This Pi Day, we’ve decided to take a closer look at our incredible line of workstations and powerhouse PCs.
![The Best PCs for Working with Pi](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/230313-The-Best-PCs-for-Working-With-Pi-1024x1024.jpg)
A powerful PC can be designed for much more than high-speed AAA gaming. Our configurable workstations and powerhouse PCs have been crafted utilising cherry-picked hardware, primed for creative and intensive workloads. This includes 3D rendering, simulations, AI modelling, and much more.
Today, we’ll be highlighting a few of our favourites, along with showing you how you can build the workstation of your dreams to enhance your productivity and workflow.
8Pack Hypercube MK2 Extreme Overclocked PC:
The 8Pack Hypercube has received a much-needed upgrade. Now equipped with all of the latest and greatest hardware, this extreme PC has been redesigned for AAA gaming and high-intensity workloads. Armed with an AMD Ryzen 9 7950X CPU, with a pre-configured overclock, unlock unrivalled performance and exceptionally fast speeds. The CPU is equipped with two overclocked profiles, that will automatically switch depending on the task. This ensures maximum performance with efficient temperatures, at up to 5.9GHz! What’s more, with the flagship RTX 4090 GPU, achieve hyper-realistic visuals with enhanced Ray Tracing and AI DLSS 3 capabilities. A must-have for 3D image rendering, AI modelling, and more at up to 4K resolutions.
To ensure these vital components remain cool and quiet, the 8Pack Hypercube MK2 features a custom water-cooling system. Built utilising high-quality hardware from EK Water Blocks, this thermal solution has been designed to maintain optimum temperatures and keep this system whisper-quiet. Plus, to perfectly match the Hypercube’s sleek purple, blue, and black aesthetic, running throughout the hard tubing is a stunning mix of blue liquid coolant.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/8Pack-HypercubeMK2-292x300.jpg)
- Designed by 8Pack
- Includes an AMD Ryzen 9 7950X CPU and NVIDIA RTX 4090, both with pre-configured overclocks
- Up to 32GB DDR5 RAM
- Custom water-cooling loop
- 2 x 2TB M.2 SSDs
- Integrated RGB lighting
8Pack Orion X2 Extreme Overclocked PC:
Designed by legendary overclocker, the 8Pack Orion X2 packs in two extreme overclocked PCs into one!
Engineered utilising only the very best cherry-picked hardware, the primary system includes an Intel Core i9 10980XE CPU with a pre-configured overclock, along with two NVIDIA RTX 3090 GPUs. Whilst the secondary system is armed with an Intel Core i7 10700K CPU and an NVIDIA RTX 3090. All of which combined, results in blisteringly-fast performance in a vast range of intensive applications, including 3D image rendering, video editing, and more! What’s more, with both 128GB and 32GB of DDR4 RAM, wave goodbye to pesky slow loading times and enjoy smooth performance with near-zero latency. Plus, there are multiple hefty storage drives, including two 14TB hard drives, and several SSDs. You will have all the storage space you need and more, for your creative projects.
Keeping all of this incredible hardware cool and quiet is the comprehensive water-cooling loop. Built with high-quality hardware from the likes of EK Water Blocks, this thermal solution will keep all of the core components performing at optimum temperatures, no matter how intensive your workload gets.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/8Pack-OrionX2-286x300.jpg)
- Designed by 8Pack
- Dual-system PC
- Primary system features an Intel i9 10980XE CPU, with a pre-configured overclock, and two NVIDIA RTX 3090 GPUs
- Secondary system includes an Intel i7 10700K CPU and an NVIDIA RTX 3090
- 128GB and 32GB of DDR4 RAM
8Pack Supernova MK2 Extreme Overclocked PC:
The 8Pack Supernova MK2 is a flexible powerhouse PC, that is perfect for both work and play! This PC comes packed with an AMD Ryzen Threadripper 7980X CPU that has been fine-tuned to reach speeds of up to 4.7GHz for exceptional performance. Plus, with the choice of one or two pre-overclocked NVIDIA RTX 4090 GPUs, unlock hyper-realistic visuals with silky-smooth frame rates at up to 4K resolutions. Armed with up to 256GB of DDR4 octo-channel RAM, the memory capacity is spread over eight different channels for ultra-fast loading speeds. What’s more, with three SSDs and two HDDs, you will have a maximum storage space of 36TB. Do we need to say any more?
