Baldur’s Gate 3 is rapidly becoming everyone’s favourite Dungeons & Dragons inspired RPG. Its three-year-long early access period left us waiting on the edge of our seats to finally get our hands on its official full release. Now that it’s finally here, is your set up ready to embark on this thrilling adventure through the Forgotten Realms?
We see you glancing at your tired-looking set-up, wondering if your gaming mouse is capable of handling all those fast mouse movements and clicks that the turn-based combat system requires. You can push those doubts to the back of your mind, as we’ve selected our top five gaming mice that are perfect for playing Baldur’s Gate 3.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/Mice-for-Baldurs-Gate-3-1024x1024.jpg)
Baldur’s Gate 3
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/BaldursGateIII-coverart-300x295.jpg)
Set in the Forgotten Realms, after becoming infected by a deadly Mind Flayer parasite, your inner corruption is rapidly growing by the second. As corruption grows, so does your power, which might just be the key to your survival. Or propel you further into the grips of darkness and evil. Your own inner conflict and the one between the devils and deities will push you to the brink, forcing you to make complex decisions that might just alter the future forever.
Craft the perfect character by selecting from several different classes and D&D races. Each of which features its own personality, interactions, abilities, and weaponry. As you venture through the Forgotten Realms, you’ll need to uncover its dark secrets, hone your unique skills, and perfect the D&D 5e turned-based combat.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/BaldursGate3-combat-1024x576.jpg)
Want to read more about the D&D inspired gameplay? Check out our dedicated Baldur’s Gate 3 guide for all the juicy gameplay tidbits you need.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/Baldurs-Gate-3-1024x1024.jpg)
What Kind of Mouse Should I Buy for Baldur’s Gate 3?
As a turn-based RPG, Baldur’s Gate 3 features a complex combat system that requires plenty of fast mouse movements and clicks. Plus, its engaging, ever-changing gameplay often results in us spending a bit too much time engrossed at our desks.
As a result, we recommend you invest in a gaming mouse that comes equipped with high-quality switches, smooth mouse feet to glide across your desk, plenty of programmable buttons for all your on-the-fly commands, along with a lightweight and ergonomic construction to keep you comfortable for longer.
![Your Guide to Gaming Mice](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/your-guide-to-mice-300x300.png)
Don’t know which gaming mouse is the right one for your set up? Stuck on all the gaming mice terminology like sensor types, polling rate, DPI, and more? Our dedicated guide to gaming mice has all the information you need to help you pick out your next gaming mouse.
Our Top Five Gaming Mice!
Is your gaming mouse tired and not up to the task of defeating the Mind Flayer parasite? Why not treat yourself and upgrade to one of our top five gaming mice, that are perfect for playing Baldur’s Gate 3? If none of these suit your individual preferences, you can shop the entire range by clicking the button below.
Corsair Harpoon RGB Pro FPS/MOBA Gaming Mouse:
Stand strong against corruption with the Corsair Harpoon RGB Pro FPS/MOBA Gaming Mouse. Built utilising a lightweight construction and weighing only 85g, this gaming mouse is the perfect companion to your adventures across the Forgotten Realms. Armed with high-performance optical sensor, powerful Omron switches, and a DPI of up to 12,000, unlock superior control and precision over all your mouse movements. Plus, with six programmable buttons, you’ll gain a distinct advantage over your enemies, as you easily configure macros or button remaps for on-the-fly commands.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/Corsair-Harpoon-RGPro-300x289.jpg)
- MOBA gaming mouse
- Optical PMW 3327 sensor
- Up to 12,000 DPI
- Six programmable buttons
- RGB backlighting
ASUS ROG Gladius III Optical Gaming Mouse:
Armed with the ASUS ROG Gladius III Optical Gaming Mouse, you’ll have everything you need in your arsenal to resist the Mind Flayer in Baldur’s Gate 3. This includes a fine-tuned DPI of up to 26,000, a 1000Hz polling rate, and up to 50G acceleration to track all your mouse movements at record speed with complete control. What’s more, thanks to the exclusive Push-Fit Switch Socket II design, the ASUS ROG Gladius III boasts intelligent hot-swappable capability. You can flick between mechanical, Ormon, and even ROG Micro switches, to perfectly suit your gameplay style, for an enhanced gaming performance.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/ASUSROG-GladiusIII-242x300.jpg)
- Wireless gaming mouse
- Up to 26,000 DPI
- 1000Hz polling rate
- 2.4GHz connectivity
- Up to 55 hours of battery life (85 via Bluetooth connectivity)
Endgame Gear XM1-RGB USB Optical Gaming Mouse:
Designed and developed by gaming professionals, the Endgame Gear XM1 Optical Gaming Mouse is the perfect addition to your party in Baldur’s Gate 3. Harness its lightweight construction, flagship Pixart PMW3389 sensor, and premium Kalih GM 4.0 mechanical switches, to enjoy ultra-fast responsiveness with virtually zero latency, for an optimised gaming experience. Paired with the PTFE low-friction mouse feet, the Endgame Gear XM1 will effortlessly glide across any surface.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/EndgameGear-XM1-RGB-273x300.jpg)
- Pixart PMW 3389 optical sensor
- Mechanical Kalih GM 4.0 switches
- PTFE low-friction mouse feet
- Up to 16,000 DPI
- Adjustable polling rate
Glorious Model O Odin USB Optical Gaming Mouse:
Hone your inner wild shape with the Glorious Model O Odin Optical Gaming Mouse. The high-quality Pixart PMW 3360 sensor, Omron mechanical switches, and a DPI of up to 12,000, all deliver you exceptional control and precision over your fast turned-based mouse movements. What’s more, the combination of G-skate mouse feet and the flexible wired cord all ensure the Glorious Model O seamlessly glides across your desk, without any cable snagging or bunching.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/Glorious-ModelO-300x296.jpg)
- Lightweight construction
- PMW 3360 sensor
- Up to 12,000 DPI
- 50G acceleration
- G-skate mouse feet
Logitech G502 HERO High-Performance Gaming Mouse:
Explore every corner of the Forgotten Realm in ultra-high speed and precision thanks to the Logitech G502 HERO Gaming Mouse. Built utilising a cutting-edge HERO 16K optical sensor, unlock maximum tracking, control, and responsive gaming, that is sure to prove advantageous during the height of battle. What’s more, with a customisable DPI of up to 16,000 and eleven programmable buttons, you can configure the Logitech G502 to perfectly suit your gameplay needs and on-the-fly gaming. Plus, thanks to the intelligent tuneable weight system, you can adjust the weight distribution, to ensure you enjoy maximum performance and comfort, even during the longest gaming marathons.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/Logitech-G502-219x300.jpg)
- HERO 16K optical sensor
- Up to 16,000 DPI
- Eleven programmable buttons
- Customisable weight distribution
- RGB lighting
Your Baldur’s Gate 3 Top Tips?
Got any tips for your fellow Baldur’s Gate 3 players? Which gaming mice are you using to play this popular RPG? Leave a comment down below.
