We’re back with five cracking deals in our Easter sale to help you save big on your gaming hardware, peripherals, and more.
Put down that chocolate egg and check out these top five deals below.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/Easter-Top-5-Deals-1024x1024.jpg)
ASUS GeForce RTX 4070 Dual OC White 12GB GDDR6X Graphics Card
Unlock eggs-cellent graphics and immersive gameplay with the ASUS GeForce RTX 4070 Graphics Card. Egg-quipped with powerful Ada Lovelace architecture and 5888 CUDA cores, this GPU will render all your favourite gaming worlds in stunning hyper-realistic quality. Cutting-edge RT and Tensor cores deliver you full compatibility with ray tracing and AI DLSS to enhance your gaming even further. Plus, its all-white aesthetic is sure to look cracking in any gaming PC.
- RTX 40 Series
- Ada Lovelace architecture
- 5888 CUDA cores
- 2550MHz boosted clock speed
- 12GB GDDR6X video memory
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/ASUSGeForce-4070-300x292.jpg)
Glorious Model D RGB Optical Black Gaming Mouse
Next up on our top five list is the Glorious Model D Optical Gaming Mouse. Crafted with an optical PixArt PMW 3360 sensor, all your flicks, clicks, and glides will be registered with eggs-trodinary precision. The max DPI of 12,000 and 1000Hz polling rate give you the competitive in-game edge thanks to ultra-fast response times and flawless tracking. What’s more, the ergonomic design ensures you’ll remain comfortable even during eggs-tended gaming sessions.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/Glorious-Modelo.jpg)
- Optical gaming mouse
- PixArt PMW 3360 sensor
- DPI of up to 12,000
- 1000Hz polling rate
- Ergonomic design
- Integrated RGB lighting
Corsair Vengeance RGB 32GB (2 x 16GB) EXPO DDR5 Dual-Channel RAM Kit
Wave goodbye to constant input lag or latency disrupting your gaming performance. The Corsair Vengeance RGB 32GB DDR5 RAM Kit delivers fast gaming at up to 6000MHz and minimal loading times. With integrated support for AMD EXPO, you can boost your speeds even further with dedicated overclocking tools for both beginners and veterans. Finally, the customisable RGB lighting adds an eggs-tra splash of colour to your PC.
- 32GB capacity (2 x 16GB modules)
- DDR5 standard
- Compatible with AMD EXPO
- Dual-channel configuration
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/CorsairVengeance-32GB-300x242.jpg)
Refract Gaming Celeste Pre-Built PC
Unlock eggs-tounding performance with the Refract Gaming Celeste Pre-Built PC. Harness the AMD Ryzen 7 7700X CPU, built with Zen 4 architecture, to enjoy ultra-fast processing power and seamless multitasking. The NVIDIA RTX 4070 renders your gaming in eggs-quisite detail with realistic lighting and shadows boosting your immersion. What’s more, thanks to 32GB of DDR5 RAM and 1TB M.2 SSD, enjoy quick loading times with near-zero latency. Plus, you’ll never need to worry about running out of precious storage space.
As an added bonus, the Refract Gaming Celeste is egg-quipped with a three-year warranty for eggs-tra protection and peace of mind.
![Refract Gaming Celeste 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-celeste-hero-300x300.jpg)
- Pre built PC
- Designed for mid-range gaming and streaming
- Includes AMD Ryzen 7 7700X CPU and NVIDIA RTX 4070
- 32GB DDR5 RAM and 1TB M.2 SSD
Nitro Concepts S300 EX Gaming Chair
Last up on our top five list is the Nitro Concepts S300 EX Gaming Chair. Constructed utilising premium-quality PU leather and cold foam upholstery, enjoy eggs-traordinary comfort. The deform-resistant padding retains its shape, keeping that factory-fresh look and feel for longer. Integrated ergonomics, such as 3D armrests, allow you to fine-tune this gaming chair to perfectly suit your body shape and comfort demands. Lastly, the embroidered Nitro Concepts logo adds a touch of style to your set-up, whilst the all-black design ensures it will blend seamlessly into any eggs-thetic.
- Constructed from PU leather and cold foam upholstery
- Deform-resistant padding
- Adjustable ergonomics
- 3D armrests
- Nitro Concepts flame logo embroidery
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/NitroConcepts-S300-240x300.jpg)
Crack Open Some More Deals
Want to crack open even more tasty deals? Check out the rest of the big savings on offer in our Easter sale by clicking the button below.
In the meantime, if you have got your hands on a cheeky upgrade or two in the sale, let us know in the comments.
*Prices correct at time of writing and PC specs are subject to change.
