At the heart of any gaming PC is the motherboard. Responsible for connecting all of your vital components together to allow them to work in sync, a high-quality motherboard is a must.
Therefore, we’ve put together this list of our top five motherboards for gaming! Each of these boards come equipped with support for the latest generation of processors, DDR5 RAM, along with a full suite of innovative features designed to enhance your gaming performance.
ASUS ROG Strix Z890-E Gaming DDR5 ATX Motherboard
The ASUS ROG Strix Z890-E DDR5 ATX Motherboard comes packed with a vast array of cutting-edge features, designed to optimise your gaming experience. This includes support for PCIe 5.0, W-Fi 7, and DDR5 RAM, for ultra-fast speeds and smooth rates. Plus, this motherboard is compatible with Intel’s latest generation of CPUs, which means you utilise Intel’s intelligent hybrid core architecture for seamless performance in gaming and streaming alike. What’s more, with seven M.2 slots, you will have plenty of space for all your storage drives. Perfect for your ever-growing gaming library and creative projects.
- ATX form factor
- Intel Z890-E chipset
- Supports both Intel 12th, 13th, 14th Gen, and Core Ultra CPUs
- Compatible with PCIe 5.0 and DDR5 RAM
- Integrated Wi-Fi 7
Gigabyte X870 Gaming X DDR5 ATX Motherboard
Unlock superior performance in all your favourite AAA games with the Gigabyte X870 Gaming X DDR5 ATX Motherboard. This motherboard features the AM5 socket, which means it is compatible with the AMD Ryzen 7000 and 9000 Series. With support for both DDR5 RAM and AMD EXPO, wave goodbye to slow loading times and input lag. In addition to this, this motherboard also comes equipped with integrated Wi-Fi 7 and Bluetooth. This enables you to connect to the internet without requiring an additional ethernet cable or Wi-Fi card.
- ATX form factor
- X870 chipset
- AM5 socket
- Supports AMD Ryzen 7000 and 9000 Series
ASUS ROG Strix Z790-H Gaming DDR5 EATX Motherboard
Achieve next-level gaming with the ASUS ROG Strix Z790-H Gaming DDR5 EATX Motherboard. Utilising the Intel Z790 chipset, you can harness the Intel 12, 13, or 14th Gen CPUs, for intelligent workload management, thanks to the hybrid P- and E- core architecture. What’s more, with support for DDR5 RAM, unlock blisteringly-fast speeds of up to 4800MHz. In addition to this, this motherboard features built-in ASUS ROG SupremeFX 7.1 Surround Sound. You can sit back and enjoy crisp, immersive audio that is sure to prove advantageous in the heat of battle.
- ATX form factor
- Z790 chipset
- Supports both Intel 12th,13th, and 14th Gen CPUs
- Integrated Wi-Fi 6E
MSI MPG Z790I Edge WiFi DDR5 Mini-ITX Motherboard
Optimise your gaming and enjoy legendary performance with the MSI MPG Z790I Edge DDR5 Mini-ITX Motherboard. As this motherboard is compatible with Intel 14th Gen CPUs, you will unlock seamless performance, that is perfect for both work and play! Plus, with support for DDR5 RAM and Intel XMP 3.0, you can enjoy boosted speeds of up to 7200MHz, thanks to reliable automatic overclocks. What’s more, with three M.2 slots, enjoy ultra-fast data transfer speeds and plentiful storage space for your gaming library and much more. The finishing touches to this elite-tier motherboard is the stylish white marble effect. This is sure to look incredible in any PC build, but especially those crisp all-white gaming PCs.
- Mini-ITX form factor
- Z790 chipset
- Supports both Intel 12th, 13th, and 14th Gen CPUs
ASUS ROG Strix X870-F Gaming DDR5 ATX Motherboard
Level up your gaming potential with the ASUS ROG Strix X870-F Gaming DDR5 ATX Motherboard. Compatible with AMD Ryzen 7000 and 9000 Series CPUs, achieve effortless multitasking and cutting-edge performance in both single- and multi-threaded tasks. Finally, this motherboard comes equipped with Wi-Fi 7, which means it has integrated Wi-Fi connectivity, removing the need for additional ethernet cables or Wi-Fi cards cluttering up your precious desk space.
- ATX form factor
- X670 chipset
- AM5 socket
- Compatible with AMD Ryzen 7000 and 9000 Series
- Supports DDR5 RAM and PCIe 5.0
Shop All Our Motherboards
Are none of these motherboards calling to you? Still on the hunt for your next upgrade? You can shop all our available motherboards with the click of a button.
