Streaming is a hot topic. As tech gets better and better, this venture becomes more accessible to everyone. Therefore, we need to answer one important question: What are the best gaming PCs and streaming hardware?
Streaming is a topic we’ve looked into a lot – there’s a nifty list of articles at the bottom to prove that. Today, we’re looking at some of the best gaming PCs and hardware available at Overclockers UK which have been primed for streaming. For any budding streamers, this is going to be a great starting point. There’s something for veterans too – perhaps you are in the market for an upgrade? Whatever brings you to this article, grab a cuppa and relax as we talk you through the best streaming hardware.
Gaming PCs
We’ll start with the gaming PCs. You can’t stream without one! We’ve picked out three faves here, but you can explore our dedicated Streaming PC collection for more inspo if you need it.
OcUK Gaming Khopesh Custom PC
The OcUK Gaming Khopesh is a configurable gaming PC. This means you can adjust the base spec from the selection of options – all to meet your needs. As standard the specifications look like this:
Specification |
AMD Ryzen 7 7700X CPU |
NVIDIA GeForce RTX 4070 Ti Super GPU |
Up to 64GB DDR5 RAM |
WD Black SN770 1TB SSD |
Optional add-on SSDs |
1000W 80 PLUS Gold Rated PSU |
Windows 11 |
With the AMD Ryzen 7 7700X CPU and NVIDIA GeForce RTX 4070 Ti Super GPU, you have plenty of computing power to stream and run most games at a decent FPS. If you’d like a touch more oomph from your processor, you have the option to upgrade up to the Ryzen 7 7800X3D or Ryzen 7 9800X3D with 3D V-Cache. As standard, the Khopesh has one storage drive, which you can upgrade up to 8TB. In addition to this, you can install up to two more high-speed SSDs. We definitely recommend opting for at least a second drive, so you can keep your gaming library on the one and all your media files on the other.
Finally, if your gaming PC is going to be on-screen at all, there are a number of beautiful cases to select from to really showcase the Khopesh. From classic black with the Kolink Observatory Y to a sleek iridescent APNX Creator C1!
Please note that any changes may occur additional costs.
Refract Gaming Indigo Pre-Built PC
The Refract Indigo was literally built to stream. As part of our Refract Gaming range, this purple PC is equipped with elite-tier hardware and was crafted to handle AAA gaming, content creation, and high-quality streaming. Here’s a quick look at the specs:
Specifications |
AMD Ryzen 9 9700X3D CPU with 3D V-Cache |
NVIDIA GeForce RTX 4080 Super GPU |
32GB (2 x 16GB) DDR5 RAM |
High speed storage |
1000W 80 Plus Gold Power Supply |
Windows 11 |
The AMD Ryzen 9 7800X3D CPU paired with the NVIDIA RTX 4080 Super GPU provides the perfect foundation for rendering your games and encoding them for live stream. Plus, with lightning-fast SSD storage and 32GB DDR5 RAM, this PC runs with incredible efficiency and speed. When you’re not streaming, the Indigo is primed for 1440p and 4K gaming. Master your skills in flawless quality, to really impress your audience on the next live stream!
What’s more, all our Refract Gaming PCs are pre-built and eligible for next-day delivery (when in stock), as well as being covered by our three-year parts and labour warranty. Peace of mind and getting you gaming all the quicker – tasty!
OcUK Gaming Osprey Custom PC
The OcUK Gaming Osprey is another of our configurable gaming PCs, offering you the best of AMD hardware to optimise your gaming.
Specifications |
Phanteks Eclipse G500A D-RGB Mid-tower PC case |
AMD Radeon RX 7900 XT GPU |
850W 80 PLUS Gold PSU |
Windows 11 |
With the OcUK Gaming Osprey, you have gaming-focused hardware that will deftly handle the demands of your favourite games and live streaming. 32GB of DDR5 RAM, an AMD Ryzen 7 7700X CPU, and AMD Radeon RX 7900 XT GPU – it reads like a recipe for the perfect streaming PC. Even better, you have configurable options, too. Increase that RAM capacity, upgrade to a Ryzen 9000 Series CPU, and even add extra storage drives. There are no wrong answers here.
