Another year, another chance to show your significant other how much they mean to you with high-quality gaming peripherals! Our 2023 Valentine’s Day Gift Guide has everything you need to make this Valentine’s Day the best one yet!
Valentine’s Day is fast approaching. Now, whilst buying a fully equipped gaming PC might be a little extreme, nothing says “I love you” like supporting your significant other’s hobbies, careers, and interests. At Overclockers UK, we have an extensive range of gaming hardware, accessories, and PC must-haves that you can gift to the PC gamer or enthusiast in your life. Cupid fires 8-bit arrows around these parts!
Sparks Fly
Telling your crush how you feel is scary, difficult, and downright nerve-wracking. We can’t guarantee success, but we do have a couple suggestions to help get your point across. This Valentine’s, take the plunge and find your happy ever after!
BitFenix Alchemy 2.0 RGB LED Strip
Specification |
30cm long |
Asus Aura compatible |
15 TriBright LEDs |
4-pin connector for RGB controller or Asus motherboard |
Flexible installation – magnets and adhesive tape |
Daisy chain compatible |
Your crush lights up your life, now it’s time to light up theirs. With the BitFenix Alchemy 2.0 RGB LED Strip, you are equipping your crush’s PC with incredibly vivid lighting. Each of the fifteen LEDs utilises TriBright technology, equipping every LED with three diodes for the brightest illumination. Powered by Asus Aura, this RGB strip has command over the full 16.8 million colour spectrum – perfect for setting the mood lighting. Installation is both easy and flexible, not only is there a choice between adhesive tape or magnets but the six magnets can be manoeuvred to best suit your crush’s PC. With its 4-pin connector, this RGB strip can be connected via an RGB controller hub or directly into an Asus Aura compatible motherboard. Even better, it can be daisy-chained should the need for expansion arise.
To learn more about the BitFenix Alchemy 2.0:
To explore our full range of RGB case lighting:
Overclockers UK Extreme Gaming Mug XL
Specification |
450ml capacity for long gaming sessions |
TeaSync technology optimising drinking experience |
Wide handle with improved stability |
Heavy-duty build quality for maximum drink compatibility |
Non-slip matte finish for excellent grip |
HBM technology |
Gifting your crush the OcUK Extreme Gaming Mug not only tells them you know about their favourite shop, but also that you understand the extreme demands of gaming sessions. Hydration is key! What better way to stay hydrated than with an XL mug, perfect for both hot and cold drinks. The wide handle offers great stability as well as great hand-feel. Plus, with its non-slip, matte finish there will be no accidental spills. Let your crush sip in safety this Valentine’s.
To explore our full range of gaming and OcUK merch:
Upgrade Their Gaming
If you’ve been with your partner for a while now, why not treat them to an upgrade for their gaming experience this Valentine’s? With better tech and accessories to optimise comfort, you are gifting them better gameplay with the cheeky bonus of preventing aches and pains.
Razer Power Up Bundle
Specification |
Cynosa Lite Mechanical Keyboard |
Gigantus V2 Large Gaming Surface |
DeathAdder Essential Gaming Mouse |
BlackShark V2 X Gaming Headset |
Complete peripheral bundle out of the box |
Compatible with Razer Synapse 3 |
With this peripheral bundle, you are gifting your partner powerful gaming performance out of the box. There’s a keyboard, mouse, mouse mat, and headset in this bundle – the perfect arsenal for work and play. The Cynosa Lite mechanical keyboard is equipped with gaming-grade, soft cushioned switches for incredible feedback when gaming or typing. Plus, with dedicated media keys and fully programmable keys, this keyboard can be personalised to meet your partner’s exact specification.
Sporting an optical sensor, the DeathAdder Essential is a highly responsive mouse with 6,400 DPI. Its ergonomic form fits neatly under the hand, promoting comfort and designed for long usage. Paired with the Gigantus V2 Gaming Surface, you have the recipe for unparalleled performance. Utilising a micro-weave cloth surface, this mouse mat facilitates fluid movement and pixel precision. Padded with high-density rubber foam and an anti-slip base, the Gigantus V2 covers all imperfections and won’t budge.
