We have two titans of their respective industries coming together with the noblechairs LEGEND Shure Edition.
This ergonomic gaming chair and matching pillow set pay homage to the classic 55SH microphone whilst providing outstanding comfort. What more could an audiophile want from a chair?!
What Is Available?
There are two stunning Shure Editions joining the noblechairs line-up. The LEGEND Gaming Chair Shure Edition and Memory Foam Pillow Set Shure Edition. All your comfort bases covered.
A Shure Thing
The noblechairs LEGEND Shure Edition is subtle, yet stunning. On both the front and back are homages to the classic 55SH microphone. You know the one, cylindrical head, metal casing, retro 50’s style. A true icon of the audio industry.
The LEGEND Shure Edition front features black velour panelling on a grey backdrop, to emulate the metal grill, complete with the central logo. The wings are accented with lime green stitching to match the Shure branding on the headrest, whilst darker grey panels frame the whole design. Upon the back is an embroidered rendering of the microphone, stand and all. This is intersected by grey and green lines, truly making the design pop.
For the final touch of class and elegance, the noblechairs logo is on the headrest with more Shure branding at the very bottom of the backrest.
Shure Features
More than just its good looks, the noblechairs LEGEND Shure Edition is packed with superior ergonomic features, premium materials, and enhanced durability.
The backrest has integrated lumbar support that can be adjusted to suit your exact needs, and it reclines down to 125-degrees. The lockable tilt rocking mechanism boasts 11-degrees of movement, so you can lean back in confidence and style. Of course, this gaming chair features 4D armrests, that are lightly textured in a way that balances comfort and grip. These can be configured in four directions, height, depth, angle, and distance from seat base, allowing you to be perfectly aligned with your desk. Experience peak comfort with every music session.
Each noblechairs LEGEND Shure Edition is precision made by machines with premium materials, crafting consistency for every model. The frame is stainless steel, lending strength, stability, and durability to the chair. Padded for comfort and support, this chair utilises dense cold foam that remains deform resistant, even with heavy usage. The PU leather upholstery is highly breathable and beautifully holds the design colours whilst being easy to clean.
Providing a strong foundation, the five-point base is manufactured from power-coated aluminium. Each arm ends in an XL caster made from a Nylon core and polyurethane coating, which makes them effortlessly glide over soft and hard flooring, alike. Gaming set up or music studio, roll with ease.
Finally, as a mark of quality and safety, this gaming chair is both DIN EN and TÜV certified!
noblechairs LEGEND Gaming Chair Shure Edition
- Officially licenced Shure design
- PU leather and cold foam padding
- Superior ergonomics such as adjustable lumbar support
- Premium build quality
- DIN EN 1335 certified
Comfort, I’m Shure
Take your comfort levels further, with the noblechairs Memory Foam Pillow Set Shure Edition. Including a neck and lumbar pillow, this set is designed to go with the LEGEND Shure Edition but will work with any noblechairs of your choosing.
The neck pillow is a plush 85mm thick, covered with soft-to-the-touch velour. It features a small, embroidered rendering of the 55SH microphone with a lime green “S” at the centre. The lumbar pillow is 80mm thick and utilises the same material, prominently displaying the Shure branding and tag line, over geometric grey and green lines. A subtle bit of texturing.
Both pillows are padded with memory foam, holding their shape with every gaming or recording session. Cheeky bonus? They are machine washable at 40-degrees!
- Neck and lumbar pillow set
- Memory foam padding
- Velour cover
- Machine washable
noblechairs has an extensive range of special edition pillow sets. If the Shure pillow set isn’t playing your tune, check out their full range!
Sound Extraordinary
Is this the throne you’ve been waiting for? Both the noblechairs LEGEND and Memory Foam Pillow Set Shure Editions are available to pre-order from Overclockers UK. Drop a comment if it’s a Shure-fire thing you’ll be upgrading!
