The Ducky ONE 2 Mini Gaming Keyboard distinguishes itself from the competition with an ultra-minimalist appearance and an uncompromising combination of features and sought-after touches to its design. As expected, reliable Cherry MX switches are Ducky’s first choice here, and these are then paired with PBT double-shot keycaps. The range of features on offer is augmented by the use of a white case without a number pad or arrow keys to result in an extremely slim and stylish frame that is then combined with RGB-LED backlighting.
The Features of the Ducky ONE 2 Mini at a Glance:
- Compact tenkeyless mini-design (60 %) in white;
- Premium Cherry MX switches
- Stylish RGB-LED backlighting
- PBT Double-shot keycaps for improved durability
- Removable cable with USB Type-C connector
- USB N-Key-Rollover & 1.000 Hertz polling rate
- Multimedia Functions & mouse cursor control via macros
Design, Aesthetics & Materials
The case of the Ducky ONE 2 Mini gaming keyboard is white. The keycaps are made from polybutylenterephthalate, or PBT for short, and use a double-shot manufacturing process to make them significantly longer-lasting than traditional ABS keys. This compact style of keyboard layout not only forgoes the numpad, it also removes the arrow keys and the Insert/Delete key block. The entire row of function keys has also been removed in the name of minimising its footprint. All of the functionality of said keys have, however, has been integrated into the remaining 61 keys and these can be activated by means of the Fn key. This TKL-Mini aka 60% layout design results in one of the most portable and lightweight keyboards available.
Stylish RGB-LED Backlighting
The highlight of the Ducky ONE 2 Mini gaming keyboard is, without a doubt, its RGB-LED lighting, and users are free to express their creativity with its programmable combinations. As such, it offers twelve distinct lighting modes, each more impressive than the next. The special feature of Ducky keyboards, however, lies in the completely software-free configuration of said RGB lighting: All settings and adjustments can be made via various button combinations.
Functions & Features of the Ducky ONE 2 Mini Gaming Keyboard
The sought after Cherry MX switches are virtually indestructible and, depending on the desired characteristics, can be swapped out to adapt the keyboard in question to meet the your individual needs and preferences. The Ducky ONE 2 Mini is available with a whole range of different Cherry switches: In addition to Red- and Silent Red switches, they are also available in Brown, Blue, Black and (last but not least) Speed Silver.
Thanks to USB N-Key-Rollover, users can activate multiple keys simultaneously without having to worry about ghosting or other delays. This is where the 1.000 Hertz polling rate of the USB port comes into ist own, making contact with the PC every single millisecond. The keyboard itself has a USB Type-C connector complete with a removable cable, the other end of which is a standard Type-A connector. The rubberised feet are also convenient for keeping your keyboard in situ, and the stand-offs can be adjusted to three different heights.
The powerful ARM M3 Micro-Controller used in the Ducky ONE 2 Mini controls and saves the selected LED effects. Additionally, it optimises communications between the keyboard and the PC while simultaneously enabling several other functions, including the use of macros and user profile storage. Additionally, the multimedia functions of the keyboard are possible thanks to Ducky Macro V2.0 – it even enables users to control the mouse cursor!.
