The latest addition of the RTX 40 Series has arrived at Overclockers UK – the NVIDIA RTX 4060.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/2829329-gf-gtmk-rtx-4060-amazon-brand-store-feature-1500x1500-engb-1024x1024.png)
The NVIDIA RTX 4060:
Built utilising cutting-edge Ada Lovelace architecture, the RTX 4060 is a must-have GPU for mid-range gaming. Equipped with up to 3072 CUDA cores, boosted clock speeds of 2460MHz, and up to 8GB of high-quality GDDR6 video memory, unlock fast smooth performance in all your favourite games at up to 1080p resolutions.
What’s more, with both third-gen RT and fourth-gen Tensor cores, the RTX 4060 comes fully equipped with support for Ray Tracing and NVIDIA’s latest generation of AI DLSS 3. Both of these combined result in photo-realistic graphics, immersive gameplay, and silky-smooth frame rates.
Architecture | Ada Lovelace |
CUDA | 3072 |
Base clock | 1.83GHz |
Boost clock | 2.46GHz |
Video Memory | 8GB GDDR6 |
Memory Bus | 128-bit |
TDP | 115W |
If you are getting your hands on a shiny RTX 4060, be sure to read our dedicated guide all about the NVIDIA 40 Series.
![Your Guide to the NVIDIA RTX 40 Series](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Guideto-NVIDIA40Series-blog-300x300.png)
Upgrade to the RTX 4060:
Gigabyte GeForce RTX 4060 Windforce OC 8GB GDDR6 Graphics Card:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Gigabyte-RTX4060.jpg)
- Ada Lovelace architecture
- 3072 CUDA cores
- 2475MHz boosted clock speeds
- 8GB GDDR6 video memory
MSI GeForce RTX 4060 Ventus 2X OC 8GB GDDR6 Graphics Card:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/MSI-RTX4060.jpg)
- 3072 CUDA cores
- 2505MHz boosted clock speeds
Alternatively, you can shop our entire range of RTX 4060 graphics cards but clicking the button below.