Finally, the BlackShark V2 X is a highly comfortable headset that delivers an immersive soundscape, whether gaming or listening to your favourite playlist. The Razer TriForce 50mm drivers create directional audio cues with a rich, warm, and balanced sound. What’s more, the microphone utilises a cardioid pick up pattern, with advanced passive noise cancellation, so no one on the other end can hear you asking your partner if they need more snacks. (Love, if you’re reading this, yes, I want more snacks.)
To learn more about the Razer Power Up Bundle:
To explore our full range of peripheral bundles:
Gunnar Optiks Lightning Bolt 360 Gaming Eyewear
Specification |
Onyx coloured frame |
Amber tinted lenses |
Additional sun lenses for outdoor use |
Ergonomically designed |
Reduces harmful artificial blue light by 65% |
Lightweight |
Spending a long time sat in front of a screen can be harmful on your eyes. Why not show your partner you care, by gifting them some protection. Stylish protection at that, too! With Gunnar Optiks Gaming Eyewear, headaches and eye strain are drastically reduced. Screen downtime will no longer be plagued by splitting headaches. Chosen here is the Lightning Bolt 360 model, with its Onyx colour and full rim frame. The full range has varying styles, but they all effectively reduce harmful blue light by up to 65%. There is a pair of Gunnar Optiks to suit everyone. Even better, they are easy to find with the Gunnar Virtual Try On Tool! Look stylish this Valentine’s!
To learn more about the Gunnar Optiks Lighting Bolt 360:
To explore the Gunnar Optiks Gaming Eyewear range:
Long Distance Love
Sadly, not all of us get to spend time face to face this Valentine’s. Whether you’re on different continents or lockdown tiers, we have the solution. Say goodbye to blurry video calls with tinny audio and say hello to Streamplify. Professional quality streaming gear with an accessible price point is the best way to level up your Zoom dates.
Streamplify CAM Full HD Webcam
Specification |
2.0 megapixel camera with Full HD resolution |
60Hz refresh rate for smooth capture |
Plug and play – no drivers required |
Integrated dual-microphone |
Versatile clip compatible with laptops, monitors, and more |
All glass lens with autofocus |
The Streamplify CAM Full HD Webcam is a versatile device, that can attach to the top of your monitor or stand free on the included tripod. Its all-glass lens captures in 1080p Full HD with its 2.0-megapixel camera. The auto-focus keeps subject matter crisp and clear, whilst the 90-degree field of view creates the perfect showcase. Plus, with the dual integrated microphones even without a dedicated mic, you have amazing quality audio for whispering sweet nothings to your beloved this Valentine’s. Alternatively…
Streamplify STARTER Bundle
Specification |
Streaming hardware bundle |
CAM Full HD Webcam |
MIC TRIPOD Microphone |
LIGHT 10 Ring Light |
Plug and play – no drivers required! |
RGB lighting |
… Go all in! If you’re upgrading the webcam, why not get a dedicated microphone and a ring light to go with it. This streaming starter bundle is the perfect way to level up your video calls – be they long-distance dates or work calls! As well as the CAM Full HD Webcam, you get the MIC TRIPOD Microphone and LIGHT 10 Ring Light.
With its cardioid pick-up pattern and included pop filter, the Streamplify MIC TRIPOD picks up crystal clear audio and offers two recording modes to suit your long-distance love’s needs. What’s more, a stylish splash of RGB lighting will add a spot of mood lighting on your date. Adding the Streamplify LIGHT 10 Ring Light into the mix will perfectly illuminate your date, at one of ten brightness levels and three colour temperatures. This ring light even features a smartphone holder if your other half will be away from the computer next date night.
To learn more about the Streamplify CAM Full HD Webcam:
To learn more about the Streamplify STARTER Bundle:
To explore the full Streamplify range:
Celebrate Your Soulmate
If your soulmate is a gamer, why not celebrate their passion? Get them a gift that says “I love you and your gaming habits” for Valentine’s Day this year. For better or worse, ‘til screen death do us part.
