![Kolink Inspire K5](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/Amazon-Kolink-InspireK5-ARGB.jpg)
Performance, aesthetics, and cooling – three crucial factors that go into buying a gaming PC case. Thankfully, you won’t have to prioritise one over the other, courtesy of the Kolink Inspire K5 ARGB Mid-Tower Case. A long-awaited addition to the Inspire range, Kolink brings a one-of-a-kind design to the K5 mid-tower chassis. The eyes are immediately dazzled by the front panel’s addressable RGB-LED strip and rear 120mm ARGB fan. A tinted yet chic tempered glass side panel easily shows off your dazzling colours and high-end hardware. Side-facing cut-outs optimise airflow whilst working as dust filters. Last but not least, you’ll have plenty of space for graphics cards, CPU coolers, and radiators. In short, for those who’re looking for an affordable mid-tower gaming PC case, look and be tired no longer, because the Kolink Inspire K5 is here for you.
![Kolink Inspire K5 ARGB Mid-Tower Gaming PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/kolink-inspire-k5-top-down.jpeg)
Functional Elegance
Those who appreciate combined elegance and performance will be thrilled by what this mid-tower chassis has to offer. The unique, opaque strip on the front panel can be controller via the I/O panel’s USB ports (3.0 and 2.0), or a 3-pin motherboard connector. What’s more, seamless control of rich, vibrant colours is assured. Whilst able to accommodate ATX, Micro-ATX, and Mini-ITX motherboards, this case also supports GPUs up to 310mm in length as well. Able to host CPU coolers up to 160mm in height, those who favour water cooling will be in luck as well; a 240mm radiator can be installed in the front whilst a 120mm radiator can be added to the rear.
![Kolink Inspire K5 ARGB Mid-Tower Gaming PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/kolink-inspire-k5-three-views.jpeg)
A 120mm ARGB fan is included, but if you want to take things up a notch, three more of the same size can be installed to the front to truly elevate airflow. By also enabling integration for two more 120mm to the PSU shroud, you’ll be granted sustainable cooling of your power supply. Such fan support is truly, well, a breath of fresh air.
![Kolink Inspire K5 ARGB Mid-Tower Gaming PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/kolink-inspire-k5-cable-management.jpeg)
A gaming PC case wouldn’t be regarded as “stylish” if it were cluttered. This makes the Kolink Inspire K5 more of a wonder when you notice that the curve of the case’s side cover offers more space to store your cables, keeping the inside nice and tidy. Gamers with a lot to play won’t be disappointed storage-wise either: already supporting two 3.5″ HDDs and 2.5″ SSDs each, the Kolink Inspire K5 allows you to install two more 2.5″ SSDs at the motherboard’s rear. The ultimate abundance of high-speed gaming storage.
The Kolink Inspire K5 ARGB Mid-Tower Gaming PC Case offers excellence in style, cooling, and functionality for your set-up. Learn more from our product page and pre-order from Overclockers UK store today!
- ARGB front strip & rear 120mm fan
- Tinted tempered glass side panel
- Supports up to ATX motherboards
- GPU support up to 310mm
![Kolink Inspire K5 ARGB Mid-Tower Gaming PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/06/kolink-inspire-k5-mid-tower-case-angle-shot-1.jpeg)
