Christmas is right around the corner, and for all those last-minute shoppers you are running out of time to nab the perfect gift.
Whilst you may want to spoil the gamer in your life, you don’t have to break the bank in doing so. In fact, there are plenty of budget-friendly performance-boosting and aesthetically pleasing gamer gifts out there. We’ve put together this list of our top five that are under £50.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/Top-5-gifts-for-PC-gamers-under-50-1024x1024.jpg)
Endgame Gear MPC1200 Cordura 3XL Black Gaming Surface
Add a touch of class to your set-up with the Endgame Gear MPC1200 Cordua 3XL Black Gaming Surface. Constructed from premium Cordura fabric, this mouse pad has been optimised for use with optical gaming mice. This facilitates superior control, enhanced accuracy, and effortless gliding. Everything you need for that competitive edge in-game. Plus, the rubberised base ensures this mouse mat will stand firm without cinching or rumpling during intensive boss battles. Finally, measuring 1200 x 600 x 3mm you’ll have plenty of real estate for your peripherals, accessories, and vital mid-game cuppa.
The Endgame Gear MPC1200 Cordura 3XL is available for £49.99*.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/EndgameGear-MPC1200-300x223.jpg)
- XXL mouse mat
- Cordura fabric
- Optimised for optical gaming mice
- Rubberised base
Aerocool Mirage 12 Pro Triple Pack 120mm RGB Fans
Keep your hardware cool and illuminated in RGB with the Aerocool Mirage 12 120mm Triple Fan Pack. Fine-tuned to enhance your PC’s natural airflow, the fan rotates at 1300 RPM at a max volume of up to 17.8 dB even under heavy-duty loads. To further ensure quiet operation, the corners of each fan are rubberised to reduce any vibrations and background noise. What’s more, the 12 ARGB LEDS add a vibrant splash of colour to the interior of your PC case. Thanks to the included remote and compatibility with a range of control software, you can easily configure the lighting to suit your desired aesthetic.
This triple pack of Aercool Mirage 12 Pro 120mm Fans are available for £29.99*.
- Triple fan pack
- 120mm
- 1300 RPM
- Includes 12 ARGB LEDs
- Comes with an RGB remote controller
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/Aerocool-Mirage-300x292.jpg)
Ducky V2 Pure White Coiled USB Keyboard Cable
Enhance your connectivity and the look of your set-up with the Ducky V2 Pure White Coiled Keyboard Cable. This USB A to USB Type C cable facilitates a strong and reliable connection to power your gaming keyboard. Its coiled design delivers excellent flexibility whilst also reducing cable clutter. This model is pure white, however, you can find plenty of other colour variants including classic red and green for that all-out festive look to your desk.
The Ducky V2 Pure White Coiled USB Keyboard Cable is available to purchase for £38.99*.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/DuckyV2-PureWhite-264x300.jpg)
- USB Type A to Type C keyboard cable
- 180mm
- Coiled design
- Plenty of different colour variants available
Streamplify HUB Deck 5
Wave goodbye to cable clutter with the Streamplify HUB Deck 5. Armed with five USB ports, you can easily organise all your cables and peripherals. Each port features a dedicated power button enabling you to use all your devices as and when you need them. Plus, the LED indicator on the slots makes it easy for you to spot when a device is on. Organisation doesn’t have to be boring (said no one ever!), as the Stream Hub Deck 5 comes with integrated RGB lighting. You can select from eleven different dynamic lighting effects to create a colourful backdrop to your cable management.
The Streamplify HUB Deck 5 is available for £29.99*.
- USB Hub
- Five USB ports
- 4 x USB 3.0
- 1 x USB 2.0A
- Integrated RGB lighting
- Includes cable clip
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/Streamplify-HUB.jpg)
Ducky 132 PBT ISO/ANSI Daisy Keycaps
Add a unique splash of colour to your set-up with the Daisy 132 PBT ISO/ANSI Keycaps. Crafted from high-quality plastic, these keycaps boast enhanced durability making them perfect for extended hours of typing or gameplay. The dye-sublimation ensures the pastel colours and novelty flower designs look factory fresh and adorable for longer. Plus, thanks to compatibility with both UK ISO and US ANSI layouts, these keycaps can be used with virtually any keyboard on the market. If Daisy is to your liking these keycaps also come in Dino, Boba, and Mico colour schemes.
The Ducky 132 PBT Daisy Keycaps are available for £29.99*.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/Ducky132-Daisy-Keycaps-300x300.png)
- 132 Keycap set
- Supports both UK ISO and US ANSI layouts
- Made from PBT plastic with dye-sub printing
- Novelty flower designs
- Pastel colours
Need Even More Gift Inspo?
*Prices correct at time of writing and are subject to change.
This is really useful! Thank you so much for your informative blog post! I appreciate the time you took to write this!
