Spoiling the gamer in your life doesn’t have to break the bank.
There are plenty of budget-friendly presents, including hardware and must-have peripherals, that will be a worthy addition under the tree this year. We’ve put together this list of our top five gifts that are under £100.
Ducky One3 Mist Mini USB Mechanical Gaming Keyboard
Level up your performance with the Ducky One3 Mist Mini Mechanical Gaming Keyboard. Crafted with innovative Quack Mechanics, this keyboard boasts superior accuracy, fast response times, and enhanced comfort for an optimised typing experience. The hot-swappable PCB allows you to freely swap between different types of key switches in order to find the set that perfectly suits your individual preferences. What’s more, its 60% mini form factor, ensures it won’t take up room on your desk, perfect for those with small office spaces.
Finally, the mist grey shell, purple keycaps, and integrated RGB lighting make this keyboard a stylish addition to any gaming set-up. The Ducky One3 Mist Mini Mechanical Gaming Keyboard is available to purchase for £89.99*.
- Mechanical gaming keyboard
- 60% mini form factor
- Quack mechanics
- PBT keycaps
- Hot-swappable PCB
- Integrated RGB lighting
Kingston FURY Beast 16GB (2x8GB) DDR5 Dual-Channel RAM Kit
Wave goodbye to latency and slow loading times with the Kingston FURY Beast 16GB DDR5 RAM Kit. Arranged in a dual-channel configuration, this kit boasts two 8GB RAM modules capable of reaching max speeds of up to 5600MHz. Plus, with support for Intel XMP 3.0, unlock simple easy-to-use overclocking to enhance your gaming experience one step further.
The Kingston FURY Beast 16GB DDR5 RAM Kit is available to buy for £49.99*.
- 16GB (2 x 8GB) RAM capacity
- DDR5 standard
- Up to 5600MHz RAM speed
- Compatible with Intel XMP 3.0
- Dual-channel configuration
WD Black SN770 1TB NVMe M.2 2280 SSD
Give the gift of storage this Christmas with the WD Black SN770 1TB NVMe M.2 SSD. Armed with 1TB capacity, you’ll never need to worry about running out of precious storage space for your expanding gaming library and creative projects. With 5150MB/s read and 4900MB/s write speeds, this M.2 SSD will process your data at incredible speeds with virtually zero latency or lag. You can game, stream, and create with no slow loading times interrupting your performance.
The WD Black SN770 1TB NVMe M.2 SSD is available to buy for £62.99*.
- 1TB storage capacity
- 2280 form factor
- 5150MB/s read speed
- 4900MB/s write speed
Streamplify MIC RGB Microphone with Tripod and Pop Filter
Ensure your teammates hear you loud and clear with the Streamplify MIC Microphone. This cardioid microphone has been designed with an intelligent pick-up pattern. The front of the microphone is extremely sensitive to ensure it registers your voice crystal-clear, whilst the back and sides have near-zero sensitivity to eliminate background chatter. Included with this microphone is an adjustable tripod with anti-vibration pads to absorb any accidental knocks and bumps.
The Streamplify MIC Microphone is available for £35.95*.
- Cardioid microphone
- Two audio modes: Full and One Way Playback
- On-the-fly controls
- Includes pop filter and adjustable tripod
ASUS ROG TUF H3 Gaming Headset
Immerse yourself in your favourite gaming soundtracks and worlds with the ASUS ROG TUF H3 Gaming Headset. Harness powerful 50mm ASUS Essence drivers to unlock rich, pure sound for heightened in-game immersion. The plush ear cups and lightweight construction ensure you stay comfortable even during long hours of work and play.
The ASUS ROG TUF H3 Core Gaming Headset is available to purchase for £49.99*.
- Gaming headset
- Lightweight design
- 7.1 surround sound
- ASUS 50mm Essece drivers
- Plush on-ear cushions
In Need of Some More Gift Inspo?
Check out our other guides for all the gift inspo you need this Christmas.
*Prices correct at time of writing and PC specs are subject to change.