You can perfectly tailor the OcUK Gaming Osprey to suit your streaming style.
Peripherals
When it comes to peripherals, what matters most is that they suit your preferences and gameplay styles. What we’ve picked here today are components that are going to boost your in-game performance and look great on screen. You’ll see why in just a sec.
Elgato Green Screen Mouse Mat
Ever thought about levelling up your stream with a mouse cam? Have a dedicated camera for your mouse and keyboard. With the Elgato Green Screen Mouse Mat, you can even set one up with a green screen background. Add effects or remove the background entirely – whatever your stream needs, this mouse mat can facilitate.
Specification |
400mm x 950mm x 3mm |
Cloth surface |
Chroma key green |
Anti-slip rubber base |
Low profile for comfort |
In addition to upgrading your on-screen display, the Elgato Green Screen Mouse Mat is a high-performance gaming surface. The top is a smooth cloth ensures your mouse will glide effortlessly across. With its 400mm by 950mm surface, you’ll even have plenty of space for all your fancy manoeuvres. Plus, the anti-slip rubber base prevents any unwanted movement and cinching.
Everything you want from a mousepad with the added green screen bonus!
Varmilo VEA109 Moonlight 110% Gaming Keyboard
If you are adding a desk cam, you need peripherals that make a statement as well as perform well for your games. We think the Varmillo VEA109 Moonlight Mechanical Keyboard does just that.
Specification |
110% mechanical keyboard |
Cherry MX Red switches (linear) |
V-silk PBT keycaps |
Gey and blue keycaps |
UK ISO layout |
Wired USB connectivity |
The Varmillo VEA109 Moonlight marries amazing style and top performance beautifully. Its 110% form factor means this keyboard has the full quota of keys, while the stunning colour scheme will look fab on camera. The black frame serves as the perfect canvas for a blend of grey keycaps with notable blue accents on the ESC, Enter, and Spacebar. Subtle, yet iconic.
Plus, this model utilises fast, linear Cherry MX Red switches, which are great for FPS games.
Endgame Gear XM2 8K White Frost Optical Gaming Mouse
Completing this peripheral trifecta is the Endgame Gear XM2 8K Gaming Mouse. With its stunning White Frost shell and vivid RGB lighting, this gaming mouse is going to look amazing on camera. Plus, it has the tech to support your gaming too!
Specifications |
Right-handed gaming mouse |
PixArt PMW3395 optical sensor with up to 26K CPI |
8K polling rate for minimal latency |
Wired USB Type A connectivity |
Hybrid skate design |
650 IPS max speed |
Armed with a PixArt PMW3395 optical sensor, the Endgame Gear XM2 8K is incredibly accurate, capable of tracking at 650IPS with an up to 26,000 CPI resolution. What’s more, it has an 8,000Hz polling rate for incredibly low latency. The left and right clicks are equipped with premium-quality Kailh GM 2.0 switches, which have been rated for 20 million actuations.
The Endgame Gear XM2 8K is a mouse that’ll stay by your side throughout your streaming career!
As we said before, preference plays a key role in which peripheral you pick. Tactile vs linear switches, wired or wireless, to RGB or not to RGB – these are the questions. Should our top picks here not tick your boxes, then we have extensive ranges for you to explore.
Streaming Hardware
Naturally, we can’t recommend the best hardware for streaming without giving you some for actual streaming hardware! Our collection of streaming hardware is ever-growing. If our top picks today don’t fit your set-up, the full range is waiting to be explored!
Streamplify CAM FHD Webcam
The Streamplify CAM has been engineered for those just dipping their toes into the streaming world. It can be intimidating figuring out everything that you need. A camera is a must, and Streamplify’s core tenant is making their hardware accessible and easy to use.
