A new gaming PC is hitting our virtual shelves: the Infin8 Sanctuary.
Equipped with high-performance gaming hardware, a custom water-cooling loop, and the slickest good looks out there, the Infin8 Sanctuary belongs in all our game set-ups. We’ve got a full spec breakdown for you, plus plenty of pictures to get those eyes all heart shaped.
Infin8 Sanctuary
The Infin8 Sanctuary is the latest overclocked gaming PC inspired by the hench 8Pack Extreme PCs. Sporting a cool white aesthetic, an AMD Ryzen 9000 Series processor, and all the high-performance tech you could want, this PC is a beast.
Specifications |
ASRock Taichi X670E AM5 motherboard |
AMD Ryzen 9 9900X CPU |
NVIDIA GeForce RTX 4090 GPU |
32GB DDR5 5600MHz RAM |
Corsair Force MP700 1TB M.2 SSD |
1200W 80 PLUS Platinum PSU |
HAVN HS 420 PC case |
Sanctity of Gaming
As you can see on the above table, the Infin8 Sanctuary has some juicy specs. From the powerhouse RTX 4090 to bleeding-edge AMD Ryzen 9000 CPU, this gaming PC is primed to deliver elite-tier gaming, creative work, and streaming. Plus, the HAVN HS 420 PC case is just *chef’s kiss*
The Infin8 Sanctuary’s foundation is the ASRock Taichi X670E AM5 motherboard, providing support for DDR5 and PCIe 5.0. Plus, that AM5 socket is the perfect home for the AMD Ryzen 9 9900X CPU. Powered by Zen 5 architecture, this processor harnesses twelve cores and twenty-four threads to expertly manage all your single- and multi-threaded loads. Better yet, it has been professionally tuned with PBO2 to ensure the best performance from your silicon. Tasty stuff.
For all your gaming and content needs, the NVIDIA GeForce RTX 4090 GPU delivers titan-class performance. Nothing short of what you’d expect from a flagship model graphics card, really. The Ada Lovelace architecture is packed with NVIDIA innovations to render your games in crisp detail, with realistic lighting, and stunning resolutions. Plus, it packs the power to handle any workload you can throw at it. AAA gaming at 4K? Yup. Streaming high-action games? You betcha. Seamless video editing? Check!
Keeping all operations running smoothly is the 32GB DDR5 5600MHz RAM. Tight timings and fast fetch rates facilitate incredible efficiency, whatever the workload. Latency? Who is that? Better yet, you can increase the RAM capacity, so the Infin8 Sanctuary can keep up with any intensive workload.
Storage and Power
To ensure you have ample space for all your games, apps, and media, the Infin8 Sanctuary is equipped with a Corsair Force MP700 1TB M.2 SSD. The shining feature of this solid state drive is it utilises PCIe 5.0 technology, which results in some blinding read and write speeds. Enjoy gaming and creating on 11,700MB/s read and 9600MB/s write speeds. Slow boot times and loading screens are a thing of the past! What’s more, if 1TB isn’t enough space for you, there are higher capacity and additional drive options.
Finally, the Infin8 Sanctuary is powered by a 1200W 80 PLUS Platinum PSU. That’s plenty of headroom for all your premium hardware and 90% efficiency at half load, in one handy package. Plus, power is delivered by CableMod RT Series Pro ModMesh sleeved cables that have been colour-matched to the Infin8 Sanctuary’s cool white vibes. What more could you want?
Sleek Cooling
One of the features we love about Infin8 gaming PCs is their impressive cooling solutions.
Bringing efficient cooling and stunning good looks in equal measures, you’d be mad to not agree. This sleek water-cooling loop features hardware from EK Water Blocks, Optimus, and TechForge, all illuminated by fresh white lighting.
The star of the show is the bespoke TechForge distro plate mounted to the motherboard’s side. The clear coolant lets the lighting shine through, while the Infin8 and HAVN branding mark this gaming PC with a touch of class. To keep up with the high-performance hardware, two 420mm radiators dissipate the heat drawn away from the vital components. This is boosted by a total of eight Phanteks D30 140mm PWM fans, installed across the chassis. A mix of standard and reverse blade models are used, optimising airflow and creating a unified look. Fresh!
Introducing the Infin8 Sanctuary | The All White Water-Cooled PC In The HAVN HS 420
Upgrade Your Set-Up
The Infin8 Sanctuary is available – right now! – at Overclockers UK. Will you be upgrading?
Infin8 Sanctuary Gaming PC
- Water-cooling gaming PC in a HAVN HS 420 PC case
- AMD Ryzen 9 9900X CPU
- NVIDIA GeForce RTX 4090 GPU
- 32GB DDR5 5600MHz RAM
- Corsair Force MP700 1TB M.2 SSD
Stay Up to Date!
Keep your finger on the pulse for all things tech, by signing up to our Newsletter!
