push pins. Thus giving you free access to anywhere in this case.
In addition to this, these cases are also easy to assemble, with removable brackets for alternate internal layouts to suit any component choices. This gives you plenty of flexibility to reach inside your PC and easily seat each component, then perfect the cable management.
Get yourself one of these Spectacular Mini-ITX cases
So why not turn some heads with one of these amazing SSUPD Meshroom S cases. Get yourself over to Overclockers UK to pre-order one of these remarkable cases today.
Meshroom S
- Supports ATX motherboards
- AIO support for up to 340mm radiator
- Full-size GPU support for an up to 4-slot 336mm card
- 3 positions for a water pump for a custom loop
- Houses up to 2 x 3.5″ HDD + 2 x 2.5″ SSD / 7 x 2.5″ SSD
Wow. Any clues as to when these will ship ?
We’re super excited for this case, too! At this moment, we haven’t received an official ETA from the manufacturer. If you have any further questions, feel free to get in contact with our Custom Services team.
