What You Need to Know About Monster Hunter Wilds
It’s time to sharpen your swords, make some potions, and get ready for Monster Hunter Wilds
Since the first trailer dropped, we have been eagerly waiting for Monster Hunter Wilds to release on PC. Available to play from February 28th 2025, we have got everything you need to know ahead of downloading this foray into the Monster Hunter world. From gameplay details to official specifications, and even a cheeky PC rec or two – we’re here to make sure you’re ready to take down some monsters.
Monster Hunter Wilds Gameplay
Monster Hunter Wilds is the latest in the Capcom series, taking us to a whole new village surrounded by tough and perilous lands. You play as the Hunter, tasked with tracking and defeating powerful monsters that live in the Forbidden Lands. Hone your fighting skills, forage for materials to make new weapons and armour, and familiarise yourself with the environment – it’s going to take more than just hacking and slashing to best these monsters.
The Forbidden Lands
The greatest challenge you will face as the Hunter may not be the beasts themselves, but the Forbidden Lands. These wide and treacherous lands have shifting weather that will change on you constantly. There are harsh Fallow and perilous Inclemency periods, where monsters will hunt you as much as you hunt them. But in periods of Plenty, there will be abundant wildlife and plenty of materials to forage for your next set of weapons and armour.
The world is in constant flux, and the monsters will adapt their behaviours to better survive and thrive. As the Hunter, you too must be flexible with your tactics, mastering more than one weapon so you are always ready for whatever these battles throw your way. Thankfully, there is an impressive collection of ranged and melee weapons to specialise in, and different armours to suit various environments, fighting styles, and more.
Build your hunter through a compelling story that will take you deep into the Forbidden Lands.
Monster Hunter Wilds game still from Steam
Is Monster Hunter Wilds Multiplayer?
Monster Hunter Wilds does feature multiplayer. You can play co-operatively online with up to three of your friends, regardless of platform thanks to crossplay support.
Monster Hunter Wilds Platforms
Monster Hunter Wilds is available to play on PlayStation 5, Xbox Series X/S, and PC from February 28th 2025.
Monster Hunter Wilds Official Specifications
Is your gaming PC properly equipped to take down these behemoths? Here are the official specifications for Monster Hunter Wilds:
ComponentMinimum SpecsRecommended Specs
Operating SystemWindows 10 / 11
64-bit
Windows 10 / 11
64-bit
ProcessorIntel Core i5-10400
Intel Core i3-12100
AMD Ryzen 5 3600
Intel Core i5-10400
Intel Core i3-12100
AMD Ryzen 5 3600
Memory16GB RAM16GB RAM
GraphicsNVIDIA GeForce GTX 1660 6GB
AMD Radeon RX 5500 XT 8GB
NVIDIA GeForce RTX 2060 Super 8GB
AMD Radeon RX 6600 8GB
DirectXVersion 12Version 12
NetworkBroadband Internet connectionBroadband Internet connection
Storage75GB available space
SSD is required
SSD is required
Additional NotesThis game is expected to run at 1080p / 30 FPS (upscaled from 720p native resolution) under the “Lowest” graphics setting.
DirectStorage supported.
This game is expected to run at 1080p / 60 FPS (with Frame Generation enabled) under the “Medium” graphics setting.
AMD Monster Hunter Wilds promo
Get a Copy of Monster Hunter Wilds with AMD!
For a limited time, you can score a copy of Monster Hunter Wilds on select AMD products! Between February 25th and April 26th 2025, you will receive a game code when you purchase a qualifying AMD CPU, GPU, gaming PC, or gaming laptop. Then, you’ll have until May 24th 2025 to redeem your code. For more information, check out our dedicated page, complete with qualifying products. There’s never been a better time to upgrade – happy hunting!
Best PCs to Play Monster Hunter Wilds
With stunning graphics and explosive gameplay, it’s no wonder that Monster Hunter Wilds has comprehensive hardware requirements. The fact it can be run on slightly older generation tech does make it accessible to most, but if your gaming PC is lacking some oomph, we got you. At Overclockers UK, we have an extensive collection of gaming PCs and laptops that will be the Felyne to your hunter. We’ve picked out five faves here that we think will be a great fit for Monster Hunter Wilds. If you need a different set of weapons, though, you can explore our full range with just the click of a button.
OcUK Gaming Mach 1 Pre-Built PC
  • Pre-built gaming PC – balancing 1080p performance and budget
  • AMD Ryzen 5 5600 CPU
  • NVIDIA GeForce RTX 4060 GPU
  • 16GB DDR4 RAM and 1TB SSD storage
  • Covered by our three years parts and labour warranty
OcUK Gaming Mach 1 - Ryzen 5600, RTX 4060 Pre-Built Gaming PC
Refract Gaming Jade 2023
Refract Gaming Jade Pre-Built PC
  • Pre-built gaming PC – fully tested and ready to ship!
  • AMD Ryzen 7 7700 CPU
  • NVIDIA GeForce RTX 4060 Ti GPU
  • 32GB DDR5 RAM and SSD storage
Gigabyte AORUS 16X Gaming Laptop
  • 16” QHD 165Hz gaming laptop
  • Intel Core i7-13650HX CPU
  • NVIDIA GeForce RTX 4070 GPU
  • 32GB DDR5 RAM and 1TB NVMe SSD
  • WINDFORCE Infinity cooling system
Gigabyte AORUS 16X i7-13650HX Gaming Laptop
OcUK Gaming Khopesh - AMD Ryzen 7 7700X, RTX 4070 Ti Super Gaming PC
OcUK Gaming Khopesh Custom PC
  • Configurable gaming PC – adjust the base spec to suit your needs!
  • Select an AMD Ryzen 7000 or 9000 Series CPU
  • Your choice of NVIDIA RTX 40 or 50 Series GPUs
  • Up to 64GB DDR5 RAM
  • Select up to three high-speed SSDs
OcUK Gaming Katana Custom PC
  • Select a 14th Gen Intel Core CPU
OcUK Gaming Katana - Intel i7 14700KF, GeForce RTX 4070 Ti Super Gaming PC
More Monster Hunting Action!
Looking for more monster hunting action? We got you, boo.
Monster Hunter Rise
Relive Monster Hunter Stories: Everything You Need to Know
Monster Hunter Rise: Sunbreak - Everything You Need to Know About This Massive Expansion
Will You Be Playing?
Let us know in the comments below if you’ll be playing Monster Hunter Wilds!
PC specs are subject to change.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
