Between the TV show and next-gen updates, the itch to play Fallout 4 is real.
As there is really no better time than now to start a new save of this iconic game, we thought we’d take a closer look at Fallout 4. Whether you’re new to the franchise or an Americana veteran, brush up on gameplay, discover the next-gen updates, and check out which PCs we think are best for exploring the wasteland.
Fallout 4 Gameplay
Fallout 4 is an ambitious open-world, post-apocalyptic RPG. Set in Boston, you are the sole survivor of Vault 111 looking for your missing child Shaun. The wasteland waits for you, welcome home.
With an expansive map and thousands of items to collect, upgrade, and build, there is plenty to do in Fallout 4. There are hundreds of locations to explore, quests to complete, and NPCs to meet. Plus, there are the various factions, all vying for power and control, to contend with, too.
The S.P.E.C.I.A.L. character design system allows you to tailor your vault dweller to suit your playstyle, using hundreds of Perks. From Power Armoured tank to smooth talking your way out of trouble, you can play Fallout 4 the way that best suits you.
What’s more, you can choose to play in either first- or third-person. Experience the combat up close and personal or get a full view of that cinematic carnage! With the Vault-Tec Assisted Targeting System (V.A.T.S.), you can even dynamically slow combat down and enjoy every visceral detail.
Next-Gen Updates!
As of April 25th 2024, you can enjoy Fallout 4 with support for next-gen hardware. This includes widescreen and ultra-widescreen support, as well as a whole bunch of new content and quest updates. It will even be Steam Deck verified!
New content includes a new story quest about the Enclave, a makeshift weapon pack, and a Hallowe’en workshop.
When Does Fallout 4 Happen in the Timeline?
Fallout 4 is the fifth major instalment in the Fallout series, although the eighth game released at the time. It is set ten years after Fallout 3 and six years after Fallout: New Vegas.
Fallout 4 VR
If you are big into your VR, then you’ll be pleased to know that there is a VR version of Fallout 4, too! Released a couple of years after the original Fallout 4, F4VR properly immerses you into the wasteland, letting you truly step into this post-apocalyptic world.
Check out more exciting VR gameplay, with our Coming to VR Series!
What Platform Can I Play Fallout 4 On?
Fallout 4 is available to play on PC, PlayStation 4, PS5, Xbox Series X/S, and Xbox One.
Like most of the Fallout franchise, Fallout 4 is a singleplayer adventure. Its cinematic design and compelling story telling make it a great game to stream, though!
Fallout 4 Official Specifications
What does it take to survive the nuclear wasteland? Here are the official specifications for Fallout 4:
Component | Minimum Specs | Recommended Specs |
Operating System | Windows 10 /8 / 7* 64-bit | Windows 10 /8 / 7* 64-bit |
Processor | Intel Core i5-2300 2.8GHz AMD Phenom II X4 945 3.0GHz | Intel Core i7 4790 3.6GHz AMD FX-9590 4.7GHz |
Memory | 8GB RAM | 8GB RAM |
Graphics | NVIDIA GTX 550 Ti 2GB AMD Radeon HD 7870 2GB | NVIDIA GTX 780 3GB AMD Radeon R9 290X 4GB |
Storage | 30GB available space | 30GB available space |
Best PCs to Play Fallout 4
Even with updates and new content dropped in the near ten years since its release, Fallout 4 has entirely modest specs. But is your gaming PC up to getting the most out of the next-gen updates? Should you need an upgrade yourself, we have picked out a few of our favourite gaming PCs and laptops for playing Fallout 4. Not your Americana vibe? No worries, you can explore the full range instead.
Refract Gaming Celeste Pre-Built PC
- Pre-built and fully tested gaming PC
- Plug and play ready!
- AMD Ryzen 7 7700X CPU
- NVIDIA GeForce RTX 4070 GPU
- Covered by three years parts and labour warranty
OcUK Gaming Calcite Pre-Built PC
- Based on our most popular selling specifications
- Intel Core i7-14700KF CPU
- NVIDIA GeForce RTX 4070 Ti GPU
- Fast Gen4 storage
MSI Sword 16 HX Gaming Laptop
- Powerful gaming laptop
- Intel Core i7-14700HX CPU
- NVIDIA GeForce RTX 4060 GPU
- 16″ QHD+ display with 240Hz refresh rate
- 16GB DDR5 RAM
OcUK Gaming Falcon Configurable PC
- Configurable gaming PC – adjust the CPU, GPU, RAM, and more!
- AMD Ryzen 7 7700 CPU as standard
- AMD Radeon RX 7800 XT GPU as standard
- Up to 32GB DDR5 AMD EXPO RAM
- Choose up to three high-speed SSDs
Infin8 C99 High-End PC
- Water-cooled high-end gaming PC
- AMD Ryzen 9 97950X3D CPU with 3D V-Cache
- NVIDIA GeForce RTX 4090 GPU
- Configurable RAM and storage
- Powerhouse for gaming and streaming
I Don’t Want To Set the World on Fire
Can’t get enough of Fallout right now? Yeah, us too. Good job we have plenty more Fallout fun for you!
Which is Your Favourite Fallout?
Let us know in the comments below which your favourite Fallout game is!
PC specs are subject to change.
