Are you looking to upgrade to the latest AMD Ryzen 7000 Series CPUs? Then look no further! Here at Overclockers UK, we’ve put together this complete guide, detailing everything you need to know about these processors, along with all of the hardware you need to upgrade.
The AMD Ryzen 7000 Series has been built to enhance your performance in both gaming and content creation alike.
AMD Ryzen 7000 Series Banner
Engineered utilising cutting-edge Zen 4 architecture, each of the four CPUs in the series features an optimised metal stack design with smaller and faster power transistors. This delivers exceptional performance and ultra-fast speeds in both single and multi-threaded tasks. Plus, all AMD Ryzen 7000 Series CPUs come armed with a vast array of intelligent built-in features, such as AMD RDNA 2, along with support for the latest gen of technology, including PCIe 5.0 and DDR5 RAM.
In fact, AMD has even developed a memory overclocking software, specifically for DDR5 RAM, called AMD EXPO. With AMD EXPO, you can easily overclock with just one click, making the process even simpler for complete beginners and veteran overclockers alike.
The CPUs
There are currently eleven desktop processors available in the series.
  • AMD Ryzen 5 7600X
  • AMD Ryzen 7 7700X
  • AMD Ryzen 9 7900X
  • AMD Ryzen 9 7950X
  • AMD Ryzen 5 7600
  • AMD Ryzen 7 7700
  • AMD Ryzen 9 7900
  • AMD Ryzen 7 7800X3D
  • AMD Ryzen 9 7900X3D
  • AMD Ryzen 9 7950X3D
AMD Ryzen 5 7600XAMD Ryzen 7 7700XAMD Ryzen 9 7900XAMD Ryzen 9 7950XAMD Ryzen 5 7600 AMD Ryzen 7 7700AMD Ryzen 9 7900AMD Ryzen 9 7950 X3DAMD Ryzen 9 7900 X3DAMD Ryzen 7 7800 X3D
Cores681216681216128
Threads12162432121624322416
Base clock4.7GHz4.5GHz4.7GHz4.5GHz3.8GHz3.8GHz3.7GHz4.2GHz4.4GHz4.2GHz
Boost clock5.3GHz5.4GHz5.6GHz5.7GHz5.1GHz5.3GHz5.4GHz5.7GHz5.6GHz5.0GHz
Cache38MB40MB76MB80MB32MB32MB64MB144MB140MB1.4MB
TDP105W105W170W170W65W65W65W120W120W120W
AMD Ryzen 5 7600X:
The ideal choice for those looking to get into PC gaming or content creation! The AMD Ryzen 5 7600X features a combination of 6 cores and 12 threads to effectively handle any task you throw its way. With a boost clock speed of up to 5.30GHz, you can enjoy ultra-fast speeds and exceptional performance in both gaming and streaming.
  • AMD Zen 4 architecture
  • Six cores and 12 threads
  • Base clock speed of 4.7GHz
  • Boost clock speed of up to 5.3GHz
  • 105W TDP
AMD Ryzen 7 7700X:
The AMD Ryzen 7 7700X comes equipped with 8 cores and 16 threads for powerful performance in both single and multi-threaded tasks. Experience all of your favourite AAA titles like never before with a maximum boost clock of up to 5.40GHz!
  • Eight cores and sixteen threads
  • Base clock speed of 4.5GHz
  • Boost clock speed of up to 5.4GHz
  • 105W TDP
AMD Ryzen 9 7900X:
The AMD Ryzen 9 7900X is the perfect choice for the gamer or streamer looking for an upgrade. This CPU has been optimised for high-speed gaming and comes packed with 12 cores and 24 threads.
  • Twelve cores and twenty-four threads
  • Boost clock speed of up to 5.6GHz
  • 170W TDP
AMD Ryzen 9 7950X:
Expertly crafted for enthusiasts and content creators is the AMD Ryzen 9 7950X. Built with a powerful combination of 16 cores and 32 threads, and with a boost clock of up to 5.7GHz, experience blisteringly fast performance in a vast array of intensive tasks, such as 4K gaming, image rendering, and much more!
