A cultural phenomenon, game of the century, and holder of childhood nostalgia, Minecraft has been around in one form or another since 2009! But did you know you can actually play Minecraft in VR? In this article we’ve got all the deets on how to do just that.
How To Play Minecraft In VR
Before we jump right in, Minecraft only officially supports virtual reality in Bedrock Edition. This means versions purchased from the Microsoft Store have built-in VR support.
Here’s how to get started, whether you’re using a HTC VIVE, META QUEST, or another VR headset:
Step One – Connect your VR headset to your PC. You can do so through a tether cable, Airlink, or other wireless VR applications.
Step Two – If detected automatically, Minecraft should appear in your games library on your VR headset. Don’t worry if the game fails to show up, as you may have to set up Minecraft VR manually which we’ll show you how to do below 👀
Minecraft VR Is Not In My Games Library
Don’t panic! VR is still a tricky beast sometimes, but there is a super simple way to force Minecraft to launch in VR from your desktop. If the game has failed to appear in your headset’s game library automatically, there are some options you can try. If you’re using SteamVR, you can add Minecraft Bedrock Edition to Steam as a non-Steam game and launch it from within SteamVR.
Option One – To add a non-steam game, simply navigate to the bottom left of your Steam library and click “Add a Game”. You’ll then be prompted to locate the .exe file for the game. Now you should be able to launch Minecraft from within Steam and SteamVR.
Option Two – You can also create a Shortcut on your desktop to launch Minecraft Bedrock Edition in VR.
Step One – Right-click on your desktop and select ‘New’ > ‘Shortcut’.
Step Two – In the location field, enter: minecraft://Mode/?OpenXR=true.
Step Three – Click ‘Next’ and name your shortcut (e.g., “Minecraft VR”).
Step Four – Click ‘Finish’. The shortcut will appear on your desktop with the Minecraft icon.
Using the Shortcut – Ensure your VR headset is connected and powered on. Click the newly created shortcut to launch Minecraft: Bedrock Edition in VR.
Ready For VR?
There’s more than just Minecraft to play in virtual reality! From Cyberpunk 2077 to countless indie and even AAA games, you’ll never run out of games. If you’re ready to jump in, Overclockers UK has a huge range of VR-ready gaming PCs, including customisable and next day delivery options.
At Overclockers UK, we have our exciting range of pre-built PCs – Refract Gaming – and they have been updated with shiny new tech!
OcUK Gaming Empath – AMD Ryzen 7 7700X, RTX 4070 Gaming PC
- AMD Ryzen 7 7700X Eight Core Processor with 5.4GHz Boost
- 32B DDR5 5600MHz Dual Channel Kit
- Nvidia GeForce RTX 4070 12GB Graphics Card
- 2.5Gb LAN, WIFI 6 & Bluetooth
- Ideal For VR Gaming
OcUK Gaming Rapier – AMD Ryzen 5 7600, GeForce RTX 4070 Super Gaming PC
- AMD Ryzen 5 7600 3.8GHz (up to 5.1GHz Boost) Six Core Processor
- 240mm AIO Liquid Cooler
- 32GB DDR5 5600MHz Dual Channel Kit
- Nvidia GeForce RTX 4070 Super 12GB Graphics Card
Hey, maybe it’s time for a new VR headset. We’ve got a great selection of HTC VIVE VR headsets for you to check out, including full PCVR kits with lighthouse tracking and even wireless options like the HTC VIVE XR Elite All-in-one XR
HTC VIVE PRO 2 Full Kit – HD VR Headset, Controllers, Base Stations
- Explore VR content in brilliant clarity and bring out the finer details with a combined 4896 x 2448 resolution.
- 120° horizontal field of view (FOV) expands your visual experience and better aligns with the human eye, letting you see more naturally.
- Stay in the moment with precision SteamVR™ Tracking that provides 360-degree coverage of your movement to the millimeter.
HTC VIVE XR Elite All-in-one XR and PC-VR Gaming System
- Convertible form factor. Detach the battery cradle for enhanced portability.
- Vivid passthrough. Blend physical and virtual worlds. Expand play. New possibilities.
- Lightweight XR. A sleek, compact headset that goes where you go.
- Finely tuned viewing. Adjustable IPD and diopter dials for the most natural and clearest visual experience.
Have you Tried Minecraft In VR?
Creeper? Awww man! If you’re building a grand palace or killing mobs in VR Minecraft, then make sure to drops some tips and tricks for us in the comments below.
PC specs are subject to change.
