We all want to make sure our gaming set-ups have the best accessories. But can it be done on a budget? In this post, we’re looking at budget-friendly gaming accessories!
In fact, we have ten tasty products to showcase in this article and a few pointers on how to bag a bargain. As accessories can be used to enhance a variety of needs, our top ten will reflect this. From basic peripherals to specialised sim hardware, there is a budget-friendly accessory to suit your set-up!
How to Find Budget-Friendly Accessories
Hunting for a budget-friendly gaming accessory is more than finding the cheapest product on the Overclockers UK website. You still need the hardware to meet your requirements, and sometimes the cheaper products just don’t offer the features you’re after. It’s all about finding a product that is functional and affordable.
We have a couple tips to help narrow down your search – and we’d love to hear yours if you have any to share!
First, take advantage of our Price Filter function. Found in the side bar, you can use this to set a max price limit on any category you’re browsing. This will then only show products within your price range, helping to keep you on budget by removing all those expensive temptations! From here, you can easily compare and contrast the products available and find the best one for you.
Alternatively, you can explore our deals, clearance, and B-Grade selections. While these might not offer our full ranges, you can score a premium product with a budget-friendly price tag, if you get lucky. To explore our dedicated deals and clearance pages, we have supplied the links below. For B-Grade products, you can toggle the categories you’re browsing to show what’s available using the tick box in the side bar or use the link below.
We have an article chock-full of savvy spending tips, if you’d like to learn more.
Top Ten Budget-Friendly Accessories
There are accessories to suit every gaming need out there. We’re going to cover our bases with your standard gaming keyboard, mouse, and headset, then move onto more specialist accessories for streaming and simulation gaming. Of course, this is just a snapshot of what’s available on the Overclockers UK website, so we’ll include links to our full ranges for you to browse.
Razer Ornata V3 X Mecha-Membrane Gaming Keyboard
The Razer Ornata V3 X is a full-sized gaming keyboard with mecha-membrane switches, customisable RGB lighting, and an ergonomic low-profile design. The mecha-membrane switches offer a cushioned, quiet typing experience, while the 6-key rollover, 1000Hz polling rate, and dedicated gaming mode provide the performance you need to dominate. What’s more, the keys are fully programmable with on-the-fly macro recording and Razer Synapse support. Tailor this gaming keyboard to suit your needs and save a pretty penny!
ASUS TUF Gaming M3 Gen II Gaming Mouse
If a product is on its second generation, then you know the first served its gamers well! The ASUS TUF Gaming M3 Gen II Gaming Mouse delivers great performance in an ultralight shell. Equipped with an 8000 DPI optical sensor, switches rated for 60 million clicks, and PTFE skates, this mouse will facilitate pixel-precise gaming for many a session to come! Plus, the six programmable buttons will enable you to map in-game functions across three memory profiles.
Logitech G G332 Gaming Headset
Logitech is a staple brand in gaming circles. Their G G332 Gaming Headset perfectly balances premium features with an accessible price tag. The 50mm drivers deliver immersive soundscapes on all your favourite games, while the on-ear volume wheel puts control at your fingertips. What’s more, the microphone has flip-to-mute functionality and the 3.5mm audio jack is compatible with a range of platforms. Spicy!
Streamplify CAM HD Webcam
Moving onto more specialised hardware, the Streamplify CAM HD Webcam is perfect for those just starting their streaming career. It captures footage in 1080p at 60FPS, has dual-microphones, and features like auto-focus, so this webcam always gets your best side. All this and a tasty price! Plus, the Streamplify CAM comes with both a versatile clip and tripod with anti-shock rubber feet, so it will seamlessly integrate with your streaming set-up.
Streamplify LIGHT 10 Ring Light
Just like the CAM, the Streamplify LIGHT 10 is an accessibly priced streaming accessory. (In fact, the whole Streamplify range is worth checking out if you’re new to streaming!) This ring light is 10” in diameter and can illuminate your streaming set-up in three colour temperatures and ten brightness levels. Say goodbye to gloomy shadows and badly lit rooms on screen! What’s more, the smartphone holder and tripod enable you to use this ring light for social content, too. Your next viral TikTok is just waiting to be filmed.
Streamplify MIC RGB Microphone and Tripod
Further proving my previous point, our microphone pick is the Streamplify MIC. Equipped with a pop filter, tripod, and a splash of RGB lighting, this cardioid microphone is the perfect budget-friendly addition to your streaming set-up. It will pick up your voice with crystal clarity and can be used in Full or One Way Playback modes, depending on your needs. Plus, with a quick mute function and volume wheel, you have full control at your fingertips.
Thrustmaster T.Flight Hotas X Flight Controller Joystick and Throttle
Whether you’re taking to the skies for the first time or building a flight sim set-up on a budget, you don’t have to sink big bucks into your hardware. The Thrustmaster T.Flight Hotas X Flight Controller delivers realistic gaming without breaking the bank. This controller set includes both a joystick and throttle, which can be detached. Featuring plug and play functionality, you don’t need to download any complex software or configure the hardware – simply boot up your favourite flight sim and take off!
Thrustmaster T80 Ferrari 488 GTB Edition Steering Wheel
You don’t need a full rig to enjoy the thrills of sim racing (though, we recommend Nitro Concepts Sim Racing range if you disagree!). The Thrustmaster T80 Ferrari 488 GTB Edition Steering Wheel comes with an officially licenced Ferrari racing wheel and dual pedal set, the core components of any racing sim rig. The wheel has realistic linear wheel resistance with automatic re-centring and mounted sequential paddle shifters for a smooth driving experience. To enhance ergonomics, the pedals have a wide footrest and an adjustable angle of inclination. Time to hit the pedal to the metal!
BitFenix Alchemy 2.0 Magnetic Connect 15 LED-Strip
Everything is better with RGB lighting. With the BitFenix Alchemy 2.0 LED Strip, you can spruce up your gaming desk, PC, or even the walls around your set-up with a splash of colour. This 30cm strip has fifteen vibrant green LEDs with BitFenix TriBright technology, making them incredibly bright. Utilising powerful magnets, the BitFenix Alchemy will effortlessly integrate on any magnetic surface and can be moved around as needed. Better yet, this LED strip has daisy chaining capabilities, so you can add more lighting as and when your budget allows!
Streamplify HUB CTRL 7 USB Hub
Most gaming accessories require a USB port. Even if you’re only getting a few, you’re going to need a little help. Enter the Streamplify HUB CTRL 7. This is a seven-port USB hub with swappable acrylic icons, RGB lighting, and power LED indicators. Plus, that sweet low price tag. Better yet, one of the ports is equipped with power charging and a cable tidy is included to keep everything contained. The Streamplify HUB CTRL 7 is every gaming set-up’s MVP.
More Budget Buys
Looking for more upgrades on a budget? We got you, boo.
What Are Your Budget Hacks?
How do you get the hardware you want while still sticking to your budget? Drop your handy tips in the comments below!
