Desk space has always been a premium. Whether your desk serves as a battle station or the heart of your WFH office, there is always something cluttering the surface. Between your monitor, peripherals, that important piece of mail you have steadfastly been ignoring, and your collection of gaming minis, there is nowhere safe to place your cup of tea. It is in an OcUK Extreme Mug after all. Kolink has the answer to your space-saving prayers, with their new M32G9SS Monitor Mounts.
![Kolink M32G9SS-2 Dual Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/M32G9SS-2_Scene-long-1.jpg.webp)
One Arm or Two?
In this range, there are two monitor mounts to choose from: a single or double arm model. Understandably, the M32G9SS Single Monitor Mount can hold one screen whereas the M32G9SS Dual holds two. Both models are manufactured from highly durable materials, including aluminium and steel, to create a strong product that will stand the test of time. Here is a quick breakdown of their specs:
Kolink M32G9SS-1 Single Monitor Mount
![Kolink M32G9SS-1 Single Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/kolink-M32G9SSx1x01.jpg.webp)
Specification |
Single-arm monitor mount |
Supports monitors between 17″ and 32″ |
VESA compatible |
Gas spring |
Three jointed arm |
![Kolink M32G9SS-2 Dual Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/kolink-M32G9SS-2-02.jpg.webp)
Specification |
Dual-arm monitor mount |
Supports two screens between 17″ and 32″ |
VESA compatible |
Gas spring in each arm |
Both arms have three joints |
How Does This Save Me Space?
With its clever and innovative design, the M32G9SS mounts clamp directly onto your desk, immediately freeing up whatever space your monitor used to take. They work like this whether your desk is freestanding or pushed flush to the wall. Juicy.
For enhanced flexibility, the arm is made of three joints connecting four sections: the base, the main body, a short top element, and a Quick Release VESA Plate.
![Kolink M32G9SS-1 Single Monitor Mount showing joints](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/kolink-M32G9SSx1x04.jpg.webp)
Interchangeable between clamp or grommet, the base is naturally how you attach the mount to your desk. Both are easy to affix and use to secure the mount in place. Next, the main body features a gas spring which can be used to smoothly adjust the height of your monitor. The shorter top element was so designed as it enables you to attach the arm further back on your desk, thus saving you more space. Finally, the Quick Release VESA Plate, compatible with both 75 x 75 and 100 x 100 models, makes it incredibly simple to swap, upgrade, and remount your monitors. In the case of the M32G9SS Dual, there are two arms sprouting from the singular clamp.
What Monitors Can They Hold?
As you would expect, this is a very important aspect of considering a monitor mount. Both models of M32G9SS Monitor Mounts can support screens between 17” and 32”, with each arm able to hold up to 9kg in weight. As this is the average weight of a 32” monitor, you’re pretty sorted. Fancy going for a curved monitor? Do it! This mount can support those, too.
One of the best features with the M32G9SS Monitor Mount range, is just how flexible they are. These mounts facilitate many configurations when it comes to arranging monitors for your desk. For your convenience, they can swivel, rotate, and tilt to place your monitor in the most comfortable position for you. If you would like to know why that is important, read our article on back care here.
When it comes to the swivel, these monitor mounts have a range of 180-degrees which can be capped at 90-degrees via the integrated limit screws. Just in case there is anything nearby you don’t want to hit on your monitor. With rotating, there are no limits, horizontal, vertical, upside-down, anything goes. Finally, these mounts allow you to tilt your screen 45-degrees either up or down, for that perfect viewing angle.
![Kolink M32G9SS-1 Single Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/M32G9SS-1_Scene.jpg.webp)
What Can I Keep on My Desk, Now I Have All This Free Space?
Well, as someone who never has less than two pen pots, an A4 notepad, and a cup of coffee on her desk, here is just some of the stuff you can put down now you have the free space.
![Close crop of plants on Briony's desk](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/briony-desk-3-close-crop.png.webp)
![The Glorious Vinyl Panda in blue and purple lighting.](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/03/Glorious-Panda-Toy-1024x1024.jpg.webp)
- A plant, oxygen is a must. Just be careful when you water it, water and electronics don’t generally mix.
- A third pen pot. You can never have too many pens.
- Some artwork from your favourite Etsy shop. Support small businesses!
- Cake. I shouldn’t have to explain this one.
- Desk buddy figurine(s). A Glorious Vinyl Panda, a Funko POP! from your fave TV show, a collector’s item from your favourite game. It’s your desk, decorate it how you like!
- A fancy lamp. One of them had to be sensible.
![Briony's desk](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/briony-desk-2-1024x775.jpg.webp)
Save on Space Now
Both the Kolink M32G9SS Single and Dual Monitor Mounts are available now at Overclockers UK. Get them in your basket and let me know what you’re filling your newfound desk space with! I wonder if I will have room for a plushie narwhal…
Kolink M32G9SS Single Monitor Mount
- Durable materials including steel and aluminium
- Extends up to 440mm
- Gas spring for height adjustment
- Matte black finish
- Extensive configuration options
![Kolink M32G9SS Single Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/kolink-M32G9SSx1x05.jpg.webp)
![Kolink M32G9SS Dual Monitor Mount](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/kolink-M32G9SS-2-01.jpg.webp)
- Dual-arm monitor mount
- VESA compatible, 75 x 75 and 100 x 100
- Each arm holds up to 9kg
- Support for curved monitors
- Clamp and grommets included