  • Sixteen cores and thirty-two threads
  • Boost clock speed of up to 5.7GHz
  • 170W TDP
For a closer, in-depth look at the AMD Ryzen 7000 Series and all of the cutting-edge features included with these CPUs, you can read more in our dedicated blog article.
AMD Ryzen 5 7600:
The AMD Ryzen 5 7600 is an excellent entry-level gaming and content creation processor. This model is part of the high-efficiency line of CPUs, with a maximum TDP of 65W that is expertly managed by the included AMD Wraith Stealth cooler. The 6 cores and 12 threads expertly handle multi-tasking, mainstream gaming, and workflows.
AMD Ryzen 5 7600
  • Base clock speed of 3.8GHz
  • Boost clock speed of up to 5.1GHz
  • 65W TDP
  • Includes AMD Wraith Stealth cooler
AMD Ryzen 7 7700:
Crafted for mainstream gaming, the AMD Ryzen 7 7700 boasts 8 cores, 16 threads, and boost speeds up to 5.3GHz. Once again, this processor features a lower TDP of 65W, with the AMD Wraith Prism cooler managing temperatures. What’s more, this CPU has future-proof support for DDR5 RAM and PCIe 5.0 connectivity on both GPUs and SSDs.
  • Eight cores and 16 threads
  • 65W TDP
  • Includes AMD Wraith Prism cooler
AMD Ryzen 7 7000 Series CPU
AMD Ryzen 9 7900:
At the top of the high efficiency line is the AMD Ryzen 9 7900 processor, with 12 cores and 24 threads. This CPU is great for AAA gaming, streaming, and content creation, with incredible boost speeds up to 5.4GHz. All with that lower TDP of just 65W, managed by the included AMD Wraith Prism cooler with integrated vivid RGB lighting.
  • Twelve cores and 24 threads
  • Base clock speed of 3.7GHz
  • 65W TDP
AMD Ryzen 7000 Series Efficiency CPUs
For a closer look at the high efficiency line-up, check out our dedicated article.
AMD Ryzen 7 7800X3D:
Joining the 3D V-Cache line up is the AMD Ryzen 7 7800X3D. Equipped with the same innovative stacked cache, this processor is perfect for mainstream gamers and streamers looking to get a little more oomph from their CPU. Pairing 8 cores and 16 threads with a juicy 104MB cache, this CPU should be the sweet spot for most gamers!
  • Base clock speed of 4.2GHz
  • Boost clock speed of up to 5.0GHz
  • 120W TDP
  • Innovative 104MB 3D V-Cache
AMD Ryzen 7 7800X3D
AMD Ryzen 9 7900X3D:
The first Ryzen processor to utilise AMD’s 3D V-Cache technology is the AMD Ryzen 9 7900X3D. Similar in spec to its other 9 7900 counterparts, this CPU has a 3D stacked cache that facilitates a higher capacity, at 140MB, and incredibly fast fetch rates. As a result, this is a high-performance processor for gaming, content creation, and streaming.
AMD Ryzen 9 7900X3D
  • Base clock speed of 4.4GHz
  • 120W TDP
  • Innovative 140MB 3D V-Cache
AMD Ryzen 9 7950X3D:
Additionally, there is the AMD Ryzen 9 7950X3D model, with a whopping 144MB cache. Paired with 16 cores, 32 threads, and boost speeds up to 5.7GHz, this CPU is the ultimate hardware for gamers and creators.
  • Sixteen cores and 32 threads
  • 120W TDP
  • Innovative 144MB 3D V-Cache
AMD Ryzen 9 7950X3D Sixteen Core 5.70GHz (Socket AM5) Processor - Retail
AMD Ryzen 7000X3D Gaming CPUs with 3D V-Cache
For a more detailed look at these processors and AMD’s 3D V-Cache, check out our dedicated blog.
8Pack and AMD Ryzen 7000 Series
We sat down with legendary overclockers, 8Pack for a closer look at the AMD Ryzen 7000 Series. If you want to see what he has to say about these processors, you can watch the video down below!
