Whether you’re playing the latest AAA title or live streaming your next great hit, you need a set-up that boasts plenty of extra space and powerful hardware. Enter the ultimate dual monitor set-up. From a premium-quality gaming PC, tasty peripherals, and plush gaming chair to must-have monitors, this set-up is sure to meet your high standards.
Keep on reading for a closer look at our dual monitor set-up.
Why Would I Want a Dual Monitor Set-Up?
Dual monitor set-ups can be helpful to gamers, streamers, and creatives alike. Harnessing plenty of screen real estate allows you to easily split your workloads across all your displays. Consistently flicking between multiple applications is a thing of the past! You can dominate your enemies on one screen whilst you have a handy game guide open on the other.
What Hardware Do I Need for a Dual Monitor Set-Up?
To create a dual monitor set-up, you’ll need to ensure you’ve got all the foundations. This includes your trusty PC, desk, comfy chair, and a range of core peripherals.
When it comes to selecting your monitors, there are a few important factors you need to consider. First, is the configuration of your screens. You aren’t limited to only having two landscape monitors. You can tweak the orientation to feature one landscape and one portrait. This is especially handy for professionals or creatives who write and read a lot of information daily.
Secondly, we recommend you opt for two of the same monitor. We have highlighted two different models below to give you plenty of options, however, opting for the same monitor can prevent any issues caused by two different resolutions, sizes, or refresh rates. You won’t achieve seamless performance across your two screens and might even notice a performance drop when you compare them.
Finally, if you’re looking to game at a high resolution you need to consider both your monitors and GPU. Rendering two screens will put extra strain on your graphics card. If it can’t keep up with these demands, you won’t achieve the level of performance you desire.
The Ultimate Dual Monitor Set-Up
To help boost your productivity and gaming, we’ve searched the Overclockers UK website and created our very own dual monitor set-up. You’ll certainly want to get these items added to your basket, and quick!
Refract Gaming Indigo Pre-built PC
Crafted with creatives and gamers in mind, the Refract Gaming Indigo Pre-built PC features all the horsepower you need for your dual monitor set-up. At the centre of this system is the AMD Ryzen 9 7900X3D CPU, optimised for multi-core workloads and next-level efficiency thanks to the integrated 3D V-Cache. Take your gaming or multitasking to a new level with 32GB of DDR5 RAM. Featuring support for AMD EXPO, you can achieve ultra-fast loading times and near-zero latency or input lag. What’s more, you’ll be sure to stay one step ahead of your enemies as the NVIDIA RTX 4080 Super will render your games in incredible lifelike quality. Those photo-realistic graphics and silky-smooth frame rates are sure to look *chef’s kiss* with all your screen real estate.
Gigabyte M27U 27’’ 3840 x 2160 Widescreen Gaming Monitor
One of the shining stars of this set-up is the Gigabyte M227U 27’’ Gaming Monitor. Equipped with a 3840 x 2160 display, 165Hz refresh rate, and 1ms response time, this monitor is the perfect companion to take with you on your gaming adventures. The 95% DCI-P3 gamut ensures true-to-life colour representation to next-level immersion.
LG 27GR93U-B 27’’ Widescreen Gaming Monitor
Our next monitor of choice is the LG 27GR93U-B 27’’ display. Boasting a 3840 x 2160 resolution, you’ll have plenty of screen real estate to handle all your multitasking. The 144Hz refresh rate and 1ms response time deliver blisteringly fast responsiveness to ensure you’ll never miss a second of the action. To further aid you in the heat of battle the LG 27GR93U-B features a built-in crosshair to enhance your precision and shooting accuracy.
Kolink Chimera Dual Monitor Desk Mount
Keep your desk free of clutter and achieve that sleek minimalistic aesthetic with the Kolink Chimera Dual Monitor Desk Mount. Capable of holding a hefty 12kg per arm and screens of up to 36’’ you won’t have to compromise on your choice of monitor. Integrated cable management along the back of the mount makes it even easier to neatly store any excess cables.
OcUK Value 3m HDMI 2.0 Braided Cable
The OcUK Value 3m HDMI 2.0 Cable is the perfect accessory to pair with your dual monitor set-up. Compatible with the 2.0 standard, this cable supports up to 5120 x 2880 resolutions and a max refresh rate of 240Hz. Everything you need to unlock maximum performance, ultra-fast response times, and stunning visual quality.
Ducky Project D Tinker 75% USB Mechanical Gaming Keyboard
Take your gaming to new heights thanks to the Ducky Project D Tinker 75% Mechanical Keyboard. This pre-built model has been engineered utilising only the finest materials to ensure superior stability and durability, no matter how intensive your gameplay gets. The hot-swappable PCB allows you to pick and choose your key switches to further fine-tune this keyboard to suit your needs. This model includes Cherry MX Speed Silver switches to deliver silky-smooth yet ultra-fast typing. The finishing touches to this keyboard are PBT double-shot keycaps arranged in a UK ISO layout and customisable RGB lighting.
Endgame Gear XM2WE Wireless Optical Gaming Mouse
Equipped with the Endgame Gear XM2WE Gaming Mouse, you can achieve pixel precision across all your workloads. The Pixart PAW3370 optical sensor delivers superior control over all your mouse movements whilst the Kalih GO switches enhance response times and have an 80 million actuation lifespan. Completely wireless and boasting fast 2.4GHz connectivity, you’ll never need to worry about pesky wires or high latency. The durable 410mAh battery has been optimised to last, capable of running for a week in between charges. Everything you need to game, stream, and create for longer!
ASUS ROG Delta S Lightweight Gaming Headset
Become immersed in all your favourite classic gaming soundtracks with the ASUS ROG Delta S Headset. Powerful ASUS Essence drivers deliver true-to-life audio whilst the intelligent airtight chamber design ensures minimal background interruption. For your late-night gaming marathons, the ASUS AI Noise-Cancelling Microphone ensures your teammates will hear you loud and clear, eliminating any unwanted noise such as mouse clicks or keyboard clatter.
ThunderX3 ED7 Adjustable Gaming Desk
The finishing touch to our dual monitor set-up is the ThunderX3 ED7 Gaming Desk. Height adjustable, this desk features a powerful dual motor allowing you to quickly swap from sitting to standing. The built-in cable tray and grommets make organising your messy wires a breeze, so you can sit back and enjoy that minimalistic clutter-free aesthetic. What’s more, finished with stylish carbon-fibre, the ThunderX3 ED7 will make a stunning addition to any set-up, complete with an included mouse pad and under-table cup holder.
You’ve Got the Tech… But What Do You Do with It?
You’ve got the tech but now it’s time for the tricky part – putting it all together. Thankfully, we’ve got a handy guide all about configuring your new shiny dual monitor set-up.
Share Your Top Hardware Recs
What are your must-have accessories for your dual monitor set-up? Share your set-up recs in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