LG 24GN600-B Widescreen Gaming Monitor
Specification |
1920 x 1080 display resolution |
24” screen with 144Hz refresh rate |
IPS panel type |
Compatible with FreeSync technology |
Features VESA 100 mount area |
DisplayPort and HDMI connectivity |
With a decent gaming monitor, you can be assured your soulmate is enjoying their favourite AAA title at its peak. Whether you are upgrading their existing monitor or equipping them with a second, there are no wrong answers. The LG 24GN600-B Widescreen Monitor is equipped with an IPS panel, which are known for their vivid colour and superior viewing angles. At 24”, this screen has a 1920 x 1080 display resolution with a 144Hz refresh rate, for amazing image quality. What’s more, it uses FreeSync technology, compatible with AMD graphics cards, for the smoothest performance. With image quality this great, you’re going to want some popcorn and to watch the game unfold!
Naturally, we have an extensive range of monitors at Overclockers UK. If you want something bigger, wider, brighter – we have it!
To learn more about the LG 24GN600-B Widescreen Gaming Monitor:
To explore the full range of gaming monitors:
Thrustmaster TMX Force Feedback Racing Wheel
Specification |
Realistic 11” racing wheel |
Compatible with PC and Xbox One, with official built-in buttons |
900-degree force feedback base |
Internal memory and upgradeable firmware |
Included pedal set |
Sequential paddle shifters |
Perhaps your soulmate has more niche gaming habits. For those who can’t get enough of racing simulators, then a hyper-realistic racing wheel is the way to go. With the Thrustmaster TMX Racing Wheel, you are getting an 11” steering wheel and pedal set that perfectly emulates the thrill of racing. The 900-degree force feedback base facilitates the authentic feel, as the 12-bit axis precisely tracks every turn of the wheel. With its mixed belt-pulley and gear system, you are gifting your soulmate the smoothest ride of their life.
What’s more, if their preferred vehicle is a plane, you can still cater for their passion. Overclockers UK stocks a range of flight sticks, instruments, and thrusters. Not even the sky is the limit when it comes to love.
To learn more about the Thrustmaster TMX Force Feedback Racing Wheel:
To learn more about racing simulator hardware and more:
WD Black SN850 1TB SSD
Specification |
1TB M.2 NVMe PCIe SSD |
2280 form factor |
Read speeds of 7000MB/s |
Write speeds of 5300MB/s |
600TB written |
PCIe 4.0 |
Whilst we are all about PC gaming, we do concede that sometimes it has to be consoles. Especially for those pesky must-have exclusive releases! If your soulmate was lucky enough to get their hands on a PS5, why not treat them to some extra storage space for all their favourite games. The WD Black SN850 SSD is the best drive to use when upgrading your PlayStation 5’s storage.
Not just the perfect shape and size, these solid state drives are incredibly fast and boast the higher capacities usually seen in traditional hard drives. With read and write speeds of 7000MB/s and 5300MB/s, respectively, slow loading times will be a thing of the past. Utilising PCIe 4.0 technology, this SSD has been optimised for gameplay.
Upgrading the PS5 is a piece of cake, too, thanks to the Overclockers Academy. You can check out Briony’s very helpful installation video here. The accompanying article drops this Thursday (10/2/22), too! UPDATE: The article is live, here.
To learn more about the WD Black SN850 SSD:
To explore our range of M.2 SSDs:
Your True Ride or Die
Whether you’re hitched or flying solo, everyone needs to spare a little love for themselves. There is absolutely every reason to treat yourself, too! Especially at Valentine’s. This is important, and I won’t hear otherwise. So, look at these gadgets and feel inspired to be kind to yourself.
Oculus Quest 2 All-in-One Headset
Specification |
All-in-One gaming headset with PC compatibility |
Comfortable headset with high-res display |
Ultra sensitive Oculus Touch controllers |
Headset casting to Oculus app or compatible TV |
50% more pixels than original headset |
3D cinematic sound for full immersion |
Take yourself on a “Me Date” and go anywhere in the virtual reality! With an Oculus Quest 2 All-in-One Headset, you don’t even need a PC to play. Everything you require is contained within the headset, including a juicy 128GB of storage. 3D cinematic sound and up to 50% more pixels than previous models, the Quest 2 takes immersive gaming to new heights. If you’re new to VR, do check out our top tips on the best way to use the Quest 2.
