Are you in need of an upgrade to your PC set-up? Is your case looking a little worse for wear or perhaps it’s just not delivering the aesthetic you desire? Whatever the case – this is the blog post for you!
We’ve created this series to take you on a guided tour through the wonderful world of PC cases, highlighting key models and their features.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/11/PC-Cases-for-SFF-1024x1024.png)
In this blog article, we’re showcasing a selection of our favourite cases for small form factor builds, ideal for those who want to create a small yet powerful set-up.
Kolink Rocket V2 Aluminium Mini-ITX PC Case
Sleek and stylish, the Kolink Rocket V2 boasts a minimalist design and support for all the latest SFF-compatible hardware. Capable of housing Mini-ITX motherboards, SFX-L PSUs, and NVIDIA SFF GPUs, this PC case comes equipped with everything you need to create a powerful show-shopping PC without compromising on space. To ensure exceptional cooling, the Kolink Rocket V2 features ventilation holes on the side panel to enhance the natural flow of air through the interior to help maintain optimum temperatures. What’s more, built from durable aluminium and sports a titanium grey design, this PC case will effortlessly blend into your set-up.
Kolink Rocket V2
- Mini-ITX PC case – 150 x 270 x 350mm
- Supports up to Mini-ITX motherboards and SFX-L PSUs
- Compatible with NVIDIA SFF GPUs
- Ventilation holes for enhanced airflow
- Minimalist design
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/12/kolink_rocket_v2_front-1-300x300.jpeg)
Lian Li Q58W3 Tempered Glass White Mini-ITX PC Case
Elevate your set-up to new heights with the Lian Li Q58W3 Mini-ITX PC Case. This stylish modular chassis supports everything you need to create your next small form factor build, including compatibility with Mini-ITX motherboards, ATX PSUs*, and even vertical GPU mounting! The hinged panels grant you easy access to the interior of the case for seamless upgrades, while the flexible mounting solutions mean you can utilise a variety of thermal solutions such as AiO CPU coolers up to 67mm tall. Plus, the mesh panels and magnetic dust filters facilitate incredible airflow to draw and dissipate any unwanted excess heat.
*With included ATX PSU bracket.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/lian-li-q58w3-300x300.jpg)
Lian Li Q58W3
- Mini-ITX PC case – 342 x 170 x 250mm
- Compatible with ATX PSUs* (*with included ATX PSU bracket)
- Mesh panels and magnetic dust filters included
- Flexible mounting options for AiO cooling
- Supports vertical GPU mounting
Fractal Design Terra Silver Mini-ITX PC Case
Small, yet incredibly stylish, the Fractal Design Terra Silver Mini-ITX Case is the ultimate space saving chassis. The Terra has been designed to not compromise on hardware, space, or aesthetic boasting an anodised aluminium exterior combined with solid walnut for a stunning modern look that will look chef’s kiss on any desk. While it may be small, you can still utilise a wide variety of powerful hardware including Mini-ITX motherboards, SFX-L PSUs, and even NVIDIA SFF-Ready 40 Series GPUs. Plus, you’ll never need to worry about running out of precious storage thanks to the dedicated 2.5’’ drive mount which supports up to two SSDs.
- Mini-ITX PC case – 343 x 153 x 218mm
- Compatible with SFX-L PSUs
- GPU clearance of up to 32mm
- Compatible with NVIDIA SFF graphics cards
- PCIe 4.0 riser cable included
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/11/FractalDesign-Terra-Silver.jpg)
Phanteks Evolv Shift Air 2 Black Mini-ITX PC Case
Level up your SFF set-up with the Phanteks Evolv Shift Air 2 PC Case. Its unique ultra-vertical SFF form factor will save space whilst ensuring you can easily install all your must-have components. This includes Mini-ITX motherboards, SFX-L PSUs, and GPUs of up to 355mm. As your hardware is arranged vertically, the I/O ports can be found on the top of the case, however, a durable grill cover ensures your vital connectors are well protected. What’s more, the included D-RGB controller allows you to illuminate your hardware in vibrant colour.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/12/phanteks_evolv_shift_front-300x300.jpeg)
- Mini-ITX PC Case – 186 x 490 x 274mm
- GPU clearance of up to 355mm
- Sleek fabric mesh side panel
- Included D-RGB controller
SSUPD Meshlicious Tempered Glass White Mini-ITX PC Case
Despite its compact shape, the SSUPD Meshlicious White Mini-ITX Case ensures you don’t need to compromise on style or performance. Boasting support for Mini-ITX motherboards, ATX PSUs*, and GPUs of up to 315mm in length, you’ll be able to easily create a powerful PC capable of running all your favourite AAA games. To add a unique touch to the interior, you can choose to arrange your GPU either horizontally or vertically, thanks to the included PCIe 3.0 riser cable. The tempered glass panel allows you to display this with pride, while the three other mesh panels enhance airflow to help keep your hardware cool and performing at its best.
*Hardware depending.
- Mini-ITX PC Case – 245 x 166.4 x 360mm
- Compatible with Mini-ITX motherboards and ATX PSUs* (*hardware depending)
- GPU clearance of up to 315mm
- Three mesh and tempered glass side panels
- PCIe 3.0 riser cable included
- Supports up to seven 2.5’’ SSDs
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/SSUPD-Meshilicious-Mini-ITX-276x300.jpg)
Learn More About SFF Hardware
Your Favourite SFF PC Case?
Do you have a small form factor PC? What case did you opt for? Share your product recs in the comments below.
