The AMD Ryzen 7000 Series has been optimised for gaming and streaming alike, promising to deliver ultra-fast speeds and powerful performance. To fully utilise the incredible benefits offered by these processors, you need a reliable and efficient CPU cooler to match.
Thankfully, here at Overclockers UK, we’ve put together this list of the best CPU coolers for the AMD Ryzen 7000 Series.
The AMD Ryzen 7000 Series utilises cutting-edge Zen 4 architecture and a refined metal stack design to result in ultra-fast speeds and superior performance, that is perfect for both gaming and streaming. Every processor in the series comes equipped with an array of built-in features to optimise performance and streamline efficiency. This includes AMD RDNA 2, PCIe 5.0, DDR5 RAM, and AMD EXPO.
Listed below are all the processors currently available in the series, including the X3D range.
- AMD Ryzen 5 7600X
- AMD Ryzen 7 7700X
- AMD Ryzen 9 7900X
- AMD Ryzen 9 7950X
- AMD Ryzen 5 7600
- AMD Ryzen 7 7700
- AMD Ryzen 9 7900
- AMD Ryzen 7 7800X3D
- AMD Ryzen 9 7900X3D
- AMD Ryzen 9 7950X3D
You can read more about each of the CPUs in the series, along with all the hardware you need to upgrade, in our dedicated AMD Ryzen 7000 Series guide.
The Cooling Requirements of the AMD Ryzen 7000 Series
Hefty performance requires ample cooling. The more advanced your chosen processor is, the higher the TDP will be. TDP stands for ‘Thermal Design Power’ and refers to the maximum amount of heat generated.
You can see the TDP of each of the desktop processors in the table below.
Processor | TDP |
Ryzen 5 7600X | 105W |
Ryzen 5 7600 | 65W |
Ryzen 7700X | 105W |
Ryzen 7 7700 | 105W |
Ryzen 9 7900X | 170W |
Ryzen 9 7900 | 65W |
Ryzen 9 7950X | 170W |
Ryzen 9 7950X3D | 120W |
Ryzen 9 7900X3D | 120W |
Ryzen 7 7800X3D | 120W |
As you can see it ranges between the various CPUs, starting from 65W to 120W. Retail processors with a 65W TDP will come equipped with a default cooler in the box, which should be plenty, especially if you are using it for work, casual gaming, or internet browsing. However, for more power-hungry applications and advanced processors, such as the 3D V-Cache series, you’ll need to have a reliable and efficient cooler that can keep it performing at optimum temperatures.
In addition to this, you also need to ensure it is compatible with the all-new AM5 socket.
Air vs Water Cooling
There are hundreds of different cooling options for the AMD Ryzen 7000 Series, ranging from air CPU coolers, AiOs, to complete water-cooling systems. What you choose all depends on your individual preferences and needs.
If you are using your PC for light gaming, internet browsing, or watching YouTube, you won’t need a hefty custom water-cooling system. An air CPU cooler will be plenty. However, if you’re looking to enjoy the latest AAA titles, want to start streaming, or run more intensive applications, you will need powerful cooling in the form of an AiO or custom water-cooled loop.
If you’re unsure of whether air or water cooling is the right choice for you, take a look at our dedicated blog articles.
Our Favourite CPU Coolers
On the hunt for the perfect CPU cooler to pair with your AMD Ryzen 7000 Series CPU? You can find plenty of high-quality compatible coolers at Overclockers UK, packed with premium cooling and aesthetics, these CPU coolers are sure to look *chef’s kiss* within your gaming PC. We’ve picked out a few of our faves below, but you can also click the button to explore the full range of CPU coolers.
be quiet! Pure Rock 2 x FX Black aRGB 120mm Air CPU Cooler
- Air CPU cooler
- 120mm fan
- Compatible with both Intel and AMD
- Supports AM5 socket
- 150W TDP cooling efficiency
- aRGB lighting
be quiet! Light Loop 240mm AiO aRGB CPU Cooler
- AiO CPU cooler
- 240mm radiator
- 2 x PWM high-speed fans
- Integrated ARGB lighting
- Compatible with AM5
Phanteks Glacier One 240D30 White 240mm AiO CPU Cooler
- AiO CPU cooler
- 2 x 120mm PWM fans
- aRGB lighting
Along with air or AiO CPU coolers, you can also opt to create your own water-cooling system. This will utilise a series of different components, such as water blocks, pumps and reservoirs. In addition to this, the water cooling will require a liquid coolant to draw away any excess heat from vital components.
EK Water Blocks EK-Quantum Velocity² dRGB CPU Water Block
- CPU water block
- dRGB lighting
Have You Upgraded to the AMD Ryzen 7000 Series?
Have you upgraded to the new 7000 Series? Be sure to let us know in the comments below, along with what CPU cooler you’ve opted for and why.