Specification |
FHD camera |
Captures at 60FPS |
Auto-focus features |
All-glass lens |
This nifty little camera has a FHD resolution and can record up to 60FPS. The all-glass lens has auto-focus capabilities, and the CAM will even auto-adjust in natural lighting, meaning you will always look your best. What’s more, there are dual stereo microphones to capture audio – negating the need for a dedicated microphone if your budget is tight. (Though, we recommend getting one, even if it is eventually).
Twitch will always catch your best side with this camera.
Elgato USB Customisable Stream Deck
If you’ve been streaming for a while but really want to streamline your production, then the Elgato USB Customisable Stream Deck is for you. Available in 6, 15, and 32-key models, you can choose the upgrade that will best suit you.
Specifications |
6, 15, or 32 LCD key models |
Fully customisable |
Compatible with major streaming software |
Assign single or multiple actions |
USB connectivity |
The Elgato Stream Deck allows you to assign functions, shortcuts, and controls to the LCD keys. With direct integration for popular streaming software, key folders for unlimited actions, and even multiple actions simultaneously or sequentially, you have the option for absolute control at your fingertips. Plus, set-up couldn’t be easier; simply drag and drop actions onto the keys via the app! Even the LCD keys can be customised with icons to denote function or your own branding.
The possibilities are endless.
Endgame Gear XTRSM USB Microphone
As mentioned before, your streaming set-up should include a microphone. Integrated audio on a webcam is great, but nothing beats the real thing. The Endgame Gear XSTRM USB Microphone brings high-fidelity audio and incredible style to the table.
Specifications |
USB microphone |
AI noise cancellation |
Shock mount and pop filter included |
Stylish RGB lighting |
Integrated media control |
Goldplated condensers |
This microphone has been primed for streaming, from its integrated controls to 192kHz sampling rate. With added AI noise cancellation, you can rest assured that your stream won’t pick up on any unwanted noises, like keyboard clacks. Plus, the included shock mount and pop filter will keep your audio free of pesky plosives and knock noises.
What’s more, there is a matching arm mount for the Endgame Gear XSTRM, should you need the flexibility they provide in your set up.
Elgato Game Capture 4K60 Pro Capture Card
Whilst you don’t need a capture card to stream, if you are wanting to record your streaming or game from a console, then it becomes a must-have component. This is where the Elgato Game Capture 4K60 Pro Capture Card comes in.
Specifications |
PCIe capture card |
Records video in 4K at 60 FPS |
Delay free audio |
HDMI pass-through |
Plug and play – no drivers required |
The Elgato Game Capture 4K60 Pro connects to your gaming PC via PCIe with external HDMI ports for easy access and recording. Games can be recorded at up to 60FPS on 4K resolutions in real-time, thanks to HDMI pass-through. Plus, there is amazing integration with streaming programmes, like OBS and XSPlit, and even support for multi-feed capture.
Additionally, the sleek black design makes this a stylish addition to your gaming PC.
Gaming Chairs
Streaming sessions often involve long stints gaming on your computer. It is imperative you have a proper gaming chair to provide suitable support for your back. Something to also consider is the aesthetic and how this gaming chair will look on camera. We have a great range of beautiful gaming chairs, but we’ve picked out a few that we think are the best gaming chairs for streaming.
Nitro Concepts X1000 Gaming Chair – Black/Blue
The Nitro Concepts X1000 Gaming Chair is a classic esports chair and the Black/Blue is our favourite for its vibrant pop of colour.
Specifications |
Breathable fabric gaming chair |
Supportive cold foam padding |
Up to 125-degree recline |
14-degree tilt rocker |
Adjustable 3D armrests |
60mm casters |
With its breathable fabric cover and cold foam padding, the Nitro Concepts X1000 will keep you well supported throughout your streaming session. From the first hellos to signing off, you will stay comfortable. What’s more, with adjustable ergonomics, such as 3D armrests and up to a 125-degree recline, you can configure this chair to meet your exact needs. There are even two pillows included with the chair – a neck and lumbar cushion for enhanced support.
