Are you looking to create the ultimate racing sim set-up? Or is your existing one looking tired and in need of an upgrade? MOZA Racing is the premium choice amongst gamers seeking to harness the very best to climb their way up the leaderboards.
In this extensive guide, we’re showcasing everything MOZA, from why their line-up is good for gaming, to highlighting the key essentials of a racing sim set-up, and even sharing our top MOZA Racing recommendations. We’ll also be detailing the compatibility between all their products, ensuring you have all the information you need to build the perfect racing sim set-up.
What is MOZA Racing?
Established in 2012, MOZA Racing has become the world’s leading manufacturer of racing sim gear. Created in partnership with engineers and sim racing drivers, MOZA Racing hardware boasts cutting-edge designs and innovative features to boost your gameplay to the next level.
MOZA has created everything you need to construct a powerful racing sim set-up from premium-quality wheels and pedal sets to digital dashboards.
Why is MOZA Racing Good for Gaming?
MOZA Racing is the ultimate choice for gamers looking to craft their very own racing sim. MOZA’s line-up of professional-grade hardware delivers incredible in-game immersion, especially when paired with Pit House.
Pit House is MOZA’s very own software that has been designed to put you at the centre of the racetrack. You’ll have complete customisation at your fingertips with the ability to configure the settings and even lighting to suit your own individual preferences. Plus, thanks to plug-and-play compatibility with a range of popular racing titles such as Forza Horizon 5, F1 2022, and Assetto Corsa, you’ll have everything you need to ensure you earn the number one spot on the podium.
What Hardware Do You Need to Create a Racing Sim Set-Up?
A racing sim set-up typically consists of six core components – a PC, monitor, chair, cockpit, pedal set, and a wheel.
The PC
At the centre of any racing sim set-up is the PC. Your gaming PC needs to be equipped with a premium processor and high-capacity RAM to facilitate seamless performance in even the most demanding applications. A top-tier GPU is also a must for ensuring the racetrack is rendered in incredible quality, allowing you to see every second of the action before you turn the corner. What’s more, plentiful storage ensures you’ll never need to worry about running out of precious storage space for your expanding gaming library.
Refract Gaming Indigo Pre-Built PC
- Pre-built gaming PC
- Designed for elite-tier gaming and high-quality streaming
- AMD Ryzen 7 7900X3D CPU and NVIDIA RTX 4080 Super
- Up to 32GB DDR5 RAM
- 1TB M.2 SSD
- Windows 11 Home
Monitor
To immerse you fully in your virtual races, you’ll need a high-quality monitor. We recommend you opt for one with a high refresh rate, such as 360Hz, and a resolution of at least 1440p. This will deliver exceptional gaming performance and response times. With virtually zero screen tearing, display stutter, or lag, you’ll experience no unwanted interruptions as you blaze across the finish line at record speed.
ASUS ROG Swift 27” PG27AQN Gaming Monitor
- 27” gaming monitor
- 2560 x 1440 resolution
- IPS panel
- 360Hz refresh rates
- 1ms response time
Cockpit and Chair
The foundation of any racing sim set-up is a durable cockpit and plush racing seat chair. Expertly engineered with only the finest materials, a racing sim cockpit has been optimised to put you at the centre of the gameplay, whilst the chair delivers unparalleled comfort for your extended hours of racing.
Most racing sim cockpits are compatible with a wide range of popular manufacturers, including MOZA racing, ensuring you can use them alongside all your other must-have hardware.
Next Level Racing GTRacer Simulator Cockpit
- Racing sim cockpit
- Includes racing seat
- Supports 13NM direct drive wheels
- Adjustable wheel and shifter plate
- Compatible with pedal sets and wheels from leading brands, including MOZA
Racing Wheel and Pedal Set
Lastly, is a racing wheel and pedal set. These components are vital for delivering an authentic racing experience to unlock pixel-precise control over the virtual road. Equipped with different feedback styles, such as hydraulic pedals or force feedback racing wheels, you can further fine-tune your racing essentials to suit your demands.
MOZA Racing R3 Racing Simulator Bundle
- Racin sim bundle
- Includes R3 Wheelbase, ES Steering Wheel, and SR-P Lite Pedal Set
- Compact design
- Compatible with a variety of popular titles such as Forza Horizon
Optional Add Ons
In addition to the must-haves, you can also find plenty of tasty add-ons to take your racing sim set-up to a whole new level. This includes handbrakes, gear shifters, emergency stop buttons, and even extra monitor stands. All of which work in perfect harmony to immerse you further in the virtual road and ensure you lift that trophy!
MOZA Racing Product Compatibility
The beauty of MOZA Racing hardware is the extensive compatibility across all their products. You’ll most likely find that you can use your existing wheel or pedal set without having to spend extra on a costly unwanted upgrade.
To make life easier (and because we love to spoil you) we’ve compiled the tables below which details the cross compatibility between MOZA Racing hardware.
Wheelbases and Racing Wheels Compatibility
Product | R3 Base | R5 Base (Old) | R5 Base (New) | R9 V1 (Old) | R9 V2 (Old) | R9 V2 (New) | R12 Base | R16 Base (Old) | R21 Base (Old) | R16 Base (New) | R21 Base (New) |
R5 ES Wheel | ✅ | ✅ | ✅ | ❌ | ✅ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
R3 ESX Wheel (For XBOX) | ✅ | ✅ | ✅ | ❌ | ✅ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
KS Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
RS V2 Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
CS V2P Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
FSR Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
TSW Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
VGS Wheel | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
CS V1 Wheel | ❌ | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ | ✅ | ✅ |
RS V1 Wheel | ❌ | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ | ✅ | ✅ |
GS V1 Wheel | ❌ | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ | ✅ | ✅ |
Wheelbases and Pedal Sets Compatibility
SRP Lite Pedals | ✅ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
SR-P Pedals (Old) | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 |
CRP Pedals (Old) | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 | 🔹 |
SR-P Pedals (New) | ✅ | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ |
CRP Pedals (New) | ✅ | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ |
Wheelbases and Add-Ons Compatibility
HBP Handbrake | ✅ | 🔹 | ✅ | 🔹 | 🔹 | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ |
HGP Shifter | ✅ | 🔹 | ✅ | 🔹 | 🔹 | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ |
SGP Sequential Shifter | ✅ | 🔹 | ✅ | 🔹 | 🔹 | ✅ | ✅ | 🔹 | 🔹 | ✅ | ✅ |
E-Stop | ✅ | ❌ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ |
CM Digital Dash | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
RM Racing Dash | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ | ✅ | ✅ | ✅ | ✅ |
Scary table aside, the key takeaway is that not all MOZA Racing hardware is cross compatible with each other. This is mostly due to differences in connectivity with the first generation of components opting for Bluetooth over USB wired. Therefore, we recommend that you always check the manufacturer page for your chosen component for more details.
Shop MOZA Racing
Are you looking to enhance your sim set-up with MOZA Racing hardware? At Overclockers UK, we stock an extensive range of MOZA Racing hardware from responsive wheels and pedal sets to plenty of must-have add-ons to enhance your driving experience further.
If you want to see more, you can click the button below to shop the entire MOZA Racing range available at OcUK.
Engines At the Ready
3.2.1… Race!
Do you have any MOZA Racing products in your racing sim set-up? Got any top recommendations? Share them in the comments below.
PC specs are subject to change.
