Do you want to level up your gaming performance but have a strict budget? Here at Overclockers UK, we’ve put together this series showcasing the best gaming PC and hardware you can get for your money.
In this blog post, we’re highlighting the top gaming PC and peripherals you can purchase for under £1000.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/PC-Hardware-Under-1000-1024x1024.png)
OcUK Gaming Mach 1 Pre-Built PC
The OcUK Gaming Mach 1 has been expertly built and tested by the OcUK team to facilitate incredible 1080p gaming. Armed with an AMD Ryzen 5 5600 CPU, unlock ultra-fast processing and seamless multitasking across all your single- and multi-threaded workloads. 16GB of DDR4 RAM ensures minimal latency or input lag while the NVIDIA RTX 4060 will render your gaming worlds in glorious detail, complete with lifelike lighting and shadows. Plus, with a 1TB SSD, you’ll have plenty of storage space for your expanding gaming library and more.
![OcUK Gaming Mach 1 - Ryzen 5600, RTX 4060 Pre-Built Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/Overclockers_Mach_1_hero_blue-300x300.jpg)
- Pre-built gaming PC
- Optimised for 1080p resolutions
- AMD Ryzen 5 5600 CPU and NVIDIA RTX 4060
- Up to 16GB DDR4 RAM
- 1TB M.2 SSD
Asrock CL27FF 27” Gaming Monitor
Enjoy crystal-clear gaming with the Asrock CL27FF 27” Gaming Monitor, thanks to its display resolution of 1920 x 1080 and refresh rates of up to 100Hz. With the built-in 1ms response times and support for AMD FreeSync. unlock a competitive in-game edge in all the latest fast-paced games. Plus the smooth refresh rates, zero screen tearing, sharp visuals, and adaptative lighting deliver an enhanced gaming experience.
- 27” gaming monitor
- 1920 x 1080 resolution
- 100Hz refresh rate
- 1ms response time
- IPS panel
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/AsRock-CL27FF.png)
ASUS U2000 Keyboard and Mouse Bundle
The ASUS U2000 Keyboard and Mouse Bundle comes equipped with everything you need to smash your workloads and defeat your enemies. The U2000 keyboard boasts low-profile uniform keycaps and whisper-quiet switches for a near-silent, yet smooth typing experience. With customisable functionality, you can configure several keys to feature on-the-fly macros to optimise your in-game performance and productivity.
What’s more, the U2000 mouse features an ergonomic design to reduce excess strain on your hands and wrist, ensuring you stay comfortable during your intense boss battles. The optical sensor and adjustable DPI of up to 1000 delivers pixel-precise control over all your mouse movements.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/01/ASUS-U2000-Bundle-300x138.jpg)
- Wired gaming bundle
- Includes a U2000 keyboard and U2000 mouse
- USB connectivity
- Plug-and-Play compatible
ASUS ROG Strix GO Core Moonlight White Gaming Headset
Immerse yourself in all your favourite gaming soundscapes with the ASUS ROG Strix GO Core Moonlight Gaming Headset. Powered by ASUS Essence 40mm drivers, enjoy rich deep audio which is enhanced further thanks to 7.1 surround sound support. You’ll hear every second of the action as it happens around you for that all-important edge in-game. Its lightweight foldable design makes this headset perfect for on-the-go listening and ensures you stay comfortable during those long hours of gaming. Plus, this headset is compatible with a huge range of platforms, including PC, mobile, PlayStation 5, XBOX Series X/S, and Nintendo Switch.
- Wired gaming headset
- ASUS Essence 40mm drivers
- Support for 7.1 surround sound
- Foldable design
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/12/ASUSROGStrix-Headset-290x300.jpg)
OcUK Mega Mat Medium Gaming Surface
Protect your desk with this OcUK elite gaming mouse pad. The OcUK Mega Mat Elite Mouse Pad has been constructed from a woven fibre that provides you with a smooth surface to glide across with ease. Plus, thanks to the rubberised base, this mouse mat grips your desk and won’t easily cinch or move around during those intense boss battles. Lastly, the high-quality stitched edges ensure durability session after session.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/03/ocuk-mega-mouse-mat-300x300.jpg)
- 352 x 255 x 3mm gaming surface
- Constructed from woven fibre
- Rubberised anti-slip base
- Stitched edges
Perfect for Any Budget!
Whilst this gaming PC and high-quality hardware comes to only £874.88*, OcUK stocks a wide range of products to suit any budget. Across all of our gaming PCs, monitors, peripherals, and more, you can make choices that won’t break your wallet!
PC Gaming on Any Budget!
*Please note that prices are subject to change and were correct at the time of writing.
