Come along as we shine a spotlight on some of our favourite gaming brands. Summer loving, and all that!
When it comes to gaming hardware, there will be certain brands that just stand out to you, depending on which facets of the hobby you like the most. Keyboard modders might like Glorious GMMK or Ducky ProjectD best. Gamers on the go might have a thing for ASUS or MSI laptops. And I know that the hoarder in us loves lightning-fast storage from WD and Seagate. So come and share in the love we have for these gaming brands!
Quackers about Ducky
Ducky is best known for its premium quality mechanical keyboards. Originally started in 1998, their consumer products were introduced in 2008 and have been dominating ever since. Ducky’s vast range of mechanical keyboards come in a variety of form factors to suit every gaming set-up. Those short on space can opt for their SF (65%) or Mini (60%) keyboards and enjoy the same level of quality and functionality as those with a full-sized keyboard. Paired with the extensive array of Cherry MX switches or Ducky Switch Kits, there truly is a Ducky keyboard to fit every need.
Feature Product: Ducky One 3 Daybreak SF
The latest generation of Ducky keyboards dropped earlier recently: the Ducky One 3. They have quickly won a place in our hearts. The Daybreak SF is part of this impressive range, featuring four core principles: True PBT keycaps, solid stance, authentic acoustics, and balanced tuning.
The “SF” indicates it is the 65% form factor model, saving on space by omitting the F-key line and number pad. It does, however, still feature the arrow and navigation keys. “Daybreak” denotes the colour scheme, a rich blend of blues accented with yellow. A truly stylish addition to any gaming environment.
The Ducky One 3 Daybreak SF comes with a selection of switch choices. Pick from classics such as Cherry MX Red and Blue, or even opt for the more specialist switches, such as Cherry MX Silent Red. Swapping between models is easy, as each product page has drop boxes for switch choices, keyboard sizes, and even colour schemes!
In addition to this, the One 3 models are equipped with hot-swapping technology, allowing you to easily remove and replace switches for more personalised feedback. No soldering required.
Ducky One 3 Daybreak SF Keyboard
- True PBT double-shot keycaps
- Dazzling RGB lighting
- Hot-swapping technology
- Ergonomic profile
- Dark blue colour scheme
More Quacking Content on Ducky
So long as Ducky keeps producing incredible gaming keyboards, we’ll keep talking about them!
Kooky for Kolink
The Kolink promise is affordable performance without compromise, and boy do we think they deliver! Known for feature-packed cases, power supplies, and accessories, Kolink hardware is high quality usually with a stunning touch of RGB lighting. WWith their recent additions, the Unity and Observatory MX Series, it’s hard to not get heart eyes!
Feature Product: Kolink Void Rift ARGB PC Case
The Kolink Void ARGB PC Case is a mid-tower chassis with tempered glass panelling and a stunning infinity effect. So simple, yet so effective, ARGB lighting has been paired with an infinity mirror to create an endless reflection. More than just its looks, this case has support for vertical GPU mounting, ATX motherboards, and includes a Kolink Umbra Void 120mm PWM ARGB fan as standard. The carefully curated interior can accommodate a wide range of premium hardware, enabling you to build a phenomenal gaming PC within its frame.
Kolink Void Rift ARGB Mid-Tower Case
- Mid-tower gaming PC case
- Tempered glass panel
- Infinity mirror panel
- Vertical GPU support
- Up to ATX motherboard
Keep Calm and Kolink
From their cases to cables, Kolink products are great for using in your builds.
Ecstatic over Endgame Gear
Endgame Gear is all about unlocking your true gaming potential with high-end hardware. As gamers ourselves, it is certainly an ethos we can get behind. With their focus on esports, they have created an impressive range of FPS mice, premium mouse pads, and accessories to enhance performance.Branching out, they have also developed a studio-quality USB microphone, the XSTRM, and Hall Effect gaming keyboard, the KB65HE.
Feature Product: Endgame Gear XM1r Dark Reflex Gaming Mouse
The XM1r is a refresh of Endgame Gear’s massively popular XM1 gaming mouse. Equipped with a PixArt PAW3370 sensor, this mouse commands up to 19,000 CPI and 400 IPS tracking, making it incredibly sensitive. Even the smallest flick of the mouse will be expertly recreated on your screen. Utilising custom-sorted Kailh GM 8.0 switches, each main button is rated for 80 million clicks ensuring high durability with each mouse.
The Dark Frost, in particular, catches our eye because of its stunning, glossy finish. Its semi-transparent shell shows off some of the inner hardware whilst still having a sleek and neat aesthetic.
- PixArt PAW3370 sensor
- Semi-transparent shell
- Up to 19,000CPI
- Kailh GM 8.0 switches
- Durable flex cord
More Love for Endgame Gear
You want more Endgame Gear? We got it!
Loopy about Lian Li
Lian Li has been a staple of the gaming industry for quite some time now. In fact, they have been making PC cases since 1983 – nearly forty years! Always a pinnacle of high-end products, their O11D EVO was a modular masterpiece, putting all that experience to good use. More than just cases, they craft high-performance cooling hardware and case accessories to elevate your build. Plus, with many featuring dazzling RGB lighting, Lian Li can really light up your build!
Feature Product: Lian Li UNI SL120 INF ARGB Triple Fan Pack
Equip your gaming PC with Lian Li UNI SL120 INF fans, and you get a boost to cooling efficiency as well as an upgraded aesthetic. These 120mm fans each boast 40 ARGB LEDs and iconic infinity mirror effect lighting, which you can configure to create truly stunning displays with the included controller and software. Plus, with its daisy chain technology, you can control more fans from one place and reduce on cable clutter!
Onto its cooling prowess, the Lian Li UNI SL120 INF fans spin up to 2200 RPM and have a maximum airflow of 61.30 CFM. Paired with the maximum air pressure of 2.66mmH2O, these are incredibly efficient fans that more than enhance the natural flow of your chassis. In addition to this, they are manufactured from premium materials with vibration reduction properties, meaning they have great longevity. Stay cooler for longer with Lian Li.
Lian Li UNI SL120 INF ARGB 120mm Fan Triple Pack with Controller
- Three 120mm ARGB fans with infinity mirror effect
- Daisy chain technology
- 40 LEDs per fan
- Max speed 2200RPM
- Fan controller included
Like for More Lian Li
Lian Li graces many of our guides and features explained articles. With such high quality products, it’s hard not to!
Which is Your Go-To Gaming Brand?
Continue the love in the comments below, by sharing which gaming brand always gives you heart eyes!
