Continuing its aim to bring premium-quality products throughout the PC gaming community, Kolink has added a trio of fans to an already exquisite range of accessories. At Overclockers UK, we’re introducing three new 120mm PWM fans: the Kolink Classic, the Kolink Umbra, and the Kolink Umbra Void.
Starting with the Kolink Classic, all fans deliver splendid cooling performance in their own right. What’s more, each version is incorporated with additional features which take the look of your gaming PC to the next level. For example, whilst the Kolink Classic is a sleek 120mm PWM fan sporting seven black blades, the Kolink Umbra adds ARGB lighting and daisy-chain capabilities. The Kolink Umbra Void goes even further beyond, adding extra LEDs and the Kolink-exclusive Infinity Mirror – granting you an endless reflective effect for a stunning light show.
Kolink Classic
Capable of speeds up to 1500RPM and an airflow of 52.15CFM, the Kolink Classic Fan is complemented by its elegant design. Accompanying its seven black blades is a female PWM connector, allowing you to link up with adjustable speeds controls for your fan. As a result, you’ll be able to alter your fan speed depending on the task at hand.
A sleek addition to any gaming PC, the Kolink Classic fan is built to last. Why? Because this 120mm PWM fan also has a hydraulic bearing incorporated into the design. With it, the Kolink Classic will enjoy reduced internal friction for boosted performance and a life of 40,000 MTBF.
Kolink Classic 120mm PWM Fan
- 120mm Black 7-Bladed PWM Fan
- Up to 1500RPM
- Female PWM connector
- Hydraulic Bearing
Kolink Umbra
Like the Classic, the Kolink Umbra brings incredible cooling performance, courtesy of its nine white curved blades. What’s more, you can utilise the 3-pin 5V header and 21 LEDs for gorgeous lighting displays. Using compatible software like Asus Aura Sync, you’ll be able to tailor your gaming PC’s light show to a variety of wondrous effects.
Furthermore, the Kolink Umbra features both a male and female PWM connector. So, you’ll be able to connect with controllers for adjustable fan speeds, coupled with the ability to daisy-chain multiple units together.
The Kolink Umbra has been manufactured with durability and performance in mind. Together with the implemented hydraulic bearing, the Kolink Umbra has also been armed with anti-vibration pads. When using your Kolink Umbra fans, you’ll relish in smooth yet quiet performance, with a sound level of just 17.8dB (A).
Kolink Umbra 120mm PWM ARGB Fan
- 120mm White 9-Bladed PWM ARGB Fan
- Up to 1500RPM
- Daisy-chain PWM connector
- Hydraulic Bearing and anti-vibration pads
Kolink Umbra Void
The Kolink Umbra Void Fan is armed with the means for incredible ARGB lighting and cooling performance. but with a twist. Through its 24 LEDs, combined with other controllable lighting effects, the Kolink Umbra Void Fan adorns your gaming PC with the signature and exclusive Infinity Mirror. With this exquisite effect, you can gaze into the void as your PC is turned into an endless tunnel of vibrant, vivid colours.
Rigged with the same hydraulic bearing and anti-vibration pads, you’ll have the benefit of reliable and lasting performance. All-in-all, this 120mm PWM fan is loaded with captivating ARGB, daisy-chain functionality, and the breathtaking Infinity Mirror effect; all backed by premium components that are built to last. Without a doubt, the Kolink Umbra Void Fan becomes a visual marvel during every gaming session.
Kolink Umbra Void 120mm PWM ARGB Fan
- Fits large, 3-slot GPUs
- Ultra-fine performance mesh
- Modular GPU mount
- Sleek aesthetic & tidy cable management