What Do I Need to Upgrade to the AMD Ryzen 7000 Series?
Motherboard:
The AMD Ryzen 7000 Series now has an LGA socket instead of PGA. This means they will not work with the previous generation of motherboards. In order to utilise one of these CPUs, you will need a compatible motherboard with an AM5 socket
ASUS ROG Crosshair X670E Hero DDR5 ATX Motherboard:
  • ATX form factor
  • AMD X670 chipset
  • AM5 socket
  • Compatible with PCIe 5.0 and DDR5 RAM
Cooler:
Similar to your motherboard, you will need a powerful cooler that is compatible with the AM5 socket.  What’s more, these CPUs have a high TPD (Thermal Design Power). Therefore, we recommend you invest in an efficient thermal system to ensure it constantly performs at optimum temperatures.
ASUS ROG Ryuo III 240mm AiO CPU Cooler:
  • 240 AiO CPU cooler
  • RGB lighting
  • 2 x 120mm PWM fans
  • Compatible with AM5 socket
RAM:
The AMD Ryzen 7000 Series does not support DDR4 RAM. You will need to upgrade to DDR5 if you purchase one of these CPUs.  What’s more, if you wish to experience AMD EXPO technology, you will need to buy a compatible EXPO RAM Kit
Corsair Dominator Platinum RGB EXPO 32GB (2x16GB) DDR5 Dual Channel RAM Kit:
  • 32GB (2x16GB RAM sticks)
  • AMD EXPO RAM kit
  • Dual-channel configuration
  • 6000MHz speeds
  • RGB lighting
GPU:
The AMD Ryzen 7000 Series come equipped to support PCIe 5.0, which means you can harness the power of the latest generation of GPUs, including NVIDIA’s RTX 40 Series!
Sapphire Radeon RX 7900 XTX Pulse 24GB GDDR6 Graphics Card:
  • RDNA 3 architecture
  • 2525MHz boosted clock speed
  • 6144 processors
  • FreeSyns 2 support
  • 25GB GDDR6 VRAM
All Your AMD Ryzen 7000 Series Questions Answered!
What Socket Does the AMD Ryzen 7000 Series Use?
The AMD Ryzen 7000 Series utilise an AM5 socket.
Will I Need to Upgrade my Motherboard for AMD Ryzen 7000 Series?
These CPUs no longer work with the previous generation of motherboards since they need an AM5 socket.
For an AMD Ryzen 7000 series, you need to purchase a motherboard that has a compatible AM5 socket.
Does the AMD Ryzen 7000 Series Support DDR4 RAM?
No – the AMD Ryzen 7000 Series does not support DDR4 RAM. Instead, it is compatible with the brand-new DDR5 standard.
You will need to upgrade to DDR5 RAM if you wish to upgrade to an AMD Ryzen 7000 Series.
When Will the AMD Ryzen 7000 Series be Released?
The AMD Ryzen 7000 Series officially launched on the 27th of September 2022. The High Efficiency CPUs joined the line up on January 10th 2023, and the X3D models dropped February 28th 2023. The AMD Ryzen 7 7800X3D model has finally landed too – available from April 6th 2023.
Is the AMD Ryzen 7000 Series Good for Gaming?
The AMD Ryzen 7000 Series come fully equipped with a vast suite of features to enhance your gaming experience. The powerful Zen 4 architecture has been primed to deliver maximum performance in single and multi-threaded tasks. You can enjoy ultra-fast speeds, smooth frame rates, and superior visuals in all of your favourite games. What’s more, new models are joining the series which have lower TDPs or AMD’s 3D V-Cache technology, ensuring there is an AMD Ryzen 7000 CPU suitable for your gaming PC.
If you’re after even more firepower for your favourite games or creative projects – check out the AMD Ryzen 9000 Series. Our dedicated guide has everything you need to know about these processors.
Your Guide to AMD Ryzen 9000 Series
Did You Upgrade to the AMD Ryzen 7000 Series?
Did you upgrade to the AMD Ryzen 7000 Series? Let us know your thoughts in the comments.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
