Singularity Computers are an Australian based company with a focus on research and development to create unique high-quality water-cooling hardware. Since March their wonderful range of products has been available here in the UK from Overclockers. We know a lot of you are huge PC enthusiasts and Singularity products cater to an audience that adores advanced, artistic hardware that’s both unique and eye-catching. If you want to learn more about the company check out our blog post HERE.
Spectre 2.0 PC Case
Spectre 2.0 PC case
The Spectre 2.0 builds on the original Spectre which was the first chassis with liquid cooling and cable management integration. This unique showcase is available in both a black and white variant making it an excellent blank canvas for modification and installation of high-end components.
The case was designed to increase the accessibility of liquid cooling and reduce build times. This is achieved with the integration of a Reservoir, Pump Top, Pump Cover, cable management channels and half a liquid cooling loop. These components no longer need to be bought and installed separately which reduces costs and build time. Fill and drain ports are integrated and decades worth of knowledge and research means this case provides maximum compatibility with a variety of hardware.
Spectre 2.0 singularity case
Features
  • Excellent compatibility for E-ATX motherboards, 60mm radiators, Large GPUs and PSUs
  • Unique integrated transparent acrylic glass distro plate that acts as a motherboard tray
  • Included vertical GPU mount and riser cable (second can be purchased separately for dual GPUs).
  • Created with high-quality materials carved from a solid block of material on a CNC Machine.
  • Spectre 2.0 has a 2-year limited warranty.
Absolute Zero Spectre PC Build
wRAITH pc Image
Wraith PC Case
The Wraith has been designed to include all of the features of Spectre but in a smaller Mini-ITX form factor. Just like the Spectre, this case allows the user to build a spectacular water-cooled system and it has been developed to allow for maximum compatibility and creativity. There are a number of integrated components that save time and money when it comes to planning, building and installation.
Integrated cooling components include the Reservoir, D5 Pump Top, D5 Pump Cover, Fill Port, Drain Port and over half of the cooling loop. Cable management is also straightforward thanks to the included cable cover that means stock cables can be used in a clean configuration. Despite its compact size, the Wraith can fit full-sized GPUs, 2x 240mm radiators, 13x 2.5” drives and even a 3.5” drive and more. Just like the other Singularity cases, Wraith is modder friendly and every component can be completely disassembled with ease.
Wraith light display
Features
  • Distro-Plate and sides made from transparent acrylic glass and the graphics card can be displayed vertically.
  • The entire manifold glows with the addition of a single LED Strip.
  • Excellent storage options with 13x 2.5” and 1x 3.5” drive capacity.
  • Uses gaskets instead of O-rings for increased durability.
  • Can hold two 30mm x 240mm radiators at the same time.
BUY NOW
Event Horizon Wraith PC Build
Resonance Dual image
Resonance Single and Dual pump & reservoir combos
The resonance is a new take on the pump and reservoir combination which greatly increases versatility compared to traditional options. Resonance Single has an integrated Reservoir, D5 Pump Top, D5 Pump Cover, and parts of the loop. Resonance Dual has 2 integrated reservoirs and space for 2 D5 Pumps which means it can be used for Single Loop, Single Loop with Dual Pumps, or Dual Loops. A vast number of loop routing options are possible with up to 8 Inlets and 3 Outlets
Each one is constructed with precision and the CNC milled aluminum mounting system with 3 axis adjustment ensures maximum compatibility in the tightest builds. A universal 120/140mm backplate with 6 horizontal adjustment positions allows direct to radiator mounting for installation in a range of cases. There is also over 150mm of vertical adjustment to align ports for maximum compatibility and freedom. The built-in fill, drain, and accessory ports make installation and maintenance straightforward.
Resonance single image
Features
  • High-performance flow-optimized design.
  • Fits onto any 120mm or 140mm wide radiator. Optimized for 240mm, 280mm, 360mm and 420mm radiator lengths.
  • Included RGB and UV Lighting make many colors and effects possible.
  • Large adjustment range for fitting into tight spaces and aligning ports.
  • Over-engineered for maximum strength and lifespan.
Resonance Features & Design
Protium Ultimate Image
Protium Ultimate pump & reservoir combo
The Protium Ultimate is unmatched in quality and versatility. It is designed to be a stand out feature in any build while also increasing performance and allowing for multiple mounting, inlet, and outlet options. This pump res combo is minimalistic and compact but at the same time provides unprecedented options and compatibility. There is the option of Crystal clear polished acrylic or stealthy black Acetyl.
It features 7x 90-degree ports and full 270-degree rotation so that it can be mounted to face three different directions. The spare ports can be used for temperature sensors, fill and drain. The included 120/140 backplate means it can be mounted directly to any 120mm or 140mm wide radiator or fan mounting position. The option of up to 12 increments and 140mm of horizontal adjustment means that you can offset the combo across the radiator for an improved fit.
Features
  • Reservoir Cap can be rotated 360 degrees to face any direction.
  • Precision Machined Components from a solid block of high-quality materials.
  • 3mm LED mounting holes in the acrylic version on Reservoir Cap and Pump Top.
  • Aluminum Reservoir Retention Ring for increased durability of Reservoir Tube & O-Rings.
  • Direct to radiator mounting system with many mounting options.
  • Includes the Singularity D5 PWM Pump.
Protium Design & Assembly
Spectre 2.0 Elite front manifold
Spectre 2.0 Elite Kit
Take your Spectre to the next level with additional manifolds. The Spectre 2.0 elite kit is a large distro plate optimised for the Spectre 2.0 case. It acts as a replacement for the entire front panel of Spectre and can be mounted on the included anodized aluminum bracket on the front of the Spectre 2.0 case. It mounts in front of the front of a 360 mm radiator that can then be attached to the rear of the bracket. The inlet and outlet for the manifold is at the top and is accessible above the front 360mm radiator.
It’s made of transparent acrylic glass available in either black or white to match your chosen colour scheme. There is still plenty of ventilation for the front fans and radiator via a CNC machined spacer which runs around the entire perimeter of the manifold. Connections can be made above the front 360mm radiator. This manifold serves an aesthetic purpose to add more character to your build and lighting can be added to make the manifold glow.
Spectre Front manifold
Features
  • Compatible with all 360mm radiators.
  • Constructed with CNC Machined Cast Acrylic.
  • Mounts in front of the front 360mm radiator and does not remove the radiator position.
  • Available in Black or white
  • Easy to install with the included mounting bracket
BUY NOW
PC build using the Spectre front manifold
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
