You have your perfect build. You’re decked out with the best peripherals. But something is still missing? Don’t worry, Glorious PC Gaming Race have you covered. With a whole range of Glorious accessories available to pre-order, you can truly achieve peak PC enthusiast level.
What’s available?
Ranging from coiled cables to a switch lubing station to a vinyl panda; Glorious have truly thought of every need and supplied a solution. Take a deep dive with me, as we look at all of the Glorious goodies available to pre-order.
Glorious PC Gaming Race GMMK Keycaps
First in the line up of Glorious accessories we have keycaps! Made from durable PBT plastic, you will be spoiled for choice when it comes to colour. There are seven – yes, seven! – sets to choose from. Go classic with Black Ash or Arctic White. Perhaps go trendy with Pastel or out of this world with Nebula. Feel exotic with Caribbean Ocean or Rainforest. Or perhaps go with understated class and opt for Olive. Whatever your aesthetic, there is sure to be a Glorious GPBT Keycap set to match.
The legends are printed using the DYE-sub method and placed centrally, making them easy to read. Do you have an RGB keyboard? Worry not, for these keys will positively glow with backlighting surrounding them.
Glorious GPBT Keycaps
- Made from durable PBT
- Available in seven colour schemes
- DYE-sub legends
- Compatible with Cherry MX switches
- Compatible with mechanical keyboards
- Pictured: Top – Nebula, Bottom – Caribbean Ocean
Glorious PC Gaming Race Glorious Keycap Puller
Make pulling keycaps easy with the Glorious Keycap Puller. This gold-plated and ergonomic puller is light in your hands and won’t leave any scratches behind on your keycaps. Hopefully, your new Glorious GPBT Keycaps! It is compatible with all mechanical keyboards, regardless of the profile arrangement. Quick, simple, and easy to use – you’ll be ready to replace your keycaps in no time. Just remember to have a keyboard diagram open while you do!
- Ergonomic shape
- Matte texture
- Lightweight
- Gold-plated
Glorious PC Gaming Race GMMK Rotary Knobs
Our next Glorious accessory is a staple feature on Glorious GMMK Pro Mechanical Keyboards. They all sport a stylish rotary knob for media control, and now you can mix and match colour colours! The Glorious Rotary Knob is easy to remove and install, and available in Black Slate, Gold, and White Ice. Simply remove your existing rotary by pulling it from the bezel and replace it with your new choice by firmly pushing it into place. Hey-presto! You’re done. What’s more, they have an easy-grip textured finish to support even the finest adjustments.
Glorious GMMK Rotary Knob
- Anodised aluminium
- Textured for grip
- Easy to remove and install
- Available in three colours (all pictured)
Glorious PC Gaming Race GMMK Switch Plates
This Glorious accessory is for the super, serious enthusiasts. Glorious have released upgrades for your switch plates, available in brass and polycarbonate. The Glorious GMMK Switch Plates boast great durability and unique features. Musical at heart? Opt for brass, a material often used on instruments for its resonating quality. Want thicker switch feedback? Then polycarbonate is for you. This flexible material is a great boost for mechanical switches.
- Available in brass or polycarbonate
- Highly durable
Glorious PC Gaming Race Glorious Keyboard Case
While “gaming on the go” is something of an alien concept in the current Covid climate, one day soon we might be able to transport our gaming gear. When we can, you’ll be ready with the Glorious GMMK Pro Keyboard Case. The sturdy EVA moulded exterior supports a plush woollen interior, complete with Velcro straps for keeping everything in place. Delightfully finished with Glorious embossed in bold letters, this case will keep your keys safe. For keeping your keyboard safe, this Glorious accessory is a must have.
Glorious GMMK Pro Case
- EVA moulded case
- Premium woollen interior
- Velcro straps for security
- Glorious embossed on the front
- Ideal for GMMK Pro keyboards or 75% keyboards
Glorious PC Gaming Race GMMK Coiled Cables
The Glorious USB Coiled Cables will keep your desk free of clutter while adding a stylish splash of colour. This Glorious accessory is a USB-C to USB-A adaptor, featuring a coiled end for connecting to your keyboard and a longer, straight cable to reach your tower. Merged by a detachable, classic 5-pin aviator connector, signals from your mechanical keyboard will always be reliably sent to your PC. Choose from Phantom Black, Ghost White, Crimson Red, or Nebula and make a bold statement with your cable choice.
Glorious Coiled Cable
- USB-C to USB-A cable
- Coiled section and straight section
- Connected with a detachable 5-pin aviator
- Available in 4 colours – Nebula pictured here
Glorious PC Gaming Race Glorious Premium Switch Puller
Moving onto switch customisation, this range of Glorious accessories are granting you a plethora of options. Made from 100% stainless steel, the Glorious Premium Switch Puller makes pulling switches easier than ever. Cracked housing and broken PCBs are a thing of the past thanks to this handy little tool. Plus, it’s ergonomic and lightweight – making it super comfortable to use.
- Made from stainless steel
- Ergonomic and lightweight
- Quick and easy to use
Glorious PC Gaming Race Glorious Switch Opener
For a thorough clean or application of lubricant, try the Glorious Switch Opener. This device is perfect for removing multiple switches with minimal risk of damage. It can handle Cherry, Gateron, and Kailh switches so whichever is your preference, you are covered too. This is the perfect tool to use when testing out different kinds of switches, getting you closer to finding your favourite.
- Compatible with Cherry, Gateron, and Kailh switches
- Remove multiple switches
- Minimal risk of damage
Glorious PC Gaming Race Glorious Lube Brush
For those who like their keyboard lubricated just so, this is the Glorious accessory for you. The Glorious Lube Brush has a fine, rounded tip perfect for the fiddly application of lubricant to your switches. Made with anti-shed nylon, this brush can be used with every keyboard upgrade and is compatible with all brands of switch lubricant, not just Glorious G-Lube.
Glorious Lube Brush
- Fine, rounded tip
- Anti-shed nylon fibres
- Compatible with all brands
Glorious PC Gaming Race Glorious Lube Station
This Glorious accessory offers a straight-forward way to lubricate switches effectively. Able to hold up to 36 switches and sporting a variety of additional ports, the Glorious Lube Station is an enthusiast who craves efficiency’s dream. This durable unit makes lubricating switches a breeze and will last through many keyboard upgrades. Plus, the anti-slip rubber feet will ensure there are no mishaps and knocks during the process.
- Holds up to 36 switches
- Ports for tools and switch stems
- Anti-slip rubber feet
- Everything you need for lubricating switches in one place
Glorious PC Gaming Race Glorious Panda Toy
Finally, the ultimate Glorious accessory: a vinyl panda desk buddy. At 3″ tall, it sports a fierce expression for striking fear into your enemies hearts! Its conical feet keep it stable on your desk and its back is adorned with a switch stem. While it has no moving parts, this little cutie is definitely a vital addition! (I think I might name mine Ptooie the Panda.)
Glorious Vinyl Panda
- 3″ tall
- Stable, conical feet
- Fierce expression
- Perfect desk companion
Feeling spoiled for choice?
Good! With these Glorious accessories, your gaming PC is going to be stylish and perfectly tuned to your needs. So, what are you waiting for? Pre-order now!