To learn more about Oculus Quest 2 All-in-One Headset:
To explore more VR hardware:
Lian Li O11D EVO Mid-Tower PC Case
Specification |
Modular mid-tower chassis |
Normal and Reverse Modes |
Grey aesthetic with integrated RGB lighting |
Three options for mounting the GPU |
Up to nine SSDs |
Excellent airflow with mesh panelling |
Alternatively, you can treat yourself to a cosmetic upgrade for your gaming PC. If your old mid-tower is getting you down, why not switch to something more dynamic? The Lian Li O11D range of mid-towers absolutely blows the mind with what they can achieve. The latest, the Lian Li O11D EVO, takes modularity to the next level. In addition to three GPU placements and multiple I/O panel placements, the entire case can be turned upside down and reversed. The careful balance of aluminium mesh and tempered glass panels creates amazing airflow whilst still showcasing all your hardware. Just imagine what you could achieve with this chassis!
To learn more about the Lian Li O11D EVO Grey:
To explore more PC cases:
EK Water Blocks
If you’re in the market to upgrade your water-cooling loop, why not treat yourself? You and your gaming PC deserve it. EK Water Blocks have the perfect Valentine’s Day offer, too. With qualifying purchases, you get 10% off and a free heart-shaped stress ball. Including custom kits and AiO coolers, you’re sure to curate an amazing water-cooling system with EK Water Blocks. Plus, who doesn’t love a cheeky freebie?! Hurry, this offer lasts only until the 21st!
Qualifying Custom Kits:
Qualifying AiO Coolers
To explore EK Water Blocks range:
Happily Ever After
We can’t talk about Valentine’s without those big-ticket gifts we wish we were getting and/or giving. The real fairy tale, grand gesture items. If this is your wheelhouse, take notes! Otherwise, it’s nice to dream.
noblechairs HERO Gaming Chair Black
Specification |
Sleek, all-black aesthetic |
Stainless steel frame with aluminium base |
Dense cold foam padding with PU leather upholstery |
Precise machine stitching |
60mm casters for soft and hard flooring |
Memory foam headrest |
What better way to tell someone they are your hero than with a noblechairs HERO? The HERO Gaming Chair is the pinnacle of comfort, with its dense foam padding and breathable PU leather upholstery. The stainless-steel frame supports a gaming chair with iconic design, sleek with its all-black aesthetic. With its superior ergonomic features and precision manufacturing, sitting in this chair is an utter thrill.
To learn more about the noblechairs HERO Gaming Chair Black:
To explore the full noblechairs range:
Intel Core i9-12900KF CPU
Specification |
16 cores: 8 P-Cores and 8 E-Cores |
Dual-channel DDR4/DDR5 controller |
Unlocked for overclocking |
No onboard graphics – GPU required |
5.2GHz Single Core Max Turbo |
Intel Thread Director software |
With next-gen tech, you are future-proofing your true love’s PC, giving them the equipment to defeat dragons yet to come! (Because these are the fairy tale options, get it?) With the Intel Core i9-12900KF processor, you get the elite tier of Intel’s latest CPU generation. DDR5 support, a blend of sixteen P- and E-Cores, and intelligent Thread Director software. That’s barely scratching the surface, too! With boost speeds up to 5.2GHz and a 30MB cache, this CPU has been primed for gaming and content creation. Plus, it is unlocked and ready to overclock!
To learn more about the Intel Core i9-12900KF CPU:
To explore 12th Generation Intel Alder Lake Processors:
Still Stumped?
Nothing catching the imagination? Left it a little too late for it to arrive in time? Less than tech-savvy and overwhelmed? Never fear, Valentine’s Day is not ruined. We have digital gift vouchers available in these denominations:
They can mixed and matched depending on how generous you are feeling! The gift voucher code is sent straight to your email inbox, ready to be printed off and slipped into a cutesy Valentine’s card. I’m a fan of the “I Choo-choo-choose You” card.
Feel the Love Valentine’s 2022
Here at Overclockers UK, we hope you’re feeling all loved up and have a great Valentine’s – however you celebrate it. Drop us a comment below if you’re gifting something techy to your significant other.
