![Cyberpunk 2077 Banner](https://img.overclockers.co.uk/media/image/Cyberpunk-2077-banner.png)
Cyberpunk 2077 is one of the most anticipated games this year. It’s been delayed several times by CD Projekt Red, but with November 19th fast approaching it won’t be long before we’re finally able to explore the streets of Night City. This vast open-world game is complex and detailed with realistic graphics and lighting which means you’ll need some decent PC hardware to run the game in all it’s glory.
What are the PC specifications for Cyberpunk 2077?
On the 18th of September via twitter and the latest Night City wire episode, CD Projekt red announced the minimum and recommended specifications needed for PC gamers. You can watch the full episode below and check out the list of specifications.
Cyberpunk 2077 Night City Wire episode 3:
The minimum specifications reveal that you won’t need a cybernetically enhanced PC for Cyberpunk 2077 to run at some level. There’s not a huge amount of detail about what these specs will get you in terms of performance but CD Projekt red did say it was created with Low settings and 1080p gaming in mind. With a CPU from 2012 and a pair of dated GPUs, it’s likely you’ll be looking at 30fps. You won’t be able to experience the incredible aesthetics and if you’re on a tight budget it might be worth picking up the game on PS4 or Xbox one instead.
The recommended specifications are surprisingly modest and CD Projekt red did say they were created with High and 1080p settings in mind. I’d also expect you will get about 30fps-60fps in what looks to be a very demanding game. These recommended specifications will never be able to handle raytracing, 1440p or 100fps+. I’m sure this is the sort of performance and experience most PC gamers are going to aim for. After all the developers have spent a lot of time bringing the megalopolis to life and we want the gameplay experience we’ve seen in the tantalising trailers and stunning showcases. CD Projekt has never held back on giving your PC a beating when it comes to graphical requirements and it’s likely Cyberpunk 2077 is going to be no different when it comes to 4K resolution and Ultra graphical settings.
The Best Cyberpunk 2077 themed PCs:
If you want some great ideas on how to make your PC cyberpunk-themed why not check out the top five entries from CD Projekts modding competition. There is an epic Throne, incredible custom cases and even a Militec robot. Each Mod was judged by big industry names such as Nvidia, Steelseries, Alienware and Gamers Nexus.
Overclockers recommended PCs to play Cyberpunk 2077:
If you want to play on PC and not one of the many consoles that will also support the game it’s likely you want to get the full PC experience with all the bells and whistles it has to offer. Night City is full of shadows and reflections created by the futuristic neon lighting so it’s no surprise Nvidia has been working hard with CD Projekt to implement plenty of raytracing goodness. There will be four ray-traced effects in the game to improve image quality, realism, and immersion alongside Nvidia DLSS 2.0 which uses AI to help to boost frame rate and create beautiful, crisp images. This means the best way to experience Cyberpunk will be an RTX GPU, at least until AMD’s Big Navi is released with raytracing capabilities later this year.
To help you prepare for the release of Cyberpunk 2077 we’ve picked out five of our best pre-built PC’s which have been assembled and tested by the expert team here at Overclockers UK. There are options for different budgets and we’ve even included PCs with brand new RTX 30 series graphics.
Overclockers Scimitar Pro Gaming PC
- AMD Ryzen 7 3700X Eight core sixteen thread processor
- Choose from an Asus TUF RTX 3080 or RTX 3090. We recommend the RTX 3080 for Cyberpunk 2077 and the RTX 3090 for Gaming and professional use.
- At least 12GB of RAM is needed for a good experience on Cyberpunk and this PC has 16GB of high-quality 8Pack 3600Mhz memory.
- 70GB of storage is needed and an SSD is recommended. Both bases are covered with the superfast Samsung 970 Evo.
- Choose from a selection of Phanteks cases and spec this PC from £2,484.98
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/09/FS106OG_196017_750x750.jpg)
Overclockers Germanium Z4 Gaming PC
- The Intel i9 -10900K with ten cores & twenty threads is the best you can get for gaming performance.
- Choose from a range of powerful Gigabyte RTX 3080 graphics cards. The Master and Xtreme have a higher boost clock speed out of the box.
- The 12GB of RAM you’ll need for Cyberpunk is covered with the 16GB of attractive RGB Team group memory you’ll find in this PC.
- There’s plenty of fast storage to ensure loading screens don’t slow you down, thanks to the 500GB Samsung 970 EVO plus.
- Choose from a selection of Phanteks cases and spec this PC from £2,999.99.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/09/FS1ECOG_249670_750x750.png)
Infin8 Watercooled Domino Gaming PC
- Intel i7 10700K with eight cores and sixteen threads is perfect for gaming and has been water-cooled and professionally overclocked to 5Ghz.
- The Domino comes equipped with a water-cooled RTX 3080 for cool and quiet performance while gaming.
- It has plenty of memory for modern games like Cyberpunk 2077 with 16GB of 3200Mhz RAM.
- Cyberpunk recommends using an SSD and you’ve got plenty of space on the 500GB Samsung 970 EVO plus inside this PC.
- This enthusiast-grade PC is as stylish as it is powerful with RGB LEDs and high-quality white hardware to bounce the lights around. Spec this PC from £3579.98
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/09/FS1DMOG_219740_750x750.jpg)
Overclockers Radiance Bullet Gaming PC
- The AMD Ryzen 3600 has six cores and 12 threads which makes it great for gaming, streaming and creative tasks.
- This is our most affordable Raytracing PC for Cyberpunk because it equipped with an Asus RTX 2070 Super Dual Evo which is an excellent graphics card at this price point.
- There’s plenty of memory for Cyberpunk 2077 and more with 16GB of attractive RGB 3000Mhz memory from Team Group.
- As standard, the Radiance comes with a 500GB WD M.2 drive which means you’ll have plenty of fast storage for Cyberpunk 2077 and more.
- Choose from a wide selection of cases from Coolermaster, In-Win, fractal design and more. Spec this PC from only £1199.99.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/09/FS1DLOG_215396_750x750.jpg)
Overclockers Gallium Gaming PC
- The AMD Ryzen 7 3700X with Eight cores and sixteen threads is great for CPU heavy tasks like streaming, rendering and gaming.
- Get the latest and greatest graphical performance from the Gigabyte RTX 3080 Gaming OC graphics card.
- Modern titles like Cyberpunk will easily run on the 16GB of fast 3600Mhz Corsair Vengeance memory.
- Loading times will be obliterated by the performance of the Gen 4 Corsair MP600 and there’s plenty of space for games.
- Choose from a wide selection of Phanteks cases and spec this PC from £1999.99
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/09/FS1EJOG_263116_750x750.jpg)
Where to Buy the Best PCs for Cyberpunk 2077:
To get your hands on one of Overclockers hand-picked PCs for Cyberpunk 2077 you can simply click the buy button above for your favourite system. Or if you’d prefer to browse the full range there is a dedicated section on the Overclockers website just for Cyberpunk 2077 which you can find HERE.
![Overclockers Support Icon](https://img.overclockers.co.uk/media/image/Overclockers-Support-Icon.png)
Ask the Experts
With years of experience in the industry, Overclockers UK is widely known for building some of the finest custom gaming machines on the market. If you want more information on building the best PC for Cyberpunk 2077 why not contact our team of friendly experts on 01782 444455 and they will be happy to help. You can also ask us a question HERE.
