Do you want to experience the very best of 1080p and 1440p gaming but don’t know which graphics cards are compatible? Well, you’re in luck! As the PC experts, we’ve put together this handy guide detailing our top recommended graphics cards and gaming monitors for 1080p and 1440p gaming.
1080p Gaming
1080p stands for the resolution of your monitor. In this instance, your monitor will have a resolution of 1920 x 1080, the most common type of gaming monitor.
A 1080p monitor is great for gaming, offering you high-quality images, videos, and fast refresh rates, without breaking the bank. A 1080p display is especially beneficial to those who enjoy fast-paced competitive gaming and esports, as they boast incredible response times, giving you that extra edge over your enemies.
1440p Gaming
Alternatively, 1440p means your monitor performs at 2560 x 1440, providing you with over a third more pixels than a traditional 1080p display.
Compared to 1080p, 1440p monitors deliver more pixels, therefore sharper, clearer visuals. Thanks to these high-resolution images with stunning clarity and response times, 1440p is the perfect choice for those looking to get immersed in all their favourite gaming worlds.
What Monitor Should I Buy for 1080p and 1440p Gaming?
If you want to give your setup a worthy upgrade with a 1080p or 1440p gaming monitor, here at Overclockers UK we have plenty of options available for you. We’ve selected two of our favourites below, along with buttons you can follow to check out the entire range.
Gigabyte G27FC A 1920 X 1080 Gaming Monitor:
- 27” gaming monitor
- 1920 x 1080 display
- VA panel
- 165Hz refresh rate
MSI MAG 275CQRXF 27” Widescreen Gaming Monitor:
- 2560 x 1440 display
- VA panel
- 240Hz refresh rates
Monitor resolutions, refresh rates, and panel type. There is so much high-tech terminology about our gaming monitors. Don’t know where to begin? Then check out our guide to gaming monitors!
What Graphics Card Do I Need for 1080p and 1440p Gaming?
To experience smooth gaming at 1080p and1440p gaming, we recommend any of the following graphics cards:
Each of these graphics cards comes equipped with everything you need to enjoy 1080p and 1440p gaming, including plentiful video memory, fast clock speeds, and much more.
NVIDIA RTX 40 Series:
Harness powerful Ada Lovelace architecture to unlock blisteringly fast performance in both gaming and streaming alike. Both third-gen RT and fourth-gen Tensor cores have been redefined to deliver stunning hyper-realistic visuals, complete with immersive lighting and shadows, along with buttery-smooth frame rates.
Each NVIDIA RTX 40 Series graphics card comes equipped with an array of powerful technology, including support for Ray Tracing and AI DLSS 3.0, to deliver you an optimised gaming experience at both 1080p and 1440p.
Want to read more about the cutting-edge tech included with the NVIDIA RTX 40 Series graphics cards? Check out our ultimate RTX 40 Series guide!
Palit GeForce RTX 4060 Ti Dual 8GB GDDR6 Graphics Card:
- Ada Lovelace architecture
- 4352 CUDA cores
- 2.54GHz boosted clock speeds
- 8GB GDDR6 video memory
MSI GeForce RTX 4060 Ventus 2X OC 8GB GDDR6 Graphics Card:
- 3072 CUDA cores
- 2.46GHz boosted clock speeds
NVIDIA RTX 30 Series:
The NVIDIA 30 Series utilise powerful Ampere architecture to deliver fast performance, smooth frame rates, and realistic visuals thanks to integrated RT and Tensor cores. All these RTX 30 series graphics cards come equipped with up to 12GB of built-in GDDR6 video memory, quick boost clock speeds of up to 1785MHz, and up to 5888 CUDA cores. All of which combined result in exceptional performance in 1080p and 1440p gaming.
What’s more, with support for cutting-edge features including Ray Tracing, AI DLSS, and G-Sync, these graphics cards will render all your gaming adventures in photo-realistic quality, for enhanced immersion.
Unsure if the NVIDIA RTX 30 Series is good for gaming in 2023? Take a look at our dedicated blog post.
Zotac GeForce RTX 3070 AMP Holo 8GB GDDR6 Graphics Card:
- Ampere architecture
- 5888 CUDA cores
- 1785MHz boosted clock speeds
Unfortunately, RTX 3070 GPUs are no longer available.
ASUS GeForce RTX 3060 Dual OC 12GB GDDR6X Graphics Card:
- 3584 CUDA cores
- 1867MHz boosted clock speeds
- 12GB GDDR6X video memory
AMD Radeon RX 6000 Series:
All these AMD Radeon RX 6000 Series GPUs are the perfect choice for gamers looking to take advantage of 1080p and 1440p gaming. Armed with up to 12GB of GDDR6X video memory and fast boosted clock speeds of 2581MHz, enjoy an optimised gaming experience that is sure to prove advantageous during the heat of battle.
Harness built-in support for DirectX12 Ultimate and AMD FidelityFX Super Resolution, to unlock immersive visuals and silky-smooth frame rates.
Does the AMD Radeon RX 6000 Series come equipped with plenty of game-enhancing features? Are these graphics cards good for gaming? Read our post to find out.
PowerColor Radeon RX 6700 XT 12GB GDDR6 Graphics Card:
- AMD RDNA 2 architecture
- 2581MHz boosted clock speeds
- DirectX 12 support
- Dedicated ray accelerators
Unfortunately, Radeon RX 6700 XT GPUs are no longer available.
Sapphire Radeon RX 6600 Pulse Gaming 8GB GDDR6 Graphics Card:
- 2491MHz boosted clock speeds
*Please be aware that there is limited availability on some of these models.*
Best Gaming PCs for 1080p and 1440p
OcUK Gaming Tanto Configurable PC:
- Configurable gaming PC
- As standard includes an AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
- 32GB DDR5 RAM
- Flexible storage options available
OcUK Gaming Radiance Frosty MK2 Configurable PC:
- As standard includes an Intel Core i5 11400F CPU and NVIDIA RTX 4060
- Up to 32GB DDR4 RAM
Refract Gaming Jade Pre-built PC:
- Pre-built gaming PC
- Includes an AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
- 32GB DDR4 RAM
- Comes with a three-year warranty
Level Up Your Hardware Knowledge
Your Top Recommendations for 1080p and 1440p Gaming?
Do you have any top graphics cards or gaming monitors for 1080p and 1440p gaming? Why not help a fellow gamer out and leave your recommendations in the comments below?
*Prices correct at time of writing and PC specs are subject to change.