To maintain optimum temperatures, not only does this powerhouse feature a custom water-looping loop, there is also a dedicated VRM thermal solution. Both of these combined, effectively draw and dissipate heat away from vital components to prevent overheating and throttling.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/8Pack-SupernovaMK2-300x281.jpg)
- Designed by 8Pack
- Includes an AMD Ryzen Threadripper 7980X and either one or two NVIDIA RTX 4090 GPUs
- Pre-configured overclocks
- 256GB of DDR4 RAM
- 36TB storage space
Build Your Dream Workstation:
If you don’t want to opt for a configurable workstation, you can also choose to build your own PC. This allows you to specifically create the PC of your dreams, that perfectly matches the demands of your workload and individual preferences.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/Pexels-BuildingPC-1024x683.jpeg)
Case:
For a powerful workstation, we recommend you opt for a full tower case that supports dual-system configurations. This enables you to pack in the power of two PCs into one system to achieve cutting-edge performance, ultra-fast speeds, and enhanced visuals. All of which is a must for image rendering, video editing, and more!
Lian Li V3000 Plus Full Tower PC Case:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/LianLi-V3000-290x300.jpg)
- Full tower
- Supports dual system configurations
- Compatible with up to E-ATX motherboards
- GPU clearance of up to 589mm
- Support for up to sixteen fans!
- Tempered glass side panels
- Integrated RGB strip
Phanteks Enthoo 719 Full Tower DRGB PC Case:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Phanteks-Enthoo719-284x300.jpg)
- Full tower
- Supports single and dual system configurations
- GPU clearance of up to 503mm
- Vertical GPU support
- Tempered glass side doors
- Integrated RGB light strip
CPU:
AMD’s Ryzen Threadripper processors have been engineered with 7nm Zen architecture and feature high clock frequencies to deliver superior performance in single- and multi-threaded applications with blisteringly-fast speeds.
AMD Ryzen Threadripper Pro 24 Core / 48 Thread 5965W CPU:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/AMD-Threadripper-300x300.jpg)
- 24 cores & 48 threads
- 3.8GHz base clock
- 4.5GHz boost clock
- 280W TDP
AMD Ryzen Threadripper Pro 64 Core/128 Thread 5995WX CPU:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/AMD-Threadripper-1-300x300.jpg)
- 64 cores & 128 threads
- 2.7GHz base clock
- 280W TDP
Motherboard:
If you are planning on utilising an AMD Ryzen Threadripper CPU, you will need a compatible motherboard with a compatible sTR5 socket. Built with intelligent power phase designs, these motherboards ensure a reliable and steady flow of power, providing it with additional power when you need it most. Plus, with onboard cooling, no matter how intensive your workload gets, this will ensure your hefty CPU is kept cool and quiet.
AsRock TRX50 sTR5 Quad Channel E-ATX Motherboard:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Asrock-TRX50-300x294.jpg)
- E-ATX motherboard
- Compatible with Threadripper Pro and 7000 Series
- sTR5 socket
- Wi-Fi6E
- PCIe Gen 5.0
Graphics Card:
A powerful graphics card is a must-have for all your intensive workloads. Therefore, we would recommend either an AMD Radeon Pro GPU or the latest RTX 40 Series, such as the RTX 4090.
Both the AMD Radeon Pro W6800 and RTX 4090 have been optimised for high-intensity applications, with fast clock speeds, GDDR6 video memory, and hefty CUDA cores. All of which deliver superior performance in image rendering, AI modelling, and much more.
