Are you a veteran streamer or enthusiast gamer looking for your next gaming set up upgrade? Well, have we got the blog post for you!
We’ve put together this list of our best PC and hardware for enthusiasts, designed to help you achieve superior performance in your favourite AAA titles and creative projects.
This high-quality PC and all of this incredible hardware comes to £4,346.21* (including a pillow set).
Refract Gaming Indigo Pre-built PC:
Built by PC experts, the Refract Gaming Indigo has been fine-tuned for elite-tier gaming and high-quality streaming. Harness the AMD Ryzen 9 7900X3D CPU, with its hybrid core architecture, for powerful, seamless multitasking and workload management.. Equipped with up to 32GB of DDR5 RAM, enjoy ultra-fast loading times at up to 5600MHz, with near-zero input lag.  What’s more, the NVIDIA RTX 4080 has been built utilising Ada Lovelace architecture with support for both Real-Time Ray Tracing and AI DLSS, to render all of your favourite games in stunning hyper-realistic quality.
Refract Gaming Indigo 2023
Available for £2,899.99*
  • Pre-built gaming PC
  • Designed for elite-tier gaming and high-quality streaming
  • AMD Ryzen 9 7900X3D CPU
  • NVIDIA RTX 4080 GPU
  • Up to 32GB of DDR5 RAM
Glorious Model O Optical USB Gaming Mouse:
Effortlessly flick, click, and glide your way to victory with the Glorious Model O Gaming Mouse. Take advantage of the high-quality Pixart PMW 3360 sensor with a DPI of up to 12,000, for superior precision and control. All of your mouse movements will be registered at lightning-fast speeds thanks to the 1000Hz polling rate and 1ms response time. This is boosted further thanks to the low resistance feet, which will effortlessly glide across your desk or tabletop.
The finishing touches to this gaming mouse are the etched honeycomb design and integrated RGB lighting. Completely customisable, you can configure the RGB to suit your desired aesthetic for a synchronised light show.
Available for £49.99*
  • Optical gaming mouse
  • Pixart PMW 3360 sensor
  • DPI of up to 12,000
  • 1000MHz polling rate
  • 1ms response time
  • Honeycomb design
  • Integrated RGB lighting
Ducky ProjectD Tinker 65% Custom Barebone Gaming Keyboard:
Engineered for gaming enthusiasts, the Ducky ProjectD Tinker 65% Barebone Keyboard can be completely customised to suit your indiviual preferences. Built from premium-quality materials, featuring a hot-swappable PCB, you can freely choose from a huge selection of key switches to find the set that perfectly matches your playstyle. Thanks to its 65% form factor, this keyboard won’t take up any extra precious desk space, meaning you don’t have to compromise on performance or aesthetics.
Please note, as this is a barebones keyboard, you will need to purchase key switches and keycaps seperately.
Available for £66.29*
  • Custom barebone gaming keyboard
  • 65% form factor
  • Hot-swappable PCB
  • QMK/VIA enabled
  • Supports both ANSI and ISO layouts
Ducky Project D
Want to know more about Ducky ProjectD? Check out our dedicated blog post where we check out this new generation of keyboard in detail.
Endgame Gear MPJ-1200 3XL Black Gaming Surface:
Protect your desk and level up your gaming with the Endgame Gear MPJ-1200 3XL Gaming Surface. This micro-woven fabric gaming mousepad has been optimised for optical gaming mice to ensure superior precision and control. Whilst the anti-slip rubber base will keep it firmly in place, no matter how intense your gameplay gets.  Measuring a hefty 1200mm x 600mm x 3mm, it boasts a huge surface area to keep your desk or tabletop well protected from any accidental knocks or spills.
Available for £34.99*
  • XXL mouse pad
  • Micro-woven fabric surface
  • Optimised for optical gaming mice
  • Anti-slip rubber base
Corsair Virtuoso Wireless Gaming Headset:
Immerse yourself in your favourite gaming soundscapes with the Corsair Virtuoso Gaming Headset. Boasting 50mm custom neodymium drivers, enjoy crystal clear, high-definition audio, that is sure to prove advantageous during gameplay. What’s more, with a broadcast-grade omnidirectional microphone, your teammates will be able to hear your commands loud and clear. A must-have for those boss battles. Completely wireless, you won’t have to worry about any unnecessary cables cluttering up your desk or getting tangled. Instead, this headset utilises powerful Corsair Slipstream technology or Bluetooth for 48KHz connectivity.
Available for £199.99*
  • Wireless gaming headset
  • 50mm neodymium drivers
  • Corsair Slipstream Wireless technology
  • Broadcast-grade detachable microphone
  • Plush ear pads
ASUS TUF 27’’ VG27VQ Gaming Monitor:
The ASUS TUF VG27VQ Gaming Monitor is the perfect addition to any gaming set up. Take advantage of the 27’’ 1920 x 1080 display with 165Hz refresh rates, to enjoy silky-smooth frame rates with ultra-fast response times for an optimised, immersive gaming experience. This is boosted one step further, thanks to the array of built-in features. This includes intelligent ASUS Extreme Low Motion Blur (ELMB) and support for FreeSync Premium.
Available for £268.99*
  • Widescreen gaming monitor
  • 27”
  • 1920 x 1080 display
  • 1ms response time
  • 165Hz refresh rates
  • VA panel
  • Compatible with FreeSync Premium
noblechairs HERO Black Gaming Chair:
Level up your set up with a premium-quality gaming throne. The noblechairs HERO Gaming Chair has been built utilising PU leather with cold foam upholstery to keep you cool and comfortable, whilst retaining its natural shape, during extended hours of gameplay. What’s more, with adjustable lumbar support and 4D armrests, you can perfectly adjust this gaming chair to suit your individual preferences and needs. Plus, its sleek all-black design means it will fit effortlessly into your set up and aesthetic.
Available for £419.99*
  • Premium quality gaming chair
  • Constructed from PU leather with cold foam upholstery
  • Adjustable lumbar support
  • Memory foam headrest
  • 4D armrests
Complete your throne with a special edition memory foam pillow set, sporting your favourite Marvel, Star Wars, or video game franchise.
noblechairs Elder Scrolls Online Special Edition Pillow Set:
noblechairs Memory Foam Pillow Set The Elder Scrolls Online Edition
Available for £55.99*
  • Special Elder Scrolls Online edition pillow set
  • Memory foam
  • Neck and lumbar support
  • Machine washable
noblechairs Boba Fett Special Edition Pillow Set:
  • Special Boba Fett edition pillow set
  • Memory foam
  • Machine washable
ThunderX3 ED7 Adjustable Gaming Desk:
All of this great tech needs a home and the ThunderX3 ED7 Adjustable Gaming Desk is the perfect choice. Constructed from a combination of powder-coated steel and durable particleboard, this desk is capable of holding up to 50kg – perfect for your gaming PC, monitor, and all your must-have peripherals. Included with this desk is a mouse pad, that has been optimised for all mouse types.  In addition to all of this, this desk is sit/stand and features an adjustable electric motor. The digital control panel is situated on the front of the desk for easy access, whether you are sitting or standing.
Available for £349.99*
  • Gaming desk
  • Sit/stand
  • Built from powder-coated steel and durable particleboard
  • Hold up to 50kg
  • Includes a mouse pad
Designed to Suit Any Budget!
We’ve got a fantastic line of in-depth articles, showcasing some of the best PC and hardware, for a range of budgets.
*Prices are subject to change and were correct at the time of writing.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
