The 8Pack ABS MK2 has been upgraded and packs a bigger punch than ever before.
Still sporting the same moody good looks, the 8Pack ABS MK2 is equipped with the latest and greatest gaming hardware. It’s got a spec worthy of cartoony heart eyes, an ultra-efficient water-cooling loop, and enough power to bump it up from an Infin8 to an 8Pack PC.
From Infin8 to 8Pack
The original ABS, or “All Black System”, was part of the Infin8 range, inspired by the hench 8Pack builds and sporting their own iconic aesthetics, just without the 8Pack branding. Now as the 8Pack ABS MK2, this powerhouse PC has upped its game and even prominently features the 8Pack logo. We’ll just give you a second to admire this PC in all its glory.
8Pack ABS MK2 Specification |
ASUS ROG Maximus Z790 Dark Hero Motherboard |
Intel Core i9-14900K CPU (Overclocked) |
64GB DDR5 RAM at 6000MHz |
NVIDIA GeForce RTX 4090 GPU (Overclocked) |
WD Black SN8560X 2TB NVMe SSD |
Bespoke water-cooling |
ASUS ROG Strix 1200W ATX 3.0 PSU |
Fractal Design Define 7 PC case |
TLDR; Briony and 8Pack Talk ABS MK2
Briony caught up with Ian “8Pack” Parry to talk all things ABS MK2.
Get Some ABS
Now we get to talk about the fun stuff: the hardware! From motherboard to PSU, the 8Pack ABS MK2 is equipped with elite-tier components, carefully selected to provide cohesive and powerful performance. Starting with the Intel Core i9-14900K CPU, this bad boy boasts twenty-four cores, a blend of eight P- and sixteen E-cores, with thirty-two threads, all intelligently managed by Intel Thread Director. You know the right core is on the job! Of course, as an 8Pack PC, the processor has been given the magic 8Pack touch, fine-tuned utilising TVB to create two ratios.
Next up, we have the dual-channel 64GB DDR5 RAM at 6000MHz. Ultra-fast and efficient to all heck, you can enjoy speedy fetch rates and tight timings for sure. Plus, with the higher capacity RAM, the 8Pack ABS is going to be perfect for all your creative needs. Make complex 3D rendering or video editing a breeze!
The other powerhouse in the customised Fractal Design Define 7 PC case is, of course, the NVIDIA GeForce RTX 4090 GPU, overclocked naturally. Harnessing all that Ada Lovelace architecture has to offer, this titan-class graphics card will effortlessly elevate your gaming and streaming to 4K. Plus, with real-time ray tracing and AI-enhanced DLSS 3.5, you can enjoy realistic lighting and smooth frame rates for heightened immersion.
Naturally, you need somewhere for all your games, creative projects, and music files to go. The 8Pack ABS sports a WD Black SN850X NVMe SSD with 2TB of storage. Plenty of space for all your things with lightning-fast read and write times, to boot! Finally, the 1200W ATX 3.0 PSU with an 80 PLUS Platinum efficiency rating supplies all the power you need, with minimal wastage.
Cooling Power
It’s not an 8Pack PC until there is a high-performance water-cooling system turning the thermal solution into a work of art. Utilising a bespoke, high-performance water-cooling solution, the 8Pack ABS MK2 has a hard-tubing loop in a matte black finish paired with waterblocks and radiators. The end result, extreme efficiency and the perfect moody black aesthetic.
Custom ABS
Where the original ABS had a lightbox, the PSU shroud now sports iconic 8Pack branding – truly marking this as an 8Pack PC. Should you want to add on the lightbox or even bump RAM capacity up to a whopping 192GB, these are available customisation options. Call up our Prestige Systems Advisor on 01782 940193, and they’ll be able to talk you through customisation options to help make the 8Pack ABS MK2 the best PC for you.
Please note that any changes can affect the price and lead time.
8Pack ABS MK2 Ready
If your gaming set-up could use an eight-pack of abs, then you’ll be happy to know the 8Pack ABS Gaming PC is available from Overclockers UK, right now!
8Pack ABS MK2 Gaming PC
- All Black System
- Intel Core i9-14900K overclocked
- NVIDIA GeForce RTX 4090 GPU overclocked
- Configurable RAM
- Bespoke water-cooling
