Are you looking for a cheeky upgrade to your PC set-up? Is your PC case looking a little worse for wear? If so, this is the blog series for you!
We’ve taking you on a guided tour through the wonderful world of PC cases, highlighting key models and their features. In this article we’re showing you all things RGB, detailing why you want a PC case that offers a vibrant splash of colour to your battle station.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/10/PC-Cases-with-RGB-1024x1024.png)
Kolink Observatory RGB Black PC Case
Effortlessly sleek and stylish, the Kolink Observatory is the ultimate choice for gamers looking for their next case upgrade. The interior of the chassis boasts ample space for up to E-ATX motherboards. GPUs up to 38cm long, and two 240mm radiators. Everything you need to create a truly show shopping PC! What’s more, the four pre-installed 120mm RGB fans facilitate incredible airflow, ensuring there is always a steady stream of natural air throughout the case. If the rainbow aesthetic isn’t quite your vibe, the included RGB controller allows you customise both the colour and effect to suit your style.
- Mid tower
- Tempered glass side and front panels
- Supports up to E-ATX motherboards
- GPU clearance of up to 380mm
- Four pre-installed 120mm RGB fans
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Kolink-Observatory-260x300.jpg)
Phanteks NV7 DRGB Full Tower Black PC Case
Showcase your gaming hardware with pride courtesy of the Phanteks NV7 Black PC Case. Compatible with up to E-ATX motherboards and GPUs of up to 450mm in length, you can install plenty of the latest cutting-edge hardware within this chassis. All you which you’ll be able to display like a work of art thanks to the front and side tempered glass panels. Included with this case are two RGB motherboard covers, designed to illuminate this component in vibrant RGB which you can easily configure with the bundled D-RGB controller.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Phanteks-NV7-264x300.png)
- Full tower
- Front and side tempered glass side panels
- GPU clearance of 450mm
- Integrated RGB motherboard covers
Kolink Unity Solar Mesh ARGB Mid Tower White PC Case
Elevate your set-up to new heights with the Kolink Unity Solar Mesh ARGB PC Case. This chassis is equipped with extensive support for a range of PC hardware, including E-ATX motherboards, vertical GPU support, and even a 360mm radiator. The four pre-installed ARGB 120mm fans will highlight all your powerful hardware in stunning colour, which you can marvel at with pride thanks to the tempered glass side panel.
- Mid tower
- Four pre-installed ARGB 120mm fans
- Half tempered glass side panel
- All white design
![Kolink Unity Solar ARGB Mesh PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/kolink-unity-solar-white-pc-case-300x300.jpg)
Fractal Design Pop Mini Black PC Case
Small, yet effortlessly stylish, the Fractal Design Pop Mini PC Case is the perfect space saving chassis. This PC case can accommodate powerful hardware from up to Micro-ATX motherboards, GPUs of 365mm long and a 240mm radiator. All of which will work in sync to render your favourite games like never before. The three pre-installed 120mm RGB fans ensure a consistent stream of natural flows throughout this case, whilst also facilitating plenty of vibrant colour. As a Mini PC case, this chassis will blend seamlessly into any office set-up, without taking up precious desk space.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/10/FractalDesign-Pop-Mini.jpg)
- Mini PC case
- Compatible with both Mini-ITX and Micro-ATX motherboards
- Tempered glass side panel
- Three pre-installed 120mm Aspect RGB fans
Kolink Big Chungus UNIT Edition ARGB Full Tower PC Case
Create a truly unique PC with the Kolink Big Chungus UNIT. This PC case is the ultimate show shopper, boasting tinted tempered glass panels, five pre-installed RGB fans, and two ARGB strips. All of which you can easily control and customise thanks to the included ARGB PWM controller to create a truly unique light show. Compatibility with E-ATX motherboards, 335mm long GPUs, and 360mm radiators, means you can utilise plenty of the latest gaming hardware including both the NVIDIA RTX 40 and AMD Radeon RX 7000 Series.
- Full tower PC case
- GPU clearance of up to 335mm
- Five pre-installed 120mm PWM RGB fans
- Two pre-installed ARGB strips
- Side, front, and lid tinted tempered glass panels.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/10/Kolink-BigChungus-UNIT-273x300.jpg)
All Things RGB
Your Favourite PC Case with RGB?
Do you have a top PC case rec that features RGB lighting? Share your case recommendations in the comments below.
