When it comes to mainstream gaming, the RTX 4060 really delivers. So, naturally, we figured we’d show off a few of an RTX 4060 gaming PC or two!
Boasting Ada Lovelace architecture, 3072 CUDA cores, 8GB GDDR6 VRAM, and a 115W TDP, the NVIDIA GeForce RTX 4060 is great for immersive gameplay whilst featuring an accessible price to performance point. An unsung king, really. Paired with the right hardware, you can enjoy some great 1080p gaming on a range of titles, from popular esports games to indie gems. We’ve picked out three RTX 4060 gaming PCs here today, to showcase their gaming acumen.
Refract Gaming Amber
Starting strong, we have the Refract Gaming Amber. This is a pre-built gaming PC primed for entry-level gameplay at 1080p. Helping out the RTX 4060, this PC features an AMD Ryzen 5 7500F CPU, 16GB DDR5 RAM, and a 1TB M.2 SSD, ensuring all your gameplay is optimised with minimal lag and speedy loading screens. As it is pre-built, the Amber is fully tested and ready to ship for easy plug-and-play installation!
Refract Amber Specification
Specification | |
Processor | AMD Ryzen 5 7500F Processor |
Graphics | NVIDIA GeForce RTX 4060 Graphics Card |
Memory | 16GB (2 x 8GB) DDR5 5600MHz AMD EXPO Dual-Channel Kit |
Storage | 1TB M.2 SSD |
Power Supply | 750W 80 Plus Gold Power Supply |
PC Case | Kolink Citadel Mesh RGB Micro-ATX Case (Black) |
If the RTX 4060 is not quite your speed, the full Refract range has been engineered to suit different playstyles and skill sets. Explore the full rainbow and find the one for you!
OcUK Gaming Carbide
The OcUK Gaming Carbide is part of a new range of pre-built PCs, inspired by the best-selling specifications from some of our configurable models. As such, it is well-equipped to handle your mainstream gaming needs and a variety of popular titles. The Carbide utilises an Intel Core i5-12400F CPU, 16GB DDR4 RAM, and a 1 TB M.2 SSD in conjunction with the NVIDIA GeForce RTX 4060 GPU. Plus, we can’t get enough of the smooth curves on the APNX C1 case!
OcUK Gaming Carbide Specification
Specification | |
Processor | Intel Core i5-12400F Processor |
Graphics | NVIDIA GeForce RTX 4060 8GB GPU |
Memory | 16GB (2 x 8GB) DDR4 3200MHz Dual-Channel Kit |
Storage | 1TB Gen4 M.2 Solid State Drive |
Power Supply | 700W 80 Plus Certified PSU |
PC Case | APNX Creator C1 Black Mid Tower |
Once you’ve picked out your dream PC, you need to make sure the rest of your gaming set-up is up to scratch. Check out our small office inspiration articles and see how you can boost your aesthetics!
OcUK Gaming Radiance Blazer
Our final pick is the OcUK Gaming Radiance Blazer. This PC is Powered by ASUS, meaning it is jam packed with premium ASUS hardware to take your gaming to new heights. In addition to the RTX 4060, this PC includes an AMD Ryzen 7 7600X CPU, 16GB DDR5 RAM, and a high-speed M.2 SSD for the primary storage. What sets the Radiance Blazer apart from the others on this list is the fact it is one of our configurable gaming PCs. You can pick and choose upgrades from a pre-selected list of hardware, so the spec better matches your requirements. Customise the PC case, memory, GPU, operating system, and add up to three SSDs. Just note that changes will affect the pricing.
OcUK Gaming Radiance Blazer Specification
Specification | |
Processor | AMD Ryzen 5 7600X CPU |
Graphics | ASUS GeForce RTX 4060 8GB GDDR6 Graphics Card *Options: RTX 4060 Ti upgrade |
Memory | 16GB DDR5 5200MHz Dual Channel Kit *Options: Up to 32GB DDR5 RAM |
Storage | WD 500GB M.2 PCIE Gen4 Solid State Drive 500GB 2.5″ SATA Solid State Drive *Options: Additional M.2 drive and a wide range of capacities up to 2TB |
Power Supply | 750W 80Plus Gold Rated PSU |
PC Case | Lian Li Lancool 205 Mesh C Mid-Tower *Options: A range of PC cases from Phanteks, Lian Li, and Kolink |
Configurable gaming PCs offer a great middle ground for the pre-built vs DIY debate. But is one truly better than the other?
More RTX 4060 Gaming PCs
Of course, this is just a small cross-section of our RTX 4060 gaming PCs. You can check out our dedicated RTX 4060 gaming PC category or explore the full range. With the customisable options, this GPU is available on more PCs than you might think!
More PC Inspo
We can talk about gaming PCs until the cows come home. If an RTX 4060 gaming PC is not your jam, then why not check out more of our articles?
What Spec Are You Looking For?
What hardware do you look for in a gaming PC? Let us know in the comments below and we might just make an article around it!
PC specs are subject to change.
