Stepping into the world of PC gaming doesn’t have to break your wallet! Whether you are thinking of treating yourself or a special someone, here at Overclockers UK we’ve put together this list of the best PC and hardware you can get for under £2000!
OcUK Gaming Mach 3 Pre-Built PC
Built by our team of experts, the OcUK Gaming Mach 3 comes packed with all the powerful hardware you need to enjoy playing your favourite games. Harness the AMD Ryzen 7 5700X3D CPU to enjoy ultra-fast processing speeds and next-level efficiency thanks to the intelligent 3D V-Cache. Up to 32GB of DDR4 RAM facilitates quick in-game loading times and near-zero latency, while the NVIDIA RTX 4070 Super will render your gaming adventures in incredible quality. Cutting-edge RT and Tensor cores deliver stunning lifelike visuals which are sure to immerse you in your virtual adventures. Plus, the 1TB M.2 SSD means you’ll never need to worry about running out of precious storage space.
- Pre-built gaming PC
- Optimised for 1440p resolutions
- AMD Ryzen 7 5700X3D CPU and NVIDIA RTX 4070 Super
- 32GB DDR4 RAM
- 1TB M.2 SSD
- Windows 11 Home included
Endgame Gear OP1 8K Optical Gaming Mouse
Engage in all-out warfare against your enemies with the Endgame Gear OP1 Gaming Mouse. The Pixart PAW3395 sensor and Kalih GX mechanical switches have been fine-tuned for maximum performance with no input lag. The customisable DPI of up to 19,000 and 8K polling rate delivers ultra-fast speeds and pixel-precise control over all your mouse movements. Plus, the hybrid skate design means this gaming mouse will effortlessly glide across any surface. You won’t have to worry about accidentally snagging during those critical boss battles!
- Optical gaming mouse
- Pixart PAW 3395 sensor
- Kalih GX mechanical sensors
- DPI of up to 19,000
- 8K polling rate
Endgame Gear KB65HE 65% Hall Effect Gaming Keyboard
The Endgame Gear KB65HE Hall Effect Keyboard features everything you need to dominate your in-game enemies. Intelligent Hall Effect and Rapid Trigger technology means that all your keypresses will be registered at incredible speeds, while the Gateron KS-37B key switches deliver silky-smooth keystrokes thanks to its actuation force of only 30gf. Premium double-shot PBT keycaps, arranged in a UK ISO layout, enhance this keyboard’s durability, ensuring it stays factory fresh for longer. Plus, the per-key RGB backlighting can be customised to perfectly suit your desired aesthetic.
- Hall effect gaming keyboard
- 65% form factor
- Gateron KS-37B key switches
- PBT double-shot keycaps
- UK ISO layout
- Customisable per-key RGB backlighting
ASUS TUF Gaming H3 Wireless Headset
Become immersed in all your favourite gaming soundscapes with the ASUS TUF Gaming H3 Headset. Thanks to the 7.1 surround sound and 50mm ASUS Essence drivers, enjoy the crystal-clear audio and true-to-life sound for a distinct advantage against your enemies. The included unidirectional microphone ensures your teammates will hear you perfectly, while the lightweight construction and on-ear fast cooling keeps you cool and comfortable, even during your extended hours of gameplay.
- Wireless gaming headset
- 2.4GHz or Bluetooth connectivity
- Premium 50mm ASUS Essence drivers and 7.1 surround sound
- Up to 15 hours of battery life
- Lightweight design
Glorious G-3XL Stealth Extended Gaming Mouse Mat
Keep your desk well-protected with the Glorious G-3XL Extended Mouse Mat. Optimised for optical gaming mice, you can effortlessly flick and glide your mouse across this surface without any accidental snags, creases, or slips. The anti-slip rubber base helps to support you in battle by keeping this mouse mat firmly in place on your desk. The stitched edges prevent any unwanted fraying for exceptional durability battle after battle.
- 914 x 457 x 3mm mouse mat
- Cloth surface
- Optimised for optical gaming mice
- Anti-slip rubber base
- Stitched edges
- All black
Take Your Battle Station to the Next Level!
Give your setup a much-needed upgrade by purchasing one of our incredible desks and gaming chairs. You can complete your setup with this desk and chair and still be under your £2000 budget!
Nitro Concepts D12 Gaming Desk
- Black gaming desk
- Sturdy steel construction with tabletop made from MDF
- Built-in headset and drink holders
- Cable grommets for easy cable management
- Stylish black and red design
Available to buy for £74.99*
Available to buy for £199.99*
ThunderX3 EAZE Loft Gaming Chair
- Light grey gaming chair
- Breathable fabric upholstery
- SYNC4 mechanism and integrated lumbar support
- Pocket on backrest
- Comes with two cushions
The Total Price
The total price for all this incredible hardware is… £1,903.91*! What a bargain.
All Your Budget Gaming Needs!
*Prices correct at time of writing and PC specs are subject to change.