AMD Radeon Pro W6800 Graphics Card:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/AMDRadeonPro-W6800-300x224.jpg)
- Professional GPU
- Optimised for creative workflows
- AMD RDNA 2 architecture
- 32GB GDDR6 video memory
Gigabyte AORUS GeForce RTX 4090 Master 24GB GDDR6X Graphics Card:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Gigabyte-AROUS-RTX4090-300x286.jpg)
- NVIDIA RTX 40 Series
- Ada Lovelace architecture
- 16384 CUDA cores
- 24GB GDDR6X video memory
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/Guide-to-RTX-40-Series-300x300.jpg)
For an in-depth look at the brand-new RTX 40 Series, you can take a look at our dedicated blog article.
RAM:
For your workstation, we would recommend either a dual- or quad-channel RAM configuration. This ensures your workflow is spread between four to eight sticks of RAM, allowing for more of your data to be processed all at once, at fast speeds.
TeamGroup Xtreem ‘8Pack Edition’ 32GB (4 x 8GB) DDR4 Quad-Channel RAM Kit:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/TeamGroup-Xstreem-32GB-289x300.jpg)
- 32GB (4X8GB) capacity
- Quad-channel configuration
- Special 8Pack edition
- DDR4 standard
- Up to 3600MHz RAM speed
Corsair Vengeance RGB 64GB (2 x 32GB) DDR5 Dual-Channel RAM Kit
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/CorsairVengeance-32GB-300x242.jpg)
- 64GB (2x 32GB) RAM kit
- DDR5 standard
- Dual-channel configuration
- Up to 5600MHz
Power Supply:
A high-quality PSU with at least an 80 Plus Gold Rating, will ensure a steady, reliable stream of power with maximum efficiency.
Corsair RMx850 850W Fully Modular ATX PSU:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Corsair-RMx850-300x263.jpg)
- 850W power capacity
- 80 Plus Gold rating
- Modular form factor
ASUS ROG Strix 1000W 80 Plus Gold ATX 3.0 Modular PSU
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/ASUSROGStrix-1000W-PSU-300x270.jpg)
- 1000W power capacity
- ATX 3.0
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/2210-atx-3.0-PSUs-blog-300x300.jpg)
If you do opt for an RTX 40 Series GPU, please note you will need a 12VHPWR power connector or an ATX 3.0 power supply. Our in-depth look at ATX 3.0 power supplies has all the information you need.
Cooling:
A comprehensive cooling system is a must to ensure your workstation performs at optimum temperatures, even under heavy loads. Therefore, we recommend a combination of both water and air cooling, such as a high-quality AiO and fans.
EK Water Blocks EK-Nucleus CR360 DRGB AiO Cooler:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/EKWaterBlocks-EKNucleus-300x245.jpg)
- AiO CPU cooler
- 360mm
- 3 x 120mm fans
- Compatible with both Intel and AMD
Corsair AF140 RGB 140mm High Performance PWM Fans:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Corsair-AF140-300x285.jpg)
- Twin pack of fans
- 2 x 140mm
- PWM fans
Enhance Your Workflow!
If you are looking to harness the power of a high-quality workstation, we’ve got a range of dedicated blog posts, designed to show you how you can optimise your workflow.
How You Can Start Earning From Your PC and Laptop
![How you can earn money from your PC or laptop](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/2211-earning-from-pc-300x300.jpg)
Upgrading Your PC: Embrace the Future of Next-Gen PC Hardware
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/Next-Gen-PC-Hardware-300x300.jpg)
Upgrade Your WFH Set-Up and Maximise Your Productivity
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Upgrade-WFH-300x300.jpg)
If you have upgraded your work set up to include a powerful workstation, be sure to leave a comment down below on how it’s boosted your workflow and productivity!