What’s more, the Nitro Concepts X1000 is equipped with a Safety Class 4 gas lift, that has 10cm of height adjustment. This can also support up to 135kg in weight.
ThundeX3 TC5 Gaming Chair Black/Red
The ThunderX3 line-up is chock-full of esports-inspired gaming furniture. We like the TC5 in black and red for the stylish coloured edges and accents, which will really pop on camera. This is also a great chair for those streaming on a lower budget, as it provides excellent ergonomic features at a lower price point.
Specifications |
AIR tech fabric cover |
High-density foam padding |
3D armrests |
Butterfly mechanism |
Supports weights up to 150kg |
65mm casters |
First of all, the ThunderX3 EC1 is equipped with their innovative AIR Tech fabric. The pinhole surface provides enhanced breathability, keeping you comfortable throughout long streaming sessions. High-density foam is used for padding, which moulds to your shape to provide full body support. Additionally, the contoured backrest will enhance this effect as well as help to improve your posture.
The ThunderX3 EC1 has fixed armrests, but they have a wide surface with cushioning to create additional support for your arms. Plus, their smooth curves add to the stylish, sleek aesthetic of this gaming chair.
noblechairs LEGEND Starfield Edition
Of course, if you want your gaming chair to be a combination of comfort and making a statement, then you can’t go wrong with a Special Edition noblechairs. A bold and heroic selection would be the noblechairs LEGEND Starfield Edition.
Specifications |
PU leather and high-tech vinyl upholstery |
Officially licenced Bethesda design |
Dense cold foam padding |
4D armrests |
Adjustable lumbar support |
Recline up to 125-degrees |
This gaming chair has it all. Breathable PU leather and high-tech vinyl cover, dense cold form padding for enhanced support, stainless steel frame that provides incredible stability and durability, 4D armrests, adjustable ergonomics… The list truly goes on. The star feature, however, is the officially licenced Starfield design.
The noblechairs LEGEND Starfield Edition emulates star maps, subtle stitching on a white and black canvas. The backrest even includes the colourful constellation logo, such iconic imagery for this space RPG.
There are noblechairs and Starfield branding both sides, for that extra touch of luxury.
Custom Printed noblechairs Gaming Chair
Ok, so maybe I pulled out the statement argument too early – because what makes more of a statement than your own branding? That’s right, we offer custom printing on select noblechairs models. Personalise your play!
EPIC | HERO | ICON |
Headrest: 130mm x 90mm | Headrest: 200mm x 100mm | Headrest: 170mm x 150mm |
Backrest: 360mm x 330mm | Backrest: 360mm x 550mm | Backrest: 320mm x 400mm |
These measurements are width x height.
Not available on Special Edition, EPIC COMPACT, or TX models.
This service is available on three noblechairs models – HERO, EPIC, and ICON – offering you plenty of canvas choices. PU leather, high-tech vinyl, or real leather. Black, white, Java, or those with coloured stitches. Whichever gaming chair best suits your style or ergonomic needs, we can add your design. Plus, there are options for where we place your artwork. You can opt for just the headrest, the main body of the backrest, or both!
There are a few stipulations. Pesky copyright laws need to be upheld and vector files are preferable, though we do now accept all image files. Why vector files? Well, they are easier for our program to read and can be scaled without distorting the image. They also need to be presented in a CYMK colour model, as that is what our printer operates on. Otherwise, your beautiful design may not turn out the way you want.
Full details can be found either on the product pages, linked above, or our dedicated blog article. For now, just ogle how amazing these chairs look and start thinking about how your design would look on there.
Serious About Streaming?
If you’re serious about starting streaming, we have a number of streaming guides, tips, and hardware recs for you to peruse.
Share Your Streaming Set-Up
What are your go-tos and must-haves for streaming? Let us know in the comments below!
PC specs are subject to change.
